Everything posted by Scary Leatherworks
Just Got My Cobra 4! Had A Question...
Scary Leatherworks replied to ericluther's topic in Sewing Leather
I started with the 138 thread and had some ok results but was then reccomended to switch to an 18 round point needle with 69 thread. haven't tried that yet was a bit of tensioning to work out had to back it off quite a bit due to the softness of the leather. make sure you try multiple scrap trials to get it right. -
Help With Preparing Article To Sew On Machine
Scary Leatherworks replied to anester05's topic in Sewing Leather
Yes you may need to make the edge wider especially at the corner it's the worst to sew. Try some Barge cement to hold it together so it can't pull apart when you are trying to sew it together. -
needle and tension. I ordered some round point #18 from Steve so I could sew thinner stuff. No they aren't designed for it but I have and still use it to sew thin stuff. I have sewn 2 layers of lamb with my class 4. try smaller needle and thread. When I got mine my smallest needle was a #23 that I used with 138 thread. Also play with the tension to pull the knot in to the middle of the leather -
Yes, you may be mad for trying it wet forming might do the trick. the Gussets being only 4cm and 8oz may be overkill though. When you have to stitch the center (middle separator and 2 gussets) it's going to be 24oz thick. you could probably use much thinner material for the gussets but I also understand how it is when you get an idea and you want to MAKE it work. Make the bends on each side of your gusset a bit wider than you want them to end up partly because you lose some around the corners. Also with an 8oz gusset it and only 4cm wide it won't want to "accordion" in but then you were only hoping to gain a cm
http://www.sewingmachineoutlet.com/ricetn.htm I've never ordered from them but click on the size you want "277,346, or 415" in the "colors" section click add to cart and then you can choose the size and color.
DoubleC I wish Rancn2arena showed more on his website. I didn't see any buckles but do like small companies that make a good product. Also I see you are in VT. Alot of my family is there, but I wanted to let you know on Craigslist someone in Walden (yes I know it's quite a bit north of you) is selling deer hides in a few shades for $20 a piece.
it's more expensive but looks to be exact. if you are in a pinch? http://www.moonshineleather.com/productdetailsbuckles.cfm?productcode=W001S-04
Smallest 794 (7X3) Needle?
Scary Leatherworks replied to Scary Leatherworks's topic in Leather Sewing Machines
Bob thanks, I'll check it out. Busted, I have no idea what size that would be. I don't really know the whole needle size thing. slowly learning though -
what is the smallest needle I can get in the 794 system for a cobra 4? I really want to sew some light leather and needles seem to be a real pain to find or figure out I never realized there were so many needle sizes/types
Selecting Right Type Of Leather, Dye
Scary Leatherworks replied to Taverner's topic in Getting Started
Check Wicket& Craig maybe there English Bridle. You have to call them but they are helpful and they will skive to your thickness and finish the back. I always get nice leather from them http://www.wickett-craig.com/index.php/leathers/description-and-grading -
Couple Of Questions For A Newbie
Scary Leatherworks replied to edgeleatherworks's topic in How Do I Do That?
$26 for a tooling belly you want at least 5/6oz http://springfieldleather.com/25850/Belly%2CHermannOak%2C9-10oz%2CEach/ As said before you want veg-tanned leather if you want to tool it. -
Where To Find This Buckle Or Similar?
Scary Leatherworks replied to JanC's topic in Hardware and Accessories
about 2/3 down the page it's the closest I have ever been able to find for a buckle like that. http://www.hardwareelf.com/elf/buckles.jsp -
http://www.buckleguy.com/products/G7341-19-Links--Natural-Brass%2C-Swivel-Bolt-Snap-w%7B47%7DChain%2C-Solid-Brass.html he has different ones also. Ive always had good luck with him
Call Abbey they may be able to tell you if this is the same. I can't find any info on it here in the states http://www.abbeyengland.com/Store/tabid/77/CategoryID/202/Category2ID/69/catpageindex/3/Level/2/ProductID/69360/Default.aspx
Is this what you're looking for? http://www.bagsmith....d-Capsules.html says free shipping on this one http://www.ebay.com/itm/Sajou-Fil-Au-Chinois-Waxed-Linen-Sewing-Thread-CHOOSE-/130502048581
Tandy Belt Blanks
Scary Leatherworks replied to leatherj's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Yes, you are totally wrong. your math is off a decimal point. I'm assuming with your calculation you were figuring on a 36" belt. 15sqft is 2160sqin but a 3/4" x36" belt is 27sqin, which means 80 belts but as stated above you won't be able to use the whole piece. You will have alot of uneven edges you will have to trim -
Wickett &craig Harness Leather Scratches
Scary Leatherworks replied to Andrew Chee's topic in All About Leather
I had an excellent piece of Show Harness from them. Yup, it scratches easily. I found that if I rubbed my hand over the light scratches they would come out. I even got a fairly significant one out that way, it just took more time. -
I like the neon green. You can buy waxed thread dyed in lots of colors (except neon green) I agree Tandy's selection is a bit boring.
you can get a fairly inexpensive airbrush and compressor to do that. I use my air-nailer compressor for my airbrush but the smaller ones work fine too. I spent $60 on my air-brush 5 yrs ago an it still works great and you can find them cheaper than that. just an example http://www.tcpglobal.com/airbrushdepot/9169.aspx
Need Antique Brass Hardware For A Backpack
Scary Leatherworks replied to DustinNielsen's topic in Suppliers
I get quite a bit of my supplies from http://www.buckleguy.com/ he has some antique brass. Also do a google search and you'll find ways to antique brass yourself if you can't find what you want already antiqued. usually you have to clean the sealer off then hang it in a sealed container with a small amount of ammonia for a while then heat at a low temp for 20-60 min or something like that. as for waxed nylon thread are you hand-stitching or machine. If hand stitching I would suggest waxed linen, instead of nylon. for waxed linen try here http://www.royalwoodltd.com/cat14-17ar.htm I think 7ply for that bag if you really want the stitching to stand out. the waxed linen at Tandy is 6ply get royalwoods thread card for $2 it's worth it for nylon thread or other types http://www.thethreadexchange.com/miva/merchant.mvc?Screen=CTGY&Store_Code=TTE&Category_Code=nylon-thread
