fredk
Contributing Member
Everything posted by fredk
  1. I reckon you're going to have the lace cut. or do it yourself. The advantage of that is you can buy leather which matches the original
  2. Standard lace is 3mm x 1mm. But you can get 6mm x 1mm. What size is the lace on this?
  3. Buy the 1 1/2 inch. You can always have it take out the extra when needed, but you can't make the hole smaller
  4. 'Rosin the bow' One of my childhood favourites. It was many years until I found out the meaning of the word rosin
  5. Here. solid resin, in the form of small pieces is sold as 'resin' or 'rosin'. The term seems interchangeable but only for the solid form of pine resin. I've ordered 'resin' which is also described as ''rosin' and as 'colophony', yet another name given to the solid form of pine resin Go for 'rosin'. Rosin has always been used on instrument stings and bows and as a powder to increase grip on playing/game surfaces and on bats & rackets; all that and more
  6. They are the same, but rosin is dried into cakes but resin may still be liquid yaaaay, I've found it! You'll never believe where it was. It was in my ready-use sewing kit. Who would have thunk it. I wonder who put it there?
  7. I've got one of those thingmebobs* but I've sort of lost it *a technical term
  8. Why is everyone, or nearly everyone, harping on about 'Mop & Glo'. I use it a lot BUT the chap says he doesn't want to use it and wont use it. Can we not try to compare other sealers that ARE available in the leather shop for him to try?
  9. Pine tar? or Pine Resin? Over here they are very different Anyway, thanks. I'm about to order 500g of Pine Resin
  10. First, try taking it back. It should not have any smell. None of mine has.
  11. educate me; what is a 'striker fired pistol' ?
  12. The chap does not want to use Mop & Go Now, of the regular leather shop sealers which meets his needs? tbh, all the ones I have dry matt or with a slight sheen, never a high gloss. It might be because I apply sealer diluted
  13. Classy!
  14. Mahogany won't go with the candy apple red. Why not try red leather?
  15. All of the above, plus I test dyes on it, especially any dye that will be used on something made from the main piece of leather. Also, small drawstring bags/pouches
  16. For those who don't know; as Doc has pointed out, talc is used in paints and varnishes to modify the gloss finish to a matt finish. In this case its called the 'matting agent'. But afaik it has to be talc. Modern baby powder uses corn starch
  17. @SUP Any talcum powder, but make sure its talcum powder, either real or artificial
  18. If you mix a small amount of talcum powder into the sealer it reduces the shine. eg, in a satin sealer it makes it more matt. By how much talc you put in you can control just how much a satin finish you end up with
  19. I see what you mean. I only use my speedy-stitcher in emergencies. Its not too late; you can unpick the sewing and re-do it
  20. That looks grand so it does
  21. BTW, I need a 'stitch' groover for more than marking a stitching line. I need and use one for grooving out the lines on game boards, for delineating the squares. Thus the ability to use it without the guide is important to me
  22. I have the one pictured and I have this one. The difference is that the cutter is in the main body so that when the guide is removed it can be used free-hand
  23. fredk
    Acquired Tools
    It'll take time but those punches can be reground and re-sharpened Would AS Brand mean Al Stohlman Brand?
