DeWayne Hayes
1 Follower
Recent Profile Visitors
2,370 profile views
DeWayne Hayes's Achievements
Member
Member (2/4)
  1. Though I make my own holsters, I recently grabbed a nice Ted Blocker duty holster off eBay - these sell for about $260 new; I got this one for $24! After I re-did the edge painting and used some Fiebing's Atom balm/wax on it, the holster could pass for new. Unfortunately, it was definitely used by a policeman, and it has a musty smell that I'm guessing is patrol car. Almost like a musty gym locker, or a musty old book. The smell actually clings to the gun too. I tried "bathing" the holster overnight in cedar shavings and that helped some. But the cedar smells wears off fairly quickly, leaving the musty smell. Does anyone have any tips for actually exorcising the holster of this squad car funk? I'm especially sensitive to off smells, so it's a bit of a buzz kill. Thanks, DeWayne
  2. That's awesome! Every time I'd pull my phone out to answer a call, instead of saying, "Hello," I'd be tempted to say, "I'm your huckleberry ..."
  3. Thanks, Larry. I'm pretty paranoid about fully covering Glock triggers, since there's no external safety to activate on them. I want to make sure if I ever took a tumble in some brush or whatnot, no stick or limb is going to find its way into my trigger guard and come in contact with the trigger. Thus, the "bat wings."
  4. Hi folks, A year or more back, I posted on here about a pattern I'd created to make leather holsters for my two long-slide Glock pistols. They were thumb snap, cross-draw, which was something I just couldn't buy on the open market, so I had to "roll my own." Had a massive thick headache-inducing welt the same thickness as the Glock trigger guard. Recently, I have been shooting some of my single action revolvers and making holsters for them, but in a strong side, old-west style. And this got me to thinking that I'd like to be able to have one of my long-slide Glocks at "gunfighter" position for long hikes in the woods. Anyway, I adapted my sixgun holster pattern (pic for reference) and made the necessary adjustments to accommodate the Glocks, as well as their red-dot optics. Most importantly, I did away with my massive welt and just used a 1-ply welt, then bent the holster to create ears covering the trigger guard, as I typically seen done on leather Glock holsters. Saved a whole lot of work, for sure! I haven't found the need for any sort of retention strap, as the holsters were wet-molded to the guns and seem pretty secure. At any rate, if they ever loosen up to a point where retention is needed, I can pretty easily retro-fit a strap that would snap to the holster loop, which comes on and off via Chicago screws around back. Just posting these as they're kind of a novelty, but also, I had someone ask me for the pattern for my thumb snap version, so if anyone would like a copy of this pattern, I'm happy to provide—might save you some trial and error. Regards, DeWayne
  5. Larry, beautiful work! Thanks for the tips. I tend to shy away from Neatsfoot, as my holsters are wet formed, and I don't want to soften them and lose that form. Al, thanks too - I looked at Leather-n-rich and it appears to be carnauba based, so I'm guessing my Atom Wax does about the same thing.
  6. Hi folks. I've made several gun holsters, and always use Fiebings Pro Dye in either English Bridle or Black. I'm considering doing one in natural though ... but I'm not sure what that really means. If I was going to finish a holster and retain the natural, non-dyed color, would I do any finishing at all? Any thought? My usual finish is Leather Balm with Atom Wax, and on a holster that will see lots of weather, I will top-coat with diluted Mop&Glo for an acrylic layer. Think I could just do the same with a natural color holster? What about beeswax? I hear some dip leather holsters in melted beeswax, is this right? Thanks, DeWayne
  7. Just circling back, folks. I tried the contact cement route and it seemed to work fine. Just a few dabs on the lip of the interior (domed, slotless) female end, and a little on the leather, wait 15-min, and she tightens up nicely now. Don't expect to ever need to take those female ends off the leather loop they're glued to, so should be good to go. Thanks for helping me brainstorm this.
  8. That's a cool tool when there is clearance on both sides, but I could never get it in there between the flap and the holster without bending or scarring the leather. The flap is pressed down tight to the holster body. I'm thinking a thin rubber washer or, as I said, a spot of contact cement might be my strategy. I'll try the rubber washer tactic first and see how it does. Thanks, folks. DeWayne
  9. Thanks, folks. My leather is thick enough that the screw isn't bottoming out, it just can't grab firmly enough on the leather to really dig in and stop spinning. It tightens ok, just not as tight as I'd like. This is only exacerbated by the fact that when I attach the second one, I can no longer get my finger in there to hold it as there's no room. I think I may try a drop of contact cement on the lip of that female domed head. I suspect that's going to stop the spinning. Worst case scenario, the leather loop it's attaching to can be replaced easily enough if I ever have to. This was the first western style revolver holster I've made - all my holster making to this point has been thumb-break style for automatics. Being able to connect a loop in the back with Chicago Screws is such a pleasure - saves a ton of stitching for the belt loop.
  10. Folks, I have made a holster that has some Chicago Screws, and I can't figure a good way to tighten them when one side is domed/slotless. Finger pressure goes so far, but then the domed side just turns. Does anyone have a trick? Rubber washer, maybe? Contact cement in place of a washer on the domed side? Anything else? Thanks, DeWayne
  11. Is there anyway that I could get a copy of the pattern for the long slide Glock holster. That is absolutely perfect. I will happily pay you for it.
    1. DeWayne Hayes
      DeWayne Hayes
      Man, I'm sorry, haven't been around much and just saw this.  If you'll give me your mailing address, I'm happy to send you a copy of the pattern I made. Please e-mail me at dewayne.e.hayes@gmail.com as I may not check here often.
      Best,
      DeWayne
    2. badhatter1005
      badhatter1005
      5626 Creek Point Drive Hickory North Carolina 28601.    By way of Joshua Presnell. I do appreciate it very much.
  12. That is gorgeous work all the way around!
  13. Beautiful piece of work! That is one case where I'm not sure if you're wearing the holster, or the holster is wearing you, but either way - great looking piece!
  14. Brilliant work - I've been thinking about an apron, myself. Well done!
  15. Absolutely. I will split a canister over two or three projects until it's exhausted. Bear in mind, you use more dye this way, as a lot of it gets sprayed right past the edges of your project (as with any sprayed medium), so you'll see your dye jar going down faster than you might expect, as opposed to a dauber, where it all goes into the leather. But I freely move the Preval from one color to another. Give it a little blast to clear out the old color still in the tube, then carry on. Also bear in mind this one little trick - when you're screwing a Preval directly onto a Fiebings 4 oz jar of dye, you'll need to trim a tiny bit off the end of the Preval's plastic tube that extends down into the dye. They're made to go into a different reusable reservoir and are just a tiny bit too long for a Fiebings dye jar, but with a sharp knife or razor, if you trim it just a bit, you can screw the Preval unit right down onto the Fiebings jar and eliminate the need for a separate reservoir entirely. Very handy! BTW - I'm in an apartment too, and I just step outside in the parking lot and spray my piece quickly. You certainly don't want to spray that pro dye in the apartment!
