NerdyLeather
Everything posted by NerdyLeather
  1. I started small and avoided big loans, reinvesting early profits back into the business. At first, I sold locally and online, testing what worked. One beginner mistake was underpricing and not fully calculating expenses. A major breakthrough came when I began treating it like a real business -tracking costs, building supplier relationships, and focusing on branding and customer trust.
  2. Boxing gloves are a whole different beast compared to normal leather projects. The patterning, the curved seams, the padding placement, and the break in feel all take a lot of trial and error. Even experienced makers get intimidated by them. You might have better luck finding someone who has worked on motorcycle gloves or heavy sports gear. Those folks already understand layered padding and tight curves, so the jump isn’t as huge. With clear patterns and a training period like you mentioned, it’s doable, just not something most casual leatherworkers will touch.
  3. This looks like a solid project for someone who’s already comfortable with structured builds. Having the salpa mockup and full tech pack ready will make the prototype stage a lot smoother since the big decisions are already mapped out. If you haven’t yet, you might get good responses from small independent studios too. Plenty of makers who usually take on bag commissions enjoy doing one off prototypes, especially when the specs are clear and the communication is organized.
  4. These 246 clones can be surprisingly decent once you clean out the shipping oil and sort the timing. The casting looks pretty normal for this tier. I still lean toward lighter new models because they hold their settings better and you don’t end up fighting worn parts or mystery fixes from previous owners. When I wanted a clear reference point for how the originals are built, I bought from Lords Sewing and their Brother lineup made it a lot easier to understand what a proper spec should look like and what a clone needs to match.
  5. Some batches of pure neatsfoot can smell pretty rough, especially if it’s closer to the old style stuff that isn’t overly filtered. Cloudiness and thickening in cooler temps can happen too, since real neatsfoot isn’t always perfectly clear or stable like the more refined brands. That said, what you’re describing sounds stronger than normal. Most leatherworkers avoid anything with a heavy rancid odor because it usually means oxidation or mixed fats. I wouldn’t put it on good leather either. You probably didn’t get scammed on purpose, but it might be a low grade or poorly stored product. I’d stick with the brands you’ve had good results with and keep this one away from your projects.
  6. This sounds like a solid opportunity for someone who already does detailed tooling. The mix of fantasy and western styles is a fun range and having materials provided takes a lot of stress out of the setup. Shipping the pieces also makes it workable for people who aren’t anywhere near California. If you post a few examples of past projects here, you’ll probably get some interest. Leatherworkers like seeing the style expectations before reaching out.
  7. You might have luck checking with small upholstery shops or independent leatherworkers around Tacoma and Seattle. A lot of them have industrial machines and are used to patterning off existing items. Even if they can’t take on the full teaching part, many are open to doing the pattern and a sample build. Local makerspaces can also be a good lead. People there often know someone who does leather full time and is open to commission work plus walkthroughs.
  8. So you want a scanned to pdf file of all of the pages?
  9. Each sheet is 11x17 so 22x17 folded in half. That would be a difficult size to print or scan.
  10. Here are photos of every page of a 1940-1950's era US Navy Leathercraft Manual. It includes patterns, locations to purchase supplies, and much more. I tried to take the best photos I could, if you want a close up of something let me know and I will try to accommodate.
  11. Btw, I recently picked up a Coach tote from Coach Bags. It’s beautifully crafted with reinforced seams, and the design might give you some ideas for your project.
  12. For the gussets, stitching them on the inside can give the bag a cleaner look, but stitching on the outside might add more durability if you're carrying something heavy like your music binder. Using a flap at the bottom to reinforce the seam is a great idea, definitely smart to avoid an outer seam at the bottom where wear and tear are most likely.
  13. I just checked out your videos, really cool to see the stamping/tooling process in action! Regarding angles, maybe consider using a few different camera setups if possible, to give viewers multiple perspectives overhead, side, and maybe a close-up on the details. Adding music and subtitles is a great touch for engagement and clarity.
  14. Growing your channel can be really challenging, but it sounds like you're on the right track by reaching out and asking for feedback. Engagement is key, so keep interacting with your viewers both in the comments and outside YouTube if you can.
  15. I use postcards as well. on top, I made some stickers with my logo and I use them as well. I think it's a nice gesture that costs nearly nothing.
  16. Your concern about maintaining a clear brand image for your leather craft is valid, and it's not uncommon for artisans to face this dilemma when they have multiple types of products.
  17. If I have enough time I prepare an online catalogue that everyone can scan and look at prices. However, if I don't have time, I just use stickers.
  18. Just last month, a friend of mine casually mentioned to his co-worker that I do custom artwork. That co-worker turned out to be organizing an art event and ended up commissioning several pieces from me. So yeah, word of mouth can be gold. While word of mouth is timeless and powerful, I've found that in today's digital age, the reach and speed of social media is unparalleled. It's like word of mouth on steroids. Around 70% of my customers come from Instagram and Facebook. I use the adspy library, which shows the ad campaigns my rivals run. Instead of shooting in the dark, I see their strategies and adapt them for my campaigns. It’s like a window into their playbook.
  19. After tooling, I usually apply a resist like beeswax or a clear acrylic finish to the areas I want to keep lighter. Then, I'll dye the background. Once dried, I wipe off any excess dye and then oil the entire piece to give it that finished look. Just be careful not to use too much resist, or the dye won't take at all in those areas. Practice on scrap leather first to get the hang of it.
  20. Last week, I ordered the "YKK® #10 Separating Nylon Coil Zipper" from ZipperStop. Got a pretty good deal on them, too. The bulk price for 100 pieces was $516. Pro tip: if you sign up for their newsletter, they offer a 10% discount. I took advantage of it and ended up paying $464 for 100 pieces. Found it on DontPayFull. There are more deals and discounts that might be handy in saving up some money for your projects. Good luck!
  21. I'd suggest giving the tension discs a good clean with a soft brush or lint-free cloth. Sometimes a tiny bit of dish soap helps too. And yep, double-check the oiling spots. Maybe reduce the oil a tad if it's excessive.
  22. Looks great! I like the patterns you used. You inspired me for my next work.
  23. When I started selling my handmade jewelry, I was just as lost. Here's what I learned: Wholesale pricing and sales tax are two different things. Wholesale is about getting goods at a cheaper price because you're buying in bulk. Sales tax, on the other hand, is something you'll have to charge your customers if your state laws require it. If you're in the US, the sales tax laws can vary from state to state, so it's best to do some homework on this. Pricing items for profit was a challenge for me too. What helped was first figuring out the cost of materials and labor, then adding a markup for profit. It took some trial and error, but eventually, I found a sweet spot where my customers felt they were getting value for money, and I was making a decent profit. Running a business is a learning curve, and there's always something new to learn. I found that reading up on various topics and connecting with others who had been there was a big help. It's great that you're reaching out and asking these questions! When I was in your shoes, I realized that I was learning so much about the business that I decided to share my experiences in a blog. For a more in-depth look at these topics and more, you could visit here. It's packed with articles from my journey to building a few successful businesses.
  24. Fewer points of failure.
  25. I'm looking for a one piece leather wallet pattern. Hopefully something similar to Open Sea leather's wallets, but please let me know what you know of.
