Everything posted by Frodo
I am making my wife a clutch purse This is where i am so far.see images The color is mahogany stain and the gusset [?] piece is a mahogany leather what I am thinking of doing next I\a loop stitch with black 3/32 lacing leather.. installing 2 -3/4 [to wide or not wide enough?] straps in the front that will wrap down,undr then up the back for shoulder straps best way to attach the straps? rivets? same with a buckle any corrections or suggestions before i proceed
I have an idea, wanna kick it around and see if we can figure it out? a pvc pipe, open back bangle, covered in leather with a strap to hold a watch.
Please help. Where can I purchase a crimping brake for leather?
Frodo replied to Jaypei's topic in Leather Machinery
http://dimlights.com/2008/10/tools-of-the-trade-crimp-break/ -
my thread broke, i noticed it was frayed then pop. So, instead of cutting all my work out, I stitched over the broken thread with the other thread, then went into the same hole downstream of the break i very carefully, coated that thread with glue will his fix work?
Thank you !!!!!!!!!!! I solved the Problem Thanks to you guys help I took it apart, cut a 1/4'' off each side then glued it on the ends, stitched the ends worked to the middle finally. I set an anvil on it over night.
I carry this in my wallet..When I am feeling crapped on or disappointed i read it to get re-centered As my wife puts it, to get her chi back
First Leather Work Attempt - Motorbike Side Bag
Frodo replied to AusSimon's topic in Motorcycles and Biker Gear
Does anyone know where I can get a 2nd Amendment stamp? Or, Does anyone know what I would cost to have one made? It can be a single stamp, or 4 separate stamps [each line] Looking to use it to stamp on wallets, so I guess the size would be 3x3 or 3x2. in reality, what ever works out the best/easiest.
Wizcrafts Thank you for the education. i did not even consider the foot and its movement. I was only thinking about mounting a large treadmill DC motor and powering thru. Northmount Picture you requested
thank you for the warm welcome.
If the spent cartridge came into your possession ALREADY cut, then it is not a spent cartridge it is just scrap brass Or so i am thinking.
You have a wonderful name, and you spell it correctly also. The ""Y" is for sissies. LOL the cord is gutted to reduce bulkyness [[SP} HEY. I have no IDEA what i am doing so i am not in a box, and I can not find the box. I just do what my strange brain says to do Brian
I will get a picture. this Brother says made in the republic of Ireland
I use 22lr as decoration buttons on a belt and wrist band. I use plexe glass to hold the bullet while cutting, and s a height/debth gauge [can be adjusted by adding strips of leather or what ever ] I made a set tool using a brass 5/16 brass acorn nut, just jamb nut it on a rod, insert rod in a drill and let a file do its job For safety concerns, use USED bullet cases, You can see my brass is NOT used, and the primer will go off if you hit it wrong, scared the cat and the dog my wife rolled her eyes....primer going off is just loud,nothing fling around.
I have another vintage machine, it is a brother, I have tried to find the model number all I find is numbers stamped under the machine in the metal H139205 i went to brother.com. and can not ask a question with out giving the model number. It is in a wood box, heavy as hell, pink and cream colored [electric]
I can do that, i have image skills. lol A simple belt clip wth a piece of leather under it, prevents pants from snagging I clip it on my front pocket not my belt the shackle is for key chain
1924 foot pedal singer called ''the RED EYE'' will it sew leather? is so how thick? what type of needle am i looking for i
