Content Count
212 -
Posts posted by Tequila
I wrote to Buckle Guy and this was the answer that they sent:
Thanks for reaching out. The leather itself would be great for wet molding, but that would be a pretty thin weight. We would recommend either going with a thicker option, or at the least, adding a second layer of that leather.
I’m leaning with @Heartless (at least for the first couple) since it’s a new mold and I want to take some of the variables out.
I’ve got a mold that I’ll be using and plan on using 2-3 ounce leather precut panels. I’m looking at some panels here on Buckleguy Has anyone tried using Vachetta leather in a wet mold? If so was it able to hold it’s shape?
thanks
I’ll just add this reminder, keep the angle low. When I first started I was sharpening at too steep of an angle, then I found a little trick. If you can find a book of matches, the angle of the matchbook (closed) is about the angle your blade should be to the stone/sandpaper/strop. Lotsa luck!
Does anyone have any experience with Leather Craft Pattern? They are out of Hong Kong and sell on the internet.
@LiftPig it’s too bad that you had all those problems, but on the bright side you now know that machine well and if something ever comes up again you’ll be confident you can fix it. Thanks for the videos and keeping us up to date.
On 5/21/2023 at 2:25 PM, fredk said:Well, I have a sort-of beader. It works
I made the working end at a slight angle. I thought it would be easier to work
Total width across is about 6.5mm (1/4 inch), with the bead about 4mm
The test leather is only 2.1mm (5 oz ?) thick. The beader needs running to and back, going deeper on each run. I went as deep as I could on my test piece but I reckon I would get a better rounded bead on thicker leather
I might try to make a smaller sized beader
I like it, nice rounded top, that’s what I’m after.
20 hours ago, chuck123wapati said:i made one today thought i would share. Found a long shank bolt with the right size shank to fit the knife. Cut to length, squared the hex with a sander. cut the round first , then narrowed the square to what i figured i wanted and filed in the outside bevel. Took about 30 minutes.
I would suggest stainless bolts if you can find them but its not a problem to use regular bolts.
Your creativity and inventiveness never cease to amaze me.
3 hours ago, fredk said:Simples. If I have the time I'll make a nylon one over the weekend and see how it works
Let me know how it works!
Let me start off by saying that I’m not that great, only a hobbier and only make things for myself or to give away. I haven’t been able to do any leather work for almost a year and thought I’d get back into it slowly by making some coasters. My thought is to have a bead around the edge. In the past when I tried to get that look I would cut a line with a swivel knife and then hand stamp using a beveler. It not only took time but I never really got the look that I was trying for. I saw that Barry King sells beader blades for a swivel knife, has anyone tried them? If you don’t use that what do you use? I saw that sometimes Bruce Johnson has a push beader in stock, would it be better for me to wait till he has one again?
Thanks for the insight
I’m with kgg on this. Maybe these manuals will be of some help
1 hour ago, Handstitched said:The major spill I did was a 500ml tin of contact adhesive...all over my right leg . So I don't what would be worse, dye or adhesive ?
HS
I guess that would depend on how hairy your leg was
Frodo, Frodo, Frodo are you OK?
Maybe this would be a good time to remind her that you need a shop so that never happens again.
@Bullduke the customer service is exactly what I bought a 26 from them a couple of years ago. I had a problem with mine (no where near as bad as yours) that was self induced. But when I called up LMC they took the time to walk me through the repair and even sent pictures of the parts I needed to adjust. I’m glad to hear that they were so helpful. I for one would love to know what they found with the machines when they got them back. Now that you’re moving to a Class 4 you might want to get with some of the members about a part that RockyAussie sells for the 4 that expands the sewing capabilities.
I got this advice when I was looking for my first machine and it’s proven to be oh so true, you can turn a cylinder machine into a flatbed, but you can’t turn a flatbed into a cylinder. For leather the cylinder works great, but when I have the odd upholstery work I add the table attachment.
@Wizcrafts I wish there was a “Like” button for your posts. BTW I’m having fun but it’s only temporary
Who would use an app like that? If you’re a customer you’d need to have the leather in front of you and I’d think I’d rely on my eyes and hands to find a defect. The online retailers would post pictures if they wanted to show a defect. And tanneries would reject a badly damaged hide and their master tanners know what is acceptable and what is not. Your heart is in the right place, I just don’t see a practical application for this.
20 hours ago, RockyAussie said:I would be happy to do that for you. Show me the type of product you want to do and any ideas of the pouch design and I will do my best.
PM sent
Looks like another successful job Rocky! Would you be interested in making a couple of molds for me? Similar to that one but probably a little simpler to the one you showed in the video.
WOW, JUST WOWW
1 hour ago, chuck123wapati said:it looks like a primer pocket cleaner for reloading ammunition.
I agree, one for small the other for large primers.
25 minutes ago, AndrewWR said:All Hand sewn, @PastorBob. I don't have sewing machine can't justify the cost or space as a hobbyist. If I was running a business, it'd be different but I think I still prefer the netness and quality of hand sewn leather.
Which brings me to @Tequila 's question:
Tequila, I don't think what I did here can be done with a machine (But I'm willing to be corrected on that). Because it's hand sewn, I punch all the holes first and each stitch pulls them into alignment close to the inner radius. I wet the middle of the edging strip with a cotton bud so the leather is more inclined to stretch around the outer radius. This stretch is only a fraction of a millimeter at a time, since the stitches are 4mm spacing. As I understand it, machine sewing doesn't allow this progressive tension so the outer radius is unstretched and the inner radius puckers under compression.
This is time consuming work but I happen to think it's worth it.
I don’t have as much patience as you, so a tip of the hat to you for that long tedious work, and your right the outcome was worth the effort. Thanks for sharing your knowledge and technique with everyone.
@AndrewWR beautiful looking case, I like the handle detail. Got a question how did you get the edge to lay flat on the curves, when I try to do it the edge material puckers.
40 minutes ago, Stewart said:Be glad to point you to some software to design your scenes to incorparate in the coasters shapes your using.
I’d like to know about the software too.
Wet Molding Vachetta Leather
in How Do I Do That?
Posted · Report reply
Thanks, for what I’m doing getting a dyed through high end leather would greatly improve it’s appeal.
