FDC
Everything posted by FDC
I have a "thing" for these old Landis machines. Now I need a 16... I like the safety sandals, they say "This will work out perfectly..." and it sure looks like it did! Nice machine and space!
A beautiful holster for a great side arm!
Hand sewing is another level for sure! I bought it from Tandy, 4 oz "Crazy Horse". It’s interesting and nice to work with. The vinyl lining gives it some body when the bag is done.
After finishing a Singer post bed restoration I wanted to make a Dopp kit bag. I bumbled around on-line and took ideas from a few places but took the time to make my own pattern. First attempt never saw the light of day, second attempt suggested a partially glued in lining instead of floating fabric. So this one has a marine vinyl interior to make cleaning up my exploded toothpaste/shampoo/ shaving cream mishaps easier. Naturally I sewed the loop in upside down with the raw edge up...4.0 required!
I'm not sure what you mean by motor pulley, are you referring to the pulley on the servo motor? If so its stock, 45 or 50 mm I think.
Those are called "levelling casters" and I bought them from an outfit in Chicago many years ago. They come in several sizes, always go as big as you can is my advice. I just checked and Amazon carries them so they are a day away if your use Amazon!
I shim my Landis 5 in 1 skiving blade to split leather up to 1.5" wide. I have machined a top feed wheel with no knurling to eliminate marking on the leather. Works perfectly.
Singer 51w55 trouble making the feed dogs walk
FDC replied to Lu.mi.sewing's topic in Leather Sewing Machines
If the 51W55 is similar to my 51W56 you need to be sure that the stitch length adjuster pin at the fly wheel is properly engaged in the drive shaft "thread". The adjuster needs to move in and out. If the flywheel isn't set far enough on the drive shaft (towards the needle) it can prevent proper engagement. The pin in the selector may also be broken or missing... Also there are two rods at the bottom of the machine, I believe that the one towards the rear of the machine controls the stitch length actuation. -
I like Hazet screw drivers, especially their slot screw drivers. Made in Germany, not cheap but the best I've come across. Proper profiles, not cheap grinding.
Acknowledged and all true however I had chosen to make a small table and space for a reducer pulley under the top was not really an option. I also tried to get this 51W56 off the ground for as little scratch as possible and that was easiest with aluminum that I had in stock. I slowed down my skiiver as you suggested and I like the results!
Thanks! I did try to think this one through, except for the amount of time it would take...
I have finished my speed reducer pulley for my 51W56. It slips on over the stock flywheel and is fixed there by set screws which fit into the stock flywheels set screw holes. My serve drive to 51W driven ratio is 2.07 to 1 now. It requires 4 1/2" 6061 rod to make.
I was lucky to find this old post bed Singer locally. I have wanted a post bed for up coming boot projects but didn't really want to blow new machine money. Total tear down, fabricated the table and went with a servo motor drive. I will machine up a slip on driven pulley to further slow it down. Thrilled for find a spot in FLA that sold water decals for it. I machined a new needle jbar that will take 135 needles to get me to #20 thread. I enjoy getting to understand these old mechanisms and give respect to the geniuses that created them so long ago.
Hi James, We are on a similar adventure as I'm almost finished restoring a 51W56 Singer post bed! The machine has been torn down, repainted and put back together and the table and stand are made. I am going with a servo motor as well. This machine handles DB x 1 needles which go up to 110/18 and have a 1.63 mm shank. I have machined a custom needle bar for my machine that will take 135 system needles and get me up to 125/20 using a 2.00 mm shank. I too want to use this machine to make my own footwear! Singer 51W56 Parts Manual Condensed.pdf 51W Manual.pdf
help from the masters..... Is the machine fixable?
FDC replied to MattiJoy2's topic in Leather Sewing Machines
I've repaired cracked and broken cast iron and it's not magic. If this machine ran as is I would consider it. I'd have recommended TIG welding with cast rod - your BF would have no problem with that. I've taken a flier on three rough leather machines and while each one required pretty serious time to restore them they all work as new. But if actual leather working is your thing, machine restoration isn't leatherworking! Chris -
Can one person transport a Landis Rapid E?
FDC replied to LMullins's topic in Leather Sewing Machines
I moved a Landis Model 12 F and it requires some finess and a trailer unless you're commiting to dismantling it, even then there's some heavy luifting for one. It's top heavy to boot. Lean on a friend or two to help and make sure that you have a robust cart. Nice find! -
Thanks so much Hans! The 51W56 is back together and working well. I have my belt specs and may just attempt to make a cleated belt when I have a bit of apre time, I have the shop to do it and another member here showed us how to do it so... Thanks for tyour time and expertise!
Just finished restoring a Singer 51W56. I used wool yarn, I had it, it works and it'll last forever. Cost - $0.00.
Thanks for the poke tigweldor! Belt length: 38.75" Tooth count: 62 Tooth spacing: 5/8" Tooth width/belt width: 0.665" (not critical, blallpark will do it!) Tooth length: 0.2325" Tooth depth (metal cleat divided by 2 is 0.08375" but pulley would allow up to 0.125" I greatly appreciate your help! Let me know if there's anything else you need! Chris
If you're in Europe the European Steamed Beech may be more available than maple, it would work just as well.
Hi guys, I have the belt specs at my shop and will get them for you tomorrow, ghe help is appreciated! Are your machines collecting dust Bob or are you using alternative belts? Chris
Hi All! I'm hoping that someone might be able to steer me in the right direction regarding a 62 tooth metal cleared timing belt for a Singer 51W56. The Singer part number is 234003. I am interested in the OEM style belt OR a modern alternative and source please. Any help would be greatly appreciated. Chris
Simple maybe, beautiful definitely! Your diamond treatment is slick!
There seem to be any size that you want in my browsing experience. Price depends on the blade spec but less than $6.00 USD for my 50 mm diameter blades and they're 1 mm thick. Sorry for the delay in responding, I'm not sure that I received a notification...
Happy 2025 Tastech! Yes I've sorted this machine out to my liking! Proper thread, thread lube and new awl and needle with a bit of fiddling. I'll never get tired of this machine, it is an industrial work of art so to speak. I have yet to make my first pair of boots but I am picking away at that as well. Too many projects, too lazy at times... Last summer I bought a Landis 5 in 1 to compliment this Model 12 F. It needed a casting repair and a restoration as well and it now looks great. I figured out how to sharpen the stock cutter but imagined a cutter set up using replaceable circular cutters so I machined a new drive shaft and after a couple of attempts have an outboard cutter that can be changed out for a fresh sharp on in seconds. Worth the trouble? Maybe not but it scratched an itch for me! I would love to see some of your footwear if you didn't mind posting some pics!
