  • CFM
16 minutes ago, Leescustomleather said:
I was only offering his video as a method that helped me and might help others. Perhaps posting a video of your method would help even more.
your  video rocks!!! i finally found it. i think it works on the same logic, its adds some room for the leather to flex instead of compressing against the blade. I'm an old guy with flip phone so I don't do videos lol. maybe i can get my son to help me out. you know i was just thinking if a guy were o cut a piece of 4" pvc in half and slide it  under his leather so he was cutting on top of a convex surface it would work pretty good for long straight cuts, i'm gonna try it .
  • Replies 25
  • Created
  • Last Reply
Top Posters In This Topic
 Good Idea! Please let me know how that works out!
On 8/24/2022 at 3:18 PM, Leescustomleather said:
There is a youtube channel called Hank strange and a video called "Carjacker holster" The man that does the leatherwork is named Andrews and he has a unique method to cut thick leather easily, making tight corners cleanly and accurately. I have never seen this done elsewhere and this is the method I use all the time now
Yes I've seen him cut thick leather and he makes it look so easy. years of practice I bet. I tried its still hard to do.
Direct answer to the original question: There is not one easiest way, it depends on what you want to cut in which shape.
Sam Andrew's method in the above-mentioned video is rather similar to Jo's from JH Leather. Except she uses a headknife, holds the point against the table and pulls the leather against the knife. The method needs a very sharp knife and a rather stiff, thick leather.
For thin leather I either work with a ruler, or I rock the head knife (for lack of a rotary cutter), or I might even use scissors.
As for long(ish) straps, I love my strap cutter!
I use a head knife for most cutting it's always what I call crazy sharp it's the height of the knife that shows vertical position the red cut boards for clickers work best for me and are worth the investment. Sharpening maintaining a "properly" sharpened blade should take seconds not even minutes a blade is not sharp until  stropped.
Sharp Blades   VSB   very sharp blades! makes cutting easy.
I've recently taken to using this hook blade in my Stanley knife.
I find it is great for rough-out cutting of pattern pieces from a large hide, to get more manageable sized pieces for proper trimming
Frodo brought our attention to them back in April
