  • CFM
Come pick it up, it’s free the man said
looks like night mare
Edited by Northmount
Replaced web files with jpegs
Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles
D.C.F.M
I'd say tough love, but it maybe a gem in the rough. A good winter's project as it is a walking foot machine.
kgg
I really don't think it looks that bad.
There is a lot of dust n it, but that can be cleaned away with a bit of soap and water and then a light oiling will help.
It looks like it has been stored in a dry place, so there is just a bit of rust on the cast parts below the table, but as long as the mechanics haven't been subjected to water it'll be good.
In short, a great find! looking forward to see the progress.
brgds Jonas
My 'ye olde pooter' won't open those files. Bugger :wacko:
' I have a very gweat friend in Wome called Biggus Dickus,
He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '  :rofl:
  • CFM
get it!!!!
  • 1 month later...
  • CFM
Update
Road trip yesterday  and we picked up the Rex. The machine was froze upthpe whelk would move about a 1/4”
Brought it home and poured penetrating oil all over it. Then removed the needle bar cover
the needle bar seems to be bent like something dropped on the machine.
I disconnected the needle bar and the machine will make  revolutions
so, question is how am I going to remove that needle bar?   Bent at the top
I am thinking about cutting it in half and going that route.
Suggestions?
D.C.F.M
Is there enough sticking out to put a sleeve or socket over it and unbend?   On my Singer, the needle bar runs inside a sleeve and the sleeve is held in place with a set-screw. If yours was the same, I might remove the set screw and tap the needle bar out sleeve and all.
I'm thinking you're going to have to replace the bar so nipping it in two to get it out is probably not a bad idea.
  • CFM
Got it out,  I am not a sewing machine technician by ANY means.
This was hard. Tried oiling and penetrating oil over nite nope
Tried heat, NOPE
Drilled out some angle iron, drilled holes and inserted all thread. Tightened the nut and push the bar up NOPE
so I cut it in 3 pieces, chamfered the middle piece and used it as a drift pin to drive the top piec out
HURRAY !!!   It is out
F8F59515-EC6C-43B3-AC76-49C4E37DD6B7.jpeg.b321f5ea035962264a0414d084160b05.jpeg62FE15B8-5FD5-4520-8352-6DB1101D8F61.jpeg.4105dfdccdc2578720ff5d75e1db7629.jpegE6279F94-57A7-4AA3-AE7C-BD367053881D.jpeg.c8e13f77cbec68ddde8e95e2010605e2.jpeg35F434C2-E6C7-418F-BC5C-89AFBE6CE5CE.jpeg.d663a0a53332a4a60a6ce72951f000e8.jpeg
D.C.F.M
The Rex has a pretty good reputation.  I bought a 1951 pfaff 131 boat anchor. Dang that thing is heavy. The stitch adjustment was locked up. Used penetrating oil and heat. Worked for me, too bad you were not so lucky.
Not so retired RN. Living on the Washington Peninsula.
Can you get a replacement needle bar easy enough?
