Members doubleh Posted December 19, 2022 Members Report Posted December 19, 2022 (edited) I do my work on an old oak desk I rescued from a junk shop and restored and it is in my garage. I have one of the swivel desk lamps mounted on one side and and a small reading light on other plus one of the super bright harbor Freight LED shop lights hung from the ceiling just behind me. With all that light I still have trouble with my stamp holding hand casting a shadow on what I am doing. I researched LED headlamp recently and finally decided on one by Energizer available at Walmart for 10 bucks. It is simple in that it only has two brightness levels to deal with and I have found the lower setting to provide the right amount of light to suit me. The higher setting is too bright. I just used it to border stamp a holster and it worked perfectly. It is light and comfortable to wear also. It was a cheap fix. Edited December 19, 2022 by doubleh Quote
CFM chuck123wapati Posted December 19, 2022 CFM Report Posted December 19, 2022 i have a set, they are Awesome, and a set of magnifiers for my head too i feel like a mummy lol. I'm gonna try a set o these i think . https://www.amazon.com/Magnifying-Glasses-Vision-Enhancing-Magnifcation/dp/B09X791TR6/ref=asc_df_B09X791TR6?tag=bngsmtphsnus-20&linkCode=df0&hvadid=80195746823013&hvnetw=s&hvqmt=e&hvbmt=be&hvdev=c&hvlocint=&hvlocphy=&hvtargid=pla-4583795280151321&psc=1 Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
MikeRock Posted December 19, 2022 Report Posted December 19, 2022 The Optivisor folks sell a light frame that goes right on over the lens set. Battery and switch on side of visor, works great. https://www.penntoolco.com/quasar-led-lighting-system-for-optivisor-qsl-6010/?msclkid=00cfc8e8887a1748b000ab484cc115ab&utm_source=bing&utm_medium=cpc&utm_campaign=**LP Shopping (1.1) - <%2450&utm_term=4575686358867949&utm_content=166342 | Quasar LED Lighting System for Optivisor - QSL-6010 | %2429.95#mz-expanded-view-419269663073 Quote
Members TonyV Posted December 19, 2022 Members Report Posted December 19, 2022 That bright led light behind you is likely casting the most shadow. Try turning it off and using the 2 desk lamps, perhaps adding another or repositioning the led so it's not shadowing your body. Quote
Members doubleh Posted December 20, 2022 Author Members Report Posted December 20, 2022 Rest assured that it is my hand making the shadow. I have no shadow until my hand with the stamp is in position on the leather. I added the overhead light trying to eliminate the shadow and did a lot of experimentation before going to the headlamp. The only other thing that worked was a light on a pole shining directly over my shoulder which I bumped out of place every time I moved to reach for something or knocked over when I forgot it was there and swiveled my chair to get up. I use a simple pair of 2x frameless reading glasses for close work now. I have an optivisor that has been unused since I had my cataracts removed. The glasses and LED light combined are so light weight I barely notice I have anything on. I also play around at being a machinest or woodworker when not fiddling with leathercraft and this combo is going to work well with both of those. Quote
rktaylor Posted December 24, 2022 Report Posted December 24, 2022 I never cared much for the headlamps, so I went this route. Just an adjustable LED lamp. I can shine it right where I'm tooling. I may revisit a headlamp sometime, but for now, this works great. Randy Quote
Members Sheilajeanne Posted December 24, 2022 Members Report Posted December 24, 2022 (edited) I have something similar, rktaylor, but it's on its own base, and the bulb is halogen rather than LED. One of these days I should upgrade to LED as the halogen bulb is very hot and no doubt burns a lot of electricity. I have considered a headband, too, due to the problem with the shadows created by my own hand, but haven't gone that route yet. I also have a 3 ft long LED fixture attached to the shelf just above my work area, which gives a lovely bright light. Those new LED fixtures that have replaced fluorescent tubes are great! Highly recommend them. Edited December 24, 2022 by Sheilajeanne Quote
Contributing Member fredk Posted December 24, 2022 Contributing Member Report Posted December 24, 2022 (edited) I have numerous lamps to light my work area Have any of youse considered using a small cheap head-lamp, on an elastic strap, and wearing it on your wrist? This sort, wear the strap around your wrist and manoeuvre the wee light into the palm of your hand. It puts light just where you want it. You can get these for just a couple of $$ in most discount stores. I have several of them laying about. Wear them on yourself to point where the light is needed, or strap them to an object for the same purpose Edited December 24, 2022 by fredk Quote Al speling misteaks aer all mi own werk..
