So I did a rolled edge, inspired by Sporran designs.  However, the edge of the front piece shows on the inside of the bag, and is not very attractive.  If you have used multiple layers, as I have (lining leather, foam, stabilizer, Bontex, front leather/fur, etc) it can be quite ugly.  Can someone tell me what I am doing wrong that allows that edge to show, or does it normally show on things like Sporrans?  (I've never actually seen one, only photos, and no one seems to post images of the inside of these things, even those selling them).  Thank you!
YinTx
  • CFM
Here is a shot of my sporran. Not high end but it looks just like yours.
Maybe a dark marksalot and the point of a edging beveler/burnisher? I ran an ad on next-door for a wood turner.  I got a response,  and for a contribution to a local charity I got a burnisher turned with a point on it. This is great for those inside spots that need a bit of burnishing.
Edited by Hags
Spelling
Not so retired RN. Living on the Washington Peninsula.
I would maybe cut it a little shorter but it looks nice.
I would be doing a binder edge either fabric tape or leather if you prefer. I am not sure but you may have come in a little too far from the edge when connecting the gusset to the front section. 1/8" in would be my guess would work best which I think would make the gusset area not stick out so much. NOT to bad overall though..
YouTube Channel
Instagram
Expand
I think this would be the answer, but everything is hand stitched and I haven't done binders so well when hand stitching.  My impressions looking at Sporrans was that they had an unusually large rolled section, so I did intentionally make it large.  I agree with your assessment, and will make the next one with a skinnier roll.  Also I think making the top more vertical instead of rounded inwards will make the edge show less, since the roll does not hug the front piece.
Expand
Thank you for that image, something I wanted to see but was not able to.  Can see that the top is more vertical, keeping that edge from showing as much.  Are those tassels just pulled through a slot and riveted at the upper edge of the front?  How soft is the gusset?  I made mine from 2-3oz veg tan belly, so it is slightly firm.  I'm thinking it needs to be dry milled veg or bag leather tho, which doesn't lend itself well to a burnished edge at the attachment to the back piece.  Mine is only partially lined, as in the front piece is lined only.  Is this standard, or do most of them have linings?  I'm not really making a Sporran, just something largely inspired by one, but I want to understand how they are really put together.
Expand
I could edge paint before adding the rolled gusset edge as an option.
Expand
If by "it" you are referring the the width of the rolled edge, I agree, I will make the next prototype a bit skinnier.
  On 1/1/2023 at 8:03 AM, Tugadude said:
Why not roll it over onto the gusset too?
Expand
I am a bit confused by this, as the rolled edge is the gusset...
I really appreciate everyone's suggestions, I was really frustrated after I finished this prototype, as I felt it was un-useable/unpresentable as it came out, and didn't want the next version to follow suit.
YinTx
  • CFM
to me it looks angled(cut at an angle) so you see more of the cut edge could you simply angle it the other way or cut it straight so it doesn't show as bad from the top
  • CFM
or maybe skive it down to nothing and fold it in or glue it together.
  • CFM
Expand
After dinner I will post more pics. It is an inexpensive one that a friend bought to replace the one I lost in the fire.
