Members Gosut Posted February 11, 2023 Members Report Posted February 11, 2023 Made templates this morning for belt ends and another checkbook cover pattern. My first attempt was to draw it directly on the back of poster board, then cut out. That project design proved unworkable, so never used it. These I first drew in LibreCAD, then printed. But how to make templates? First idea, one I intended to use for a knife sheath pattern, was to trace it on the poster board using carbon paper. Then decided to cut around the pattern, glue it to the back of the poster board with a rub-on glue stick, then cut out. This worked well. I went with oval belt holes, and the first two are passable, but the rest look good. I used a hole punch (3mm) for the rounded ends and cut between them. Used the same method on the belt buckle slot, except bumped it up to a 5mm punch. Worried about the half-circle end of the buckle end and the English point on the other, but went at it slowly with an small craft knife that was a gift some years ago. Also used the craft knife for the belt holes and buckle slot. The rest I used a utility knife. Used the craft knife for the rounded corners of the checkbook cover. Being a newbie, I looked at cutting out the template as practice for cutting the leather later. Is this a standard way of making templates? If I was going to do a lot of belts and checkbook covers, I might have sprung for that plastic film used to make templates, Being this would see little use, thought poster board would be okay. Quote
CFM chuck123wapati Posted February 11, 2023 CFM Report Posted February 11, 2023 1 hour ago, Gosut said: Made templates this morning for belt ends and another checkbook cover pattern. My first attempt was to draw it directly on the back of poster board, then cut out. That project design proved unworkable, so never used it. These I first drew in LibreCAD, then printed. But how to make templates? First idea, one I intended to use for a knife sheath pattern, was to trace it on the poster board using carbon paper. Then decided to cut around the pattern, glue it to the back of the poster board with a rub-on glue stick, then cut out. This worked well. I went with oval belt holes, and the first two are passable, but the rest look good. I used a hole punch (3mm) for the rounded ends and cut between them. Used the same method on the belt buckle slot, except bumped it up to a 5mm punch. Worried about the half-circle end of the buckle end and the English point on the other, but went at it slowly with an small craft knife that was a gift some years ago. Also used the craft knife for the belt holes and buckle slot. The rest I used a utility knife. Used the craft knife for the rounded corners of the checkbook cover. Being a newbie, I looked at cutting out the template as practice for cutting the leather later. Is this a standard way of making templates? If I was going to do a lot of belts and checkbook covers, I might have sprung for that plastic film used to make templates, Being this would see little use, thought poster board would be okay. pretty much how i do it. i use cardboard templates. I trace around them onto the leather with a pencil so they last for years plus I trace one pristine out for my files and also scan them so i can print them out on plain paper if needed for drawing my tooling designs on. i get my card stock from old Christmas clothes boxes they are pretty and free too lol. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
CFM Frodo Posted February 11, 2023 CFM Report Posted February 11, 2023 Cracker boxes cereal boxes i love the plastic 3 ring binders old file’s Or you can buy bontex it is a bag stiffner 48x48 sheet 20 bucks Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
Members Hags Posted February 12, 2023 Members Report Posted February 12, 2023 Manila file folders or cardstock for smaller things, the hard craft paper that separates the toilet paper at Costco for larger stuff. Quote Not so retired RN. Living on the Washington Peninsula.
Members Charley1 Posted February 12, 2023 Members Report Posted February 12, 2023 Make my holster patterns from card stock, wanting the flexibility to insure fit. Then I trace to pattern onto sheet plastic and cut it out with an Exacto knife to make a long term template. Most available and least expensive sheet plastic I've found is used for the cheap "for sale" or "for rent" signs found at big box hardware stores or Target/Walmart. Quote
Members Littlef Posted February 12, 2023 Members Report Posted February 12, 2023 14 minutes ago, Charley1 said: Make my holster patterns from card stock, wanting the flexibility to insure fit. Then I trace to pattern onto sheet plastic and cut it out with an Exacto knife to make a long term template. Most available and least expensive sheet plastic I've found is used for the cheap "for sale" or "for rent" signs found at big box hardware stores or Target/Walmart. aaa... the for sale/rent sign is a good idea. I've been drawing on printer paper or graph paper, and then then gluing it to a posterboard to give it rigidity. The plastic sign idea is nice, and would be more durable than posterboard. Thanks for a good idea. Quote Regards, Littlef Littlef - YouTube
Members Littlef Posted February 12, 2023 Members Report Posted February 12, 2023 (edited) 8 hours ago, Gosut said: Made templates this morning for belt ends and another checkbook cover pattern. My first attempt was to draw it directly on the back of poster board, then cut out. That project design proved unworkable, so never used it. These I first drew in LibreCAD, then printed. But how to make templates? First idea, one I intended to use for a knife sheath pattern, was to trace it on the poster board using carbon paper. Then decided to cut around the pattern, glue it to the back of the poster board with a rub-on glue stick, then cut out. This worked well. I went with oval belt holes, and the first two are passable, but the rest look good. I used a hole punch (3mm) for the rounded ends and cut between them. Used the same method on the belt buckle slot, except bumped it up to a 5mm punch. Worried about the half-circle end of the buckle end and the English point on the other, but went at it slowly with an small craft knife that was a gift some years ago. Also used the craft knife for the belt holes and buckle slot. The rest I used a utility knife. Used the craft knife for the rounded corners of the checkbook cover. Being a newbie, I looked at cutting out the template as practice for cutting the leather later. Is this a standard way of making templates? If I was going to do a lot of belts and checkbook covers, I might have sprung for that plastic film used to make templates, Being this would see little use, thought poster board would be okay. A couple suggestions, from another newbie. I would recommend gluing the whole sheet to the posterboard first - or at least only the major parts roughly cut out. Glue it, let it dry, and then cut it out, when its dry as one piece. Use your hole punches to cut clean holes. If you don't have oblong punches to cut slots... use a hole punch on each end of the slot.... then use your knife to make the straight cuts to form a slot between the two holes. Edited February 12, 2023 by Littlef Quote Regards, Littlef Littlef - YouTube
Members TinBadgeLeather Posted February 20, 2023 Members Report Posted February 20, 2023 Hobby Lobby has a 10 pack of the poster board for less than 3 bucks. I fold them in half and spray 3m 77 spray adhesive to make hem double thickness. I then take the paper pattern., spray them with the 77 and attach them to the double thickness board. Cut them out and you a cheap, long lasting pattern. I’ve used some of these for 10 years or more and they’re still holding up. Quote
CFM Frodo Posted March 3, 2023 CFM Report Posted March 3, 2023 Dollar General and Dollar Tree have vinyl place mats for $1.25 Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
Contributing Member JLSleather Posted March 4, 2023 Contributing Member Report Posted March 4, 2023 card stock. Gitcha some 80lb or so. Available everywhre, basically. Print right on your home printer. Cut out, and done. Pattern gits worn out.. print another one. For belts, I just have patterns of the width and the tip end. The "holes" are just poked with a stylus or pencil... then poke the leather same way through the holes for punch position. Great for holsters, too. Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Members BlackDragon Posted March 4, 2023 Members Report Posted March 4, 2023 I'm using chipboard for making hardcover books. What I'm using is about 1.8mm but it comes in various thicknesses and sizes. Its a good stiffness and doesn't lift up as I'm trying to mark the leather. I draw a pattern on a piece of paper then use an Elmers glue stick to attach it to the chipboard. Quote
Doc Reaper Posted March 8, 2023 Report Posted March 8, 2023 T-shirt cardboard, but it’s not something you can stock up on. I went to hobby lobby and purchased the large poster board pad they had. I like cereal boxes but I have also used paper and duct tape to make a few patterns Quote Doc Reaper
Members dikman Posted March 8, 2023 Members Report Posted March 8, 2023 Manilla folders, cereal boxes, whatever I can find that's free. It all works, Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Littlef Posted March 9, 2023 Members Report Posted March 9, 2023 7 hours ago, Doc Reaper said: T-shirt cardboard, but it’s not something you can stock up on. I went to hobby lobby and purchased the large poster board pad they had. I like cereal boxes but I have also used paper and duct tape to make a few patterns I use poster board as well. Another Thing I use is craft foam. Not to make a template, but it makes a good analog for leather to prototype gun holsters, mag holsters, ammo pouches, or whatever else. Quote Regards, Littlef Littlef - YouTube
Members BLURDWORX Posted March 27, 2024 Members Report Posted March 27, 2024 I use TRACING PAPER first. its cheap and easy to cut, and best it lets you see all levels of the potential pattern. after you have it JUST RIGHT then I transfer it to chip board or another stiff (not thick) cardboard. This technique has served me well for years making one-off items. Best part is both materials are cheap and come in LARGE sizes or rolls. Quote Be EXCELLENT to each other. _ Bill n Ted _
Members Bert03241 Posted April 9, 2024 Members Report Posted April 9, 2024 On 2/11/2023 at 10:19 AM, Gosut said: Made templates this morning for belt ends and another checkbook cover pattern. My first attempt was to draw it directly on the back of poster board, then cut out. That project design proved unworkable, so never used it. These I first drew in LibreCAD, then printed. But how to make templates? First idea, one I intended to use for a knife sheath pattern, was to trace it on the poster board using carbon paper. Then decided to cut around the pattern, glue it to the back of the poster board with a rub-on glue stick, then cut out. This worked well. I went with oval belt holes, and the first two are passable, but the rest look good. I used a hole punch (3mm) for the rounded ends and cut between them. Used the same method on the belt buckle slot, except bumped it up to a 5mm punch. Worried about the half-circle end of the buckle end and the English point on the other, but went at it slowly with an small craft knife that was a gift some years ago. Also used the craft knife for the belt holes and buckle slot. The rest I used a utility knife. Used the craft knife for the rounded corners of the checkbook cover. Being a newbie, I looked at cutting out the template as practice for cutting the leather later. Is this a standard way of making templates? If I was going to do a lot of belts and checkbook covers, I might have sprung for that plastic film used to make templates, Being this would see little use, thought poster board would be okay. NO PICTURES IT DIDN'T HAPPEN Quote
CdK Posted June 12, 2024 Report Posted June 12, 2024 I invested in a 10W diode laser and mounted a camera on it as well. I use this to copy, create and cut out patterns directly onto poster board. Sometimes I'll cut leather directly but this requires good ventilation and/or extraction of the fumes. Quote Leather work machines I own: Thor 1341, Thor 441, LSZ-1 clone, 801 bell skiver, Tinker's Delight Shoe Patcher. (Tippmann Boss was re-homed.)
Members Dwight Posted June 13, 2024 Members Report Posted June 13, 2024 At 79 yrs . . . I have always despised trying to make two things exactly alike by using templates and / or patterns. I like them similar . . . but still unique and "one of a kind". My leather work is the same. I use manila file folders to make "sort of" patterns . . . they get me to be where I can cut a piece of leather . . . and know it will fit a 1911 . . . a Ruger Vaquero . . . or a double barreled derringer. I then wet mold the weapon . . . let it dry . . . and complete the project from there. Each holster will fit the intended weapon or any just like it . . . but laid side by side . . . one may be a tad longer . . . one may be a tad wider . . . one may have double stitching on the outside . . . one may have a thick welt VS thin welt. Just how I do it . . . but again . . . common ol' manila folders and a razor knife have always done well by me . . . get that "sort of" pattern out . . . outline it with a ball point pen . . . go to cutting and I'm good. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
