kgg Posted September 22, 2023 Report Posted September 22, 2023 26 minutes ago, fibersport said: I'm really hesitating to buy another digital controlled motor that looks a lot like what I already have. From what I'm reading, the Reliable motor is a 12 coil motor which should give me better start up torque and what looks like a stronger physical designed motor. It seems the Reliable and the Sailrite are the same motors except for price. The brush motor that Wizcrafts talks about looks like its a tried and true motor, just more old school in terms of servo motors. Yes according to the specs the Reliable and the Sailrite motors appear to be clones of one and another with both being 12 coil designs. There is more at play here when trying to find the min startup speed of the motor. You need to know the size of the small pulley on the end of the motor and the size of the hand-wheel pulley on the sewing machine. So finding someone with the exact same setup and an rpm digital tachometer maybe difficult. Since you can measure the size of your hand-wheel all then left is to determine the size of the small pulley on the motors and their speed range. Once you know those parameters you can use a pulley calculator to determine what to expect on your machine whether it is a brush or brushless servo motor. What I found is that Reliable does not list the speed range but I'm assuming it to be like the Sailrite Workhorse. They say " which let you set your top stitching speed while maintaining variable speed control. Variable maximum speed settings range from 400-3600 stitches per minute. " which does differ from the max rpm of the motor being rated at 4500 rpm. So from that the motors low start up speed is 400 rpm. Sailrite lists two pulleys a Black one and Silver one with the Black one being a clogged 33mm and the Silver being a V-belt 60mm. These specs are from their webpage ( https://www.sailrite.com/Sailrite-Workhorse-Servo-Motor-110V ) The specs for the Consew I could not find. My experience with a digital servo motor with a speed range of 500 - 5000 rpm on a 800 watt, 9 coil and with no reducer pulley are Calculated top speed of the hand-wheel pulley should come in at 156 rpm using a 160 mm hand-wheel pulley size, a 50 mm motor pulley and with the motor speed set to the minimum speed of 500 rpm's. This particular servo motor is a 800 watt brushless 9 coil servo motor with a speed range of 500 to 5000 rpm's. Measured pulley and hand-wheel sizes were. i) The hand-wheel pulley measured out to be 159mm. ii) The small pulley at the motor measured out at 49mm. Measured results with 500 rpm's showing on the controller screen i) with the foot pedal fully depressed the rpm's with my digital tachometer showed 154.5 rpm's with no material under the needle ii) with the foot pedal feathered to get the minimum hand-wheel pulley speed the digital tachometer showed a low rpm reading of 61 rpm's with no material under the needle. From that I can assume a no load ramp up speed of 61 rpm's. Hope this helps, kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Tastech Posted September 22, 2023 Members Report Posted September 22, 2023 Reading these comments and the dilemma of the start up speed makes me appreciate the machines i have on treadles . mind you treadles are not created equal .Not essentially true but you need the right size fly wheel to suit the machine and your purpose . My favorite combo is my Pfaff post bed with a 29K patcher treadle which has been modified into a flat bed . The secret is the smaller diameter flywheel . 12 inches .. Nice and slow for doing the curves of shoe uppers . Above all they are reliable , 100 years old and still going . You also need the right chair /stool to minimize ass and hip cramps . Quote
Members Quade Posted September 22, 2023 Members Report Posted September 22, 2023 Quote The brush motor that Wizcrafts talks about looks like its a tried and true motor, just more old school in terms of servo motors I had one of these. I'm going to let it go with a machine I'm getting rid of. It functions, but I don't like the feel as much as the digital motors. The digitals seem to have more slow speed torque. Looking at the "workhorse". It seems pretty decent. I might have to try one. Quote
Moderator Wizcrafts Posted September 22, 2023 Moderator Report Posted September 22, 2023 1 hour ago, Quade said: I had one of these. I'm going to let it go with a machine I'm getting rid of. It functions, but I don't like the feel as much as the digital motors. The digitals seem to have more slow speed torque. I agree that the analog servo motors have low starting torque. On the machines where I need low speed with high torque, I add a speed reducer. That cures the problem entirely. Some are 2:1, others are 3:1 speed reduction/torque multiplication. These motors and reducers came from Toledo Industrial Sewing Machines. One of my 10 machines is mounted on a table I've had since 2010. I've change the machine heads several times, but kept the table and motor. The motor is branded SewPro 500GR. It is an analog servo motor with a built in 3:1 speed reducer. That motor powers any machine that fits in the cutout through the densest leather. I tried to buy another SewPro 500GR motor two or three years ago but learned they are no longer made. Evidently, the people who made them in China went out for lunch and never came back! No motor for you! Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members fibersport Posted September 22, 2023 Author Members Report Posted September 22, 2023 Keep in mind that I am not concerned with the minimum speed, what I am looking for is a ramp up speed, or actually time. As I have said, I have a speed reducer installed. My minimum motor speed is 500, my final output speed is about 109. I have an app on my phone that uses the camera light to act as a strobe to tell you what the rpm is, both my phone app and calculations are in agreement with my measurement of the pulleys and machine handwheel. I am looking for the slowest ramp up speed between the analog and digital servo motors. Quote
Members Gump Posted September 22, 2023 Members Report Posted September 22, 2023 Your speed setting doesn't have any bearing on slow speed start. My Sewquiet 6000 is set on maximum with a speed reducer. I can do 1 stitch at a time or 1183 spm flat out. Without reducer I get max machine speed at setting 22 out of 30. For high speed work the motor can be set higher, but you lose slow speed start. I got this from the manual, as it isn't in the spec. literature. So apparently it has slow start speed built in. Quote
Members Quade Posted September 22, 2023 Members Report Posted September 22, 2023 Quote Evidently, the people who made them in China went out for lunch and never came back! No motor for you! Haha that's China for you. Quote
Members fibersport Posted September 22, 2023 Author Members Report Posted September 22, 2023 Gump - I caught the start up speed setting in a video on setting the parameters on the Sewquiet 6000, zero disables the slow start but it didn't say what the highest number is nor what the different settings actually do. With my current set up, it's either zero or 500 rpm at the motor. On your sewquiet, can you slow the stitch down just by feathering the treadle? Quote
kgg Posted September 22, 2023 Report Posted September 22, 2023 2 hours ago, fibersport said: I am looking for the slowest ramp up speed between the analog and digital servo motors. From the information I have seen a Brushless servo will have anywhere from 5 percent to 15 percent advantage of converting electrical power to mechanical power over the Brushed servo motor. The big but to this has a lot to do with how many coils the brushless servo motor was constructed with and particularly how good the box of electronic controls are. The performance advantage of a brushless servo motor when using a speed reducer probably will be unnoticeable. From a durability point when comparing quality built motors will probably the same. However the brush motors with the manual speed knob are much simpler to track problems which typically means replacing or cleaning the motors brushes. When the electronics and some brushed servo motors did have some electronics give problems and particularly the brushless it is probably cheaper just to replace the whole unit. I feel the only reason the brushless servo motors are becoming more available is that they are considerably cheaper to manufacture. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Uwe Posted September 22, 2023 Report Posted September 22, 2023 (edited) EFKA is one of the high-end motor and controller options for sewing machines, for a price (roughly $1,500+ range for motor+controller+control panel). These are designed for industrial production applications and are not targeted at the home/hobby market. The spec sheet for DC1550/DA321 combo states a minimum starting speed of 70rpm. I have a feeling this is the state of the art in motor controls. For speeds slower than 70rpm, you have the option of using an electronic thumb controller, that you can twirl as slowly as you want with your thumb. Edited September 22, 2023 by Uwe Quote Uwe (pronounced "OOH-vuh" ) Links: Videos
