I have one of those little hobby thingy's, which is good fun to play around with, but after reading a few posts decided I had to have something bigger (still not sure what I'm going to do with it but I just HAD to have one!:lol:). It's a 10w diode, comes with air-assist and a roller unit for doing bottles/cans etc. I nearly bought a 40w CO2 but realised the diode will be more versatile for my likely needs. It's a Vevor brand and I noticed their other models were advertised with a discount code but not this model, so I put the code in and it worked! Got 5% off!:).
I'm still not sure where I'm going to put the bloody thing when it arrives. :rolleyes2:
  • Replies 28
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Move the telephone . . . you can put it on your nightstand . . . lol
You'll have fun with that roller unit . . . my son and DIL love the glasses I did for them for Christmas
Put their names and an image of their house on them . . .
May God bless,
Dwight
www.dwightsgunleather.com
LOL. I think you might be my bruvver from another muvver.
I'm the same. I read these posts and I almost talk myself into NEEDING one. I have to pull myself up and remind myself that I've not long talked myself into NEEDING a £1500 clicker press to do that job and don't talk to me about the lack of space.
Well, I am a Brummie (and an Aussie), so maybe........:lol:.
Just shipped so as long as Australia Post don't lose it should be here in about a week. Wracking my brains (well, what's left of them) trying to work out where to store it. Leatherworking/reloading shed is full, garage has a car one side and a sandblasting cabinet/welder/Pfaff 335 edge binder/Triumph Bonneville clogging up the other side so no room there. No room in the house (not that I would use it inside). Other shed is full - lathes/grinders/assorted other stuff, wife said no more sheds!!!!
Might have to mount it on a board and hang it on a wall when not in use.:dunno:
While I haven't done this myself, there are several YouTubers out there that mount their lase to a piece of plywood which is then mounted to a wall with a hinge. Swing it up to cut/engrave and fold back when done. Some folks even use it in the vertical position.
My little 3000mw lives on a shelf over the Bell skiver at the moment.
Not sure why you think the diode will be more versatile . My co2 can do much more then a diode and do it a lot faster
Yes, a CO2 will be faster and will cut thicker stuff but the diode has a finer laser "point" and should provide more detail in engraving. Plus this one is significantly cheaper than a CO2 unit (excluding the K40-type units which are generally referred to as a "tinker's delight", to coin a phrase). And the CO2 units are bigger and much heavier, and considering I'm already struggling to find a home for this open-frame unit a CO2 unit is out of the question.
We need our toys.
kgg
You need to be a jailhouse lawyer and follow the letter of the law. Add an extension to one of the sheds. However you may have to build a doghouse as well.
kgg
Edited by kgg
