Members stampingdelight Posted April 23, 2024 Members Report Posted April 23, 2024 what does everyone recommend using on a leather hat to help keep water proof & does not change the shape if some items can do that. Quote
Northmount Posted April 24, 2024 Report Posted April 24, 2024 Moved out of Help wanted to Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners. Posts in Help wanted need moderator's approval before they can be seen. You are better off asking questions here. 4 hours ago, stampingdelight said: what does everyone recommend using on a leather hat to help keep water proof & does not change the shape if some items can do that. Quote
Members stampingdelight Posted April 24, 2024 Author Members Report Posted April 24, 2024 30 minutes ago, Northmount said: Moved out of Help wanted to Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners. Posts in Help wanted need moderator's approval before they can be seen. You are better off asking questions here. k thanks so just ask leather work questions in these topic area Quote
Contributing Member fredk Posted April 24, 2024 Contributing Member Report Posted April 24, 2024 Try rubbing in vaseline Quote Al speling misteaks aer all mi own werk..
AlZilla Posted April 24, 2024 Report Posted April 24, 2024 Blackrocks Leather N' Rich has worked on mine for a couple of years now. Been rained on a few times and wipes/dries right off. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Northmount Posted April 24, 2024 Report Posted April 24, 2024 1 hour ago, stampingdelight said: k thanks so just ask leather work questions in these topic area Lots of topic areas (forums). Pick the ones that seem to fit and fire away! Descriptions of each on the home page. There's also the forum, How do I do that? Some of the posts get moved into other forums they fit into. Quote
Members SUP Posted April 24, 2024 Members Report Posted April 24, 2024 I make leather cozies for my fruit fly traps - just plastic containers with diluted vinegar, which frequently get wet. To keep waterproof, I apply several layers of diluted resolene, then wax and then petroleum jelly, buffing each thoroughly. It works well and no excessive shine either. Quote Learning is a life-long journey.
Members Littlef Posted April 24, 2024 Members Report Posted April 24, 2024 (edited) I think I might be tempted to use a product like a Sno-Seal, used to waterproof hiking boots and other leather outdoor equipment; especially if it'll be worn for extended periods through rain and weather. Adding any product can change coloration (usually darkening), and could potentially cause leather to bend or flex, so it's always advisable to test it first in an inconspicuous place. Edited April 24, 2024 by Littlef Quote Regards, Littlef Littlef - YouTube
CFM chuck123wapati Posted April 24, 2024 CFM Report Posted April 24, 2024 yea dress it as any outdoor leather product would be or if the weather is really bade try one of these.https://www.bootbarn.com/boot-barn-hat-protector/2000213392.html?msclkid=fc136922fdd310ed4b160f0bf352467a&utm_campaign=Shopping&utm_content=hats&utm_medium=cpc&utm_source=bing&utm_term=4583176819036973 Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members stampingdelight Posted April 24, 2024 Author Members Report Posted April 24, 2024 11 hours ago, AlZilla said: Blackrocks Leather N' Rich has worked on mine for a couple of years now. Been rained on a few times and wipes/dries right off. k thanks will check it out Quote
AlZilla Posted April 24, 2024 Report Posted April 24, 2024 So, I wore my hat out in the rain today and meant to grab a picture of how well the water beads up. I waited too long but there's 1 big blob left on the right side. I was inside maybe 7 or 8 minutes. I looked at it when I first walked in and it was beaded all up with rain. I probably haven't hit it with anything for close to a year. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Members stampingdelight Posted April 25, 2024 Author Members Report Posted April 25, 2024 On 4/23/2024 at 7:54 PM, fredk said: Try rubbing in vaseline should I do when full try or damp & what does vaseline do to the leather never tried Quote
Members stampingdelight Posted April 25, 2024 Author Members Report Posted April 25, 2024 5 hours ago, AlZilla said: So, I wore my hat out in the rain today and meant to grab a picture of how well the water beads up. I waited too long but there's 1 big blob left on the right side. I was inside maybe 7 or 8 minutes. I looked at it when I first walked in and it was beaded all up with rain. I probably haven't hit it with anything for close to a year. thanks letting me see just hopping can do & not have to keep putting on not sure of one needs to do it every few months or if once on is good to go thanks again for the help Quote
Contributing Member fredk Posted April 25, 2024 Contributing Member Report Posted April 25, 2024 4 hours ago, stampingdelight said: should I do when full try or damp & what does vaseline do to the leather never tried I've found in this test that Vaseline will give some water-proofing . Put it on dry leather and rub it in good Link to tests; go to the last few posts on page 8 Quote Al speling misteaks aer all mi own werk..
Members stampingdelight Posted April 25, 2024 Author Members Report Posted April 25, 2024 9 hours ago, fredk said: I've found in this test that Vaseline will give some water-proofing . Put it on dry leather and rub it in good Link to tests; go to the last few posts on page 8 thanks Quote
