Members Bert03241 Posted May 6, 2024 Members Report Posted May 6, 2024 I mostly do wet molding knife sheaths and gun holsters . I've never do any carving but would like to try, But is the wet molding gonna mess up any carving work Quote
Members Mablung Posted May 6, 2024 Members Report Posted May 6, 2024 What sort of carving? A ornate floral, simple figure, something in between? And how much detail do you put into the wet molding? Every line of the implement, or more of just a general shaping? The detail and whether you want the front piece to be more decorative or to supply more retention make a difference in what you carve and on what sorts of pieces. Quote
Contributing Member fredk Posted May 6, 2024 Contributing Member Report Posted May 6, 2024 Simple answer; yes Quote Al speling misteaks aer all mi own werk..
Members dikman Posted May 6, 2024 Members Report Posted May 6, 2024 I guess it depends on how tight the bends on the wet molding are. I did this one where the carving extends all the way around on the back of the holster, the wet molding to curve the holster didn't affect the carving much but it's not a really tight curve. I would think tight/sharp molding could cause issues with carved designs. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Bert03241 Posted May 7, 2024 Author Members Report Posted May 7, 2024 well I wouldn't be doing anything to intricate at first. I suppose I could limit any carving to the flatter parts of the holster or sheath . Guess I'll just have to give it a try see how it works out.Thanks for replying Quote
Members dikman Posted May 7, 2024 Members Report Posted May 7, 2024 That's one thing about leatherwork, I don't think there are too many hard and fast rules. It's a matter of trying something out and see what happens, I wanted to see how it would work out. I'm not sure if I'll do it again, though, as it's a lot more work and I don't think, in the case of holsters, that it's necessary. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Moderator immiketoo Posted May 12, 2024 Moderator Report Posted May 12, 2024 How I handle this is twofold. First, I pre-curve any leather I need to bend and I try and tool it on a curved mandrel if possible. (Many times it’s not easy) The second thing I do is only add moisture to the inside surface of the holster/sheath. That minimizes the smushing effect of the fold. Combine these two and most people won’t notice any distortions. Quote Learnleather.com
Northmount Posted May 12, 2024 Report Posted May 12, 2024 On 5/6/2024 at 3:47 PM, Bert03241 said: is the wet molding gonna mess up any carving work Take a look at these saddle pictures. https://leatherworker.net/forum/topic/47182-wet-moulding-and-carving-in-what-order-and-how-much-water/?do=findComment&comment=452495 Quote
Members dikman Posted May 12, 2024 Members Report Posted May 12, 2024 9 hours ago, immiketoo said: The second thing I do is only add moisture to the inside surface of the holster/sheath. That minimizes the smushing effect of the fold. Combine these two and most people won’t notice any distortions. That's what I did, I held it under the tap and ran water along where the bend would be and kept trying the bend until it started to fold then stopped the water. There was enough moisture in the leather to bend it but it didn't soak through to the front. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Moderator immiketoo Posted May 13, 2024 Moderator Report Posted May 13, 2024 11 hours ago, dikman said: That's what I did, I held it under the tap and ran water along where the bend would be and kept trying the bend until it started to fold then stopped the water. There was enough moisture in the leather to bend it but it didn't soak through to the front. That’s the ticket. I use less water than that, only adding a bit at a time. You can always add but you can’t take away. Quote Learnleather.com
