Thanks for all the responses guys and sorry for being lates responding at times. I’m dealing with health issues and when I’m in the hospital I slack off on emails and messages. I just got back today though and actually sitting at my leather work bench crafting away on a sheath. My 3rd sheath so far. Also I got a hide of Wickett and Craig Skirting and using it for the first time. I like it a lot. Actually prefer it over the A grade HO tooling. I really like how the russet burnishes when tooling. I wish it was a little stiffer. I read that when ordering directly from W&C they offer pressing to desired temper. Anyone know anything about that?
Thanks again folks
If its iron contamination, the only way I can see that sort of spread is if some one used an angle grinder near the leather allowing the 'sparks' to land on it. The 'sparks' ain't sparks but very tiny pieces of hot metal
Yeah, could be some kind of metal work near the tanning or processing area of some sort? Very strange. Could it even be something completely different? Not metal but other type of oxidation of some sort? Couldn’t be mold cause the leather was new and I got to work on the day of arrival, or could it?. I didn’t even fully case it, but rather used the sponge method, the first piece I worked on wasn’t large and I was eager to try out the leather and new tools. Granted the 10oz leather was “thirsty” and I did wet it with the sponge more than I normally would have. Anyway, as soon as the leather got its colour back some the first spots started to show. Later on I sponged it a bit more and even more spots were showing. Very strange. I really wish I got a definitive diagnosis but that might not be the case. Mostly out of curiosity. Of course, should I ever get spots like this again in a completely different piece of leather, I’d know the fault lies in my end. Can’t see how that could be though.
On 11/14/2024 at 2:25 PM, leatherman64 said:
As an FYI normally if you use Bee Natural Pro Carve in your water you case with, it will eliminate that reaction before it happens.  It will not remove it once there, but if you are keeping that hide then it’s worth a try to salvage the leather.
Do you know if Eco flow easy carve has similar properties in it that give the same effect? Bee natural Pro carve is a bit harder to get in my region.
5 hours ago, Yukonrookie said:
. . . I wish it was a little stiffer. I read that when ordering directly from W&C they offer pressing to desired temper. Anyone know anything about that?
a. I don't know anything about W&C
b. you can stiffen up modest size pieces of leather yourself. By soaking in warm water then drying fairly quickly between two heavy boards*. Cover the boards in absorbent clean white paper. Your only limit is the size of the boards
* or light thin boards with weights placed on them
Thanks. That’s a good, quick and easy idea. Have you ever stiffened with an oven? Or the “flash boil” method? Like for holsters, for example.
I've tried both
The boiling water method tightened up this knife scabbard hanger and made it very firm Dagger Hanger, all, 01LWs.JPG
I never liked using an oven. I found the results too unpredictable
Gotcha. Will it change form much, or mostly just shrink a bit?
I found it would shrink quite a bit in any direction. It was totally unpredictable
Good to know. I just ordered some leather hardener/firmer. For most of my projects I like the temper of the leathers I work with currently. That’s a side of W&C a couple heavy weight Double Butts of Italian veg tan and some shoulders of Italian. Of those the double butts have a firmer temper than the 8/10oz W&C skirting, which surprised me a bit. I had just finished a side of HO 8/10 oz tooling and decided to try out some W&C. Simply because I’m relatively new to the craft and want to get an understanding of the different makes and types of veg tan. Anyway, the HO had a slightly firmer temper over the same weight W&C and for the odd project that was good. Than again the W&C has a thing or two that I like a tad more than the HO so it evens itself out. Both are obviously top notch so I hope it doesn’t sound like I’m bashing one or the other, with my limited knowledge lol.
If you don’t mind me asking what leathers do you mostly work with?
  • 2 weeks later...
If you sharpen knives, or use any kind of file on metal and don't get it all cleaned up. This is exactly what happens. The little microscopic shavings will stain the leather. I ran into this problem and it took me a few months of research to digit it out. I no longer allow filling or sharpening in the leather shop and it solved my problem
  • 2 months later...
I just wanted to give an update on the supplier and how it all turned out.
I’d been meaning to do this a lot sooner. I’m dealing with health issues and have been in and out a bunch lately. Apologies for the delay.
So, the supplier is buyleatheronline.com and they took great care of me. They replied to my complaint in a timely fashion and after they made sure that my hide was a one off situation and that no more hides got contaminated, they right away sent me out a new piece of beautiful natural double butts. It really is excellent quality. No scars, blemishes or overly loose grain. Flessh side very nice as well. Of course completely free of charge and they let me keep the original one as well.
I’ll definitely order more from them.
Since I’m very happy with their service and their handling of this I’d like to leave them feedback here. Is that something that’s done on here and, if so, where should one best place it on here?
That's excellent service. :specool: It's becoming something of a rarity in these days of internet shopping.
Yes, Sir. That it is for sure. Mistakes can happen to the very best of them. It’s how they then deal with it what makes a great business, in my opinion.
