Members Mulesaw Posted January 28 Members Report Posted January 28 @BlackDragon I am looking forward to the result :-) I think those black ones on your picture look like they could be a winner. Brgds Jonas Quote
kgg Posted January 28 Report Posted January 28 (edited) On 1/26/2025 at 7:08 PM, Dwight said: This aluminum sleeve that goes over the stamp takes that away as it is appreciably bigger . . . easier to hold on to . . . and makes turning it to "just the right angle" a whole lot easier. I think I would use: i) an off the shelf hollow linear shaft as they come in various outside and inside diameters. I guess a shaft with a 3/4" ( 20mm) OD and a 3/8" (10mm) ID would work. If the shaft isn't large enough add some form of a grip. These shafts are really available off places like Aliexpress and are mostly used for linear movement. An example would be ( https://vi.aliexpress.com/item/1005008313729816.html?spm=a2g0o.productlist.main.1.7f1edY5sdY5swH&algo_pvid=da5d617e-a98c-46cd-b478-14026027a4f7&algo_exp_id=da5d617e-a98c-46cd-b478-14026027a4f7-0&pdp_npi=4%40dis!CAD!26.96!13.48!!!133.20!66.60!%402101e9a217380630172501546ef44e!12000044581316320!sea!CA!3463193163!X&curPageLogUid=rV9wvFNWFsW5&utparam-url=scene%3Asearch|query_from%3A ) ii) 3D print a shaft with comfortable outside diameter for my hand with the correct inside diameter to accommodate the stamp. Cost would be pennies to make. Me being me I would do the 3D printed method. kgg Edited January 28 by kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
CFM chuck123wapati Posted January 28 CFM Report Posted January 28 On 1/27/2025 at 12:42 AM, Dwight said: Actually . . . it does look easy to make . . . and the part(s) you see in the pictures . . . they are not "that" hard. But as Beehive mentioned . . . there are a whole batch of different shank sizes . . . combating that with just one tool is in itself a trick. We're working on that trick . . . there are several different approaches . . . just trying to determine which will hold up the longest. May God bless, Dwight a set screw in one side would allow the use of different size shanks. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members dikman Posted January 28 Members Report Posted January 28 8 hours ago, chuck123wapati said: a set screw in one side would allow the use of different size shanks. That would also be a good idea for something like a beveller where you're following curves, although I think for a beveller it would be better to make it permanent, i.e. a very tight force fit. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members steelhawk Posted January 28 Members Report Posted January 28 I had to basketweave stamp 25 holsters. To help relieve the pain to my thumb, I used vet wrap and greatly enlarged the tool diameter. Quote www.bearriverholsters.com
Members steelhawk Posted January 29 Members Report Posted January 29 Here's a picture of the holster I made with the tools I wrapped. With the vet wrap I still had good control of the tools. Quote www.bearriverholsters.com
Members Dwight Posted January 29 Author Members Report Posted January 29 2 hours ago, steelhawk said: Here's a picture of the holster I made with the tools I wrapped. With the vet wrap I still had good control of the tools. Actually before the aluminum sleeve . . . I did things like that . . . never found the one I really liked other than the duct tape . . . or rubber hose. The rubber hose though became a pain in itself . . . never figured out why . . . just did. I like the aluminum by far the best (especially better than the duct tape . . . lol ) May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members dikman Posted January 29 Members Report Posted January 29 23 hours ago, steelhawk said: I had to basketweave stamp 25 holsters. To help relieve the pain to my thumb, I used vet wrap and greatly enlarged the tool diameter. That sounds like a brutal form of punishment!!! Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members greygeist3191 Posted January 30 Members Report Posted January 30 I printed a couple on my 3d printer to fit my most used sizes Work pretty good Think I got the file off thingiverse Quote
Members steelhawk Posted January 30 Members Report Posted January 30 On 1/29/2025 at 2:55 PM, dikman said: That sounds like a brutal form of punishment!!! It was, but the $3500 made up for it. Quote www.bearriverholsters.com
