Members MattiJoy2 Posted March 20 Members Report Posted March 20 (edited) went to my walking foot repair man today to pick up my machine. Almost top shelf was a vintage very large Durkopp Adler cylinder arm. He said it was a very good machine and had a huge bobbin. It had a crack around the upper right top half circling nearly around the whole thing. I climbed up to push on it and it was stiff and didn't move or wobble. I asked him what happened and he said it fell. He would give it to me for $500. I told him my boyfriend has 40 years experience welding {that's his profession}, and could repair it and he said the mechanisms work perfect and it should be fine. It looks like it has been painted but not sure. I am unable to really see the total damage and need to take it off the shelf to inspect further. What do you think. Is it possible it could work and fall from my guess around 15 feet. Should I consider buying it and what should I look for. I'm new to this repair man and haven't built trust or a relationship with him yet. The crack is not the cylinder arm it is on the top next to the stem, if that helps. Edited March 20 by MattiJoy2 Quote
Members MattiJoy2 Posted March 21 Author Members Report Posted March 21 It fell. It is a vintage cylinder arm Adler with a large bobbin. I pushed on the machine to see if it is loose from the crack and nothing. It is for sale for $500. My boyfriend is a welder by trade and can fix it. Is is possible it can be working properly again? The owner of the shop said it is mechanically ok but the crack is 2/3 around the entire perimiter of the upper body against the stem of the machine.It is stiff and has no movement. What should I look for in evaluating it or should I not bother Quote
Moderator Wizcrafts Posted March 21 Moderator Report Posted March 21 @MattiJoy2; Get the model number and maybe a low res photo. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Michiel Posted March 21 Members Report Posted March 21 I have seen adlers with a crack that stil worked. (For a long time) i would like to see a picture, but in generall i think: “if its not broken, don’t fix it” (if you have someone who thinks he can weld it, you might consider to buy it and start using it) Quote
toxo Posted March 21 Report Posted March 21 Firstly it's on the top shelf because it's not sellable. I wouldn't risk $50 on something that Might work. If you jump through all the hoops necessary to get it home and find it doesn't work you'll not get your money back. If he can get it down and it turns freely you might have a chance but it still might not be in sync. If it looks like there's a chance you could make an offer but I wouldn't be offering anything near $500. Welding cast steel can be difficult so you can use the cost of repair in your favour. Quote
AlZilla Posted March 21 Report Posted March 21 Pictures are really required to give any kind of opinion. But your boyfriend is the best one to ask. Welding can cause distortion that might lead to misalignment of previously machined parts. Cast iron can also be it's own particular challenge. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
kgg Posted March 21 Report Posted March 21 On 3/20/2025 at 11:22 PM, MattiJoy2 said: Almost top shelf was a vintage very large Durkopp Adler cylinder arm. Expand My take without seeing any photo's: With a crack that severe there are three questions that need to be answered. 1) Does it move freely and sew? If not it there are more then likely internal damaged / misaligned parts. 2) What parts are damaged / misaligned / bend inside. Parts for Durkopp Adler in general can be expensive and depending on the age of the machine they maybe difficult to get. 3) Welding can be done on cast iron but and it is a big but can the machine be welded properly so nothing internally warps. If the crack could be repaired it does beg the question why hasn't the repair shop had it done? Personally I would consider this a parts machine so it's worth is next to nothing except to someone with the same or similar model. As for the repair shop well I would would be very wary and probably consider finding another repair shop. Since you are looking at cylinder arm machine I have two suggestions: 1) Set a realistic budget. My rule of thumb if I'm looking for a used machine for myself I am willing to pay 60% to 70 % of the cost a new machine if it is owned by a hobbyist. 2) Determine the class of machine that covers 90% of what you plan on sewing. As a quick reference: i) The Juki DNU-1541S and clones for Flatbed needs. ii) The Juki LS-1341 and clones for Cylinder Arm needs. These machines in general cover most needs. If it is going to be your main machine I would suggest a cylinder arm machine with a flatbed attachment and probably go with a new machine. Clone machines and there are many are a cost effective way. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Cumberland Highpower Posted March 21 Members Report Posted March 21 (edited) Sure it can be fixed. Can you post some details like Wiz asked? You "May just be able to use it as it is...Maybe forever? Or maybe not? If it looks like it's holding pretty well, you can just cut a small relief in the cracked areas and work in JB weld, grind flush and repaint the machine. Nobody will ever know. Check to see if it works freely w/o any binding or misalignment before doing anything. Are you certain it's a crack? Some machines are made from more than one piece and bolted together. (Like my Seiko TE6). It has 2 pieces that are bolted together and finished smooth on the exterior, but "look" like a fine crack. Is it a hairline crack or a crack that allows some daylight? If he's a welder by trade there is little doubt he can fit it. Cast iron you have is best brazed. Probably in 'stitches" to keep anything from warping or cracking further. It can be welded also, but I'm not sure I would do it on a sewing machine. Edited March 21 by Cumberland Highpower Quote
CowboyBob Posted March 21 Report Posted March 21 (edited) On 3/21/2025 at 11:16 AM, kgg said: My take without seeing any photo's: With a crack that severe there are three questions that need to be answered. 1) Does it move freely and sew? If not it there are more then likely internal damaged / misaligned parts. 2) What parts are damaged / misaligned / bend inside. Parts for Durkopp Adler in general can be expensive and depending on the age of the machine they maybe difficult to get. 3) Welding can be done on case iron but and it is a big but can the machine be welded properly so nothing internally warps. If the crack could be repaired it does beg the question why hasn't the repair shop had it done? Personally I would consider this a parts machine so it's worth is next to nothing except to someone with the same or similar model. As for the repair shop well I would would be very wary and probably consider finding another repair shop. Since you are looking at cylinder arm machine I have two suggestions: 1) Set a realistic budget. My rule of thumb if I'm looking for a used machine for myself I am willing to pay 60% to 70 % of the cost a new machine if it is owned by a hobbyist. 2) Determine the class of machine that covers 90% of what you plan on sewing. As a quick reference: i) The Juki DNU-1541S and clones for Flatbed needs. ii) The Juki LS-1341 and clones for Cylinder Arm needs. These machines in general cover most needs. If it is going to be your main machine I would suggest a cylinder arm machine with a flatbed attachment and probably go with a new machine. Clone machines and there are many are a cost effective way. kgg Expand Here's one we welded years ago & he's still using it.But every repair is different. welded Adler.pdfFetching info... Edited March 21 by CowboyBob Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
kgg Posted March 21 Report Posted March 21 On 3/21/2025 at 3:56 PM, CowboyBob said: But every repair is different. Expand I agree and it also depends on the ability / experience of the person doing the repair. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Northmount Posted March 21 Report Posted March 21 @MattiJoy2 Merged your posts into a single thread. Let's keep related items together instead of starting a new thread and asking similar questions. Quote
Members GerryR Posted March 25 Members Report Posted March 25 I'm a little late to the party, but here is my $.02 If everything runs freely, the casting can be brazed, or if just a hairline crack, silver soldered; I wouldn't weld it. Quote
Members Tigweldor Posted March 26 Members Report Posted March 26 (edited) Problem with silver soldering is that the crack would have to be "clinically" clean - if the machine was painted after it cracked or oxides have meanwhile formed in the crack - the results will be at best mediocre. Otherwise the tensile strength of a sound silver solder joint will surpass that of the cast iron of the machine. I would also definitely NOT pay 500$US for a sewing machine that has a cracked housing - I would not even go back to that guy/shop for future business cause in my eyes he quoted a "sucker price" to a standing repeat customer. Just my opinion on the matter, though. Edited March 26 by Tigweldor Quote
Members MattiJoy2 Posted May 20 Author Members Report Posted May 20 Thank you everyone for your help. I was so desperate I put multiple questions on the board not knowing how active you are on this site. I had paid so much trying to repair a vintage 111w155 which became a money pit with barely any sew time. I took your advice, sold it and purchased a refurbished Juki LS1245 cylinder arm. I have been happily sewing ever since. Sorry for not replying sooner. I am so grateful for the advice I got on here and realized though I am near a large city, finding a reputable industrial sewing machine repair man is not that easy. Seems like you really need to master the skill yourself on your own machine to fix all the previous misalignments. Way out of my wheelhouse. Problem solved, excellent advice, thank you! Quote
CFM Frodo Posted May 20 CFM Report Posted May 20 On 3/26/2025 at 12:35 AM, Tigweldor said: Problem with silver soldering is that the crack would have to be "clinically" clean - if the machine was painted after it cracked or oxides have meanwhile formed in the crack - the results will be at best mediocre. Otherwise the tensile strength of a sound silver solder joint will surpass that of the cast iron of the machine. I would also definitely NOT pay 500$US for a sewing machine that has a cracked housing - I would not even go back to that guy/shop for future business cause in my eyes he quoted a "sucker price" to a standing repeat customer. Just my opinion on the matter, though. Expand I agree with tig offer the Dude $100.00 cash be prepared to walk out Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
Members FDC Posted May 30 Members Report Posted May 30 I've repaired cracked and broken cast iron and it's not magic. If this machine ran as is I would consider it. I'd have recommended TIG welding with cast rod - your BF would have no problem with that. I've taken a flier on three rough leather machines and while each one required pretty serious time to restore them they all work as new. But if actual leather working is your thing, machine restoration isn't leatherworking! Chris Quote
