Members SUP Posted May 18, 2025 Members Report Posted May 18, 2025 (edited) Others have probably tried this already but since I discovered it new for myself, I thought of putting it up here. I use thick leather splits as punching mats. I often also use a block of wax. I sometimes place the split piece on the wax block so that even if the punch goes through, it just gets lubricated with wax. When I was last melting the wax block to smoothen it, I dipped the leather split piece in the melted wax. I let it absorb for a minute or two on both sides and then kept it aside to dry. It dried hard, harder than the original split and it works well as a punching mat. For the wax, I used a mix of paraffin wax and beeswax. Plain paraffin is too brittle and pure beeswax is too sticky. Together, they work well for me, both in block form as well as in the punching mat. Edited May 18, 2025 by SUP Quote Learning is a life-long journey.
Members dikman Posted May 19, 2025 Members Report Posted May 19, 2025 "Smoothen"? I had to look that up and yes, it's a word. In all my 76 years I've never heard it before. I finally learned a new word. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members SUP Posted May 19, 2025 Author Members Report Posted May 19, 2025 (edited) 😄 What word do you use in its place? Edited May 20, 2025 by SUP Quote Learning is a life-long journey.
RockyAussie Posted May 20, 2025 Report Posted May 20, 2025 Very good tip. Thanks for sharing. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members jrdunn Posted May 20, 2025 Members Report Posted May 20, 2025 18 hours ago, SUP said: 😄 What word do you use in its place? Maybe SLICKIFY??? Quote
Members Hags Posted May 20, 2025 Members Report Posted May 20, 2025 Beware of using wax before staining. Quote Not so retired RN. Living on the Washington Peninsula.
Members SUP Posted May 20, 2025 Author Members Report Posted May 20, 2025 57 minutes ago, Hags said: Beware of using wax before staining. I only use wax on pieces of splits that I use as pounding boards. I do not stain or dye those pieces. But when using wax to harden leather, certainly. As @fredk has explained in another thread, 'This was one of the ways that leather armour was made, from the early Roman times up to the 19th century. see cuir bouilli' So a new use for an old technique. New to me, anyway. Isn't that nice? 🙂 3 hours ago, jrdunn said: Maybe SLICKIFY??? 😄Certainly more illustrative of the result than boring old 'smoothen'. Quote Learning is a life-long journey.
Contributing Member fredk Posted May 20, 2025 Contributing Member Report Posted May 20, 2025 This is a clever idea What thickness of leather are you using for your stamping pad? Quote Al speling misteaks aer all mi own werk..
Members SUP Posted May 20, 2025 Author Members Report Posted May 20, 2025 3-4 mm at least. I got 2 huge sides of splits during a Black Friday sale but they are of different thicknesses. I just cut them up from one side, and make usable pieces. The current one is one of the thinner pieces, because the split has a very variable thickness all through. Without the wax, they gradually get floppy. Let's see what happens with the waxed one. Quote Learning is a life-long journey.
Members dikman Posted May 20, 2025 Members Report Posted May 20, 2025 SUP, I've always just used "smooth". Anyhow, it's an interesting idea you have there. I have plenty of paraffin wax that I bought to re-wax a jacket and don't have any other use for it, plus plenty of beeswax, plus some old hard leather from a very old saddle, might have to give this idea some thought. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
