Members el_pipou Posted September 10, 2025 Members Report Posted September 10, 2025 Hi, I recently bought two cans of oil advertised as pure neatsfoot oil. However, I have worked with neatsfoot oil from other brands before and this one seems different in multiple ways. I had used starwax neatsfoot oil, wich was nearly odorless, and stayed liquid even at about 10 degrees celcius, and saphir brand, wich had a bit of a smell but not a suspicious one and remained liquid too. The oil I just bought is supposedly from a brand called P.Paulin, and not only does it have a very strong rancid smell, it does not stay liquid under Id say 20 degrees celcius. It is also cloudy while the other brands were transparent. is this normal? is it just a different neatsfoot oil? or is it neatsfoot oil mixed with a great deal of tallow and such greases? I dare not use it on any piece of leather, or even to lube machinery because of this horrid stench. did I get scammed? or did I just observe non-industrial neatsfoot oil for the first time? Quote
Members dikman Posted September 11, 2025 Members Report Posted September 11, 2025 Sounds like it might be compounded neatsfoot oil, this is pure NF mixed with petroleum-based oils. It can be made cheaper because it's effectively diluting the NF with (relatively) cheap mineral oils. It will still work on leather but most leatherworkers prefer the pure stuff. If it's compounded it should mention it on the labei. A google search for P Paulin doesn't come up with anything. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members el_pipou Posted September 11, 2025 Author Members Report Posted September 11, 2025 thank you for your anwser, Ill probably try to resell it or give it away regardless of what it is because I simply dont want my shoes smelling like this 😂 it was cheaper than most neatsfoot oil... (30 bucks a liter whereas other oils were between 40 and 55), so I guess it was adultered with something... it does WORK very well though, perhaps a little bit better than the other oils, but the stench overcomes that fact. I tried it on my meast favourite pair of boots and the stench didnt go away (yet anyway) I guess Ill try to use another strong scented product to mask the smell like some shoe-wax or something Quote
kgg Posted September 11, 2025 Report Posted September 11, 2025 52 minutes ago, el_pipou said: Ill probably try to resell it or give it away regardless of what it is because I simply dont want my shoes smelling like this What country are you in?? A link to where you bought it would be helpful so someone else doesn't buy it by mistake. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Contributing Member fredk Posted September 11, 2025 Contributing Member Report Posted September 11, 2025 If it has stench I'd not use it at all, Something in it is 'off' and could affect the leather. Just dispose of it properly and write off its cost to experience Quote Al speling misteaks aer all mi own werk..
Northmount Posted September 11, 2025 Report Posted September 11, 2025 5 hours ago, kgg said: What country are you in?? A link to where you bought it would be helpful so someone else doesn't buy it by mistake. kgg IP address shows Valenciennes, Hauts-de-France, 59300, France @el_pipou You should put your general location in your profile. It helps get info relative to your location. Quote
Members SUP Posted September 11, 2025 Members Report Posted September 11, 2025 If the oil has a rancid stench, I would not use it. Normally, neetsfoot oil as well as the compounded mix last for a long time. The compounded oil has petroleum based products added, which have an even longer shelf life. It does not smell rancid or of much of anything. So if the oil smells, there might be something else added to replace some of the neetsfoot oil, maybe another oil altogether, that is not petroleum based. It could be anything, from olive to coconut to palm oil to even linseed oil, all of which are cheaper than neetfoot oil, so could be adulterants. All would harden at cooler temperatures and cause the cloudiness. All would also turn rancid with exposure to air, unlike neetsfoot oil. Quote Learning is a life-long journey.
Members dikman Posted September 11, 2025 Members Report Posted September 11, 2025 Oops, I missed the rancid bit - it's obviously compounded but as has been said they used something even cheaper than mineral-based oil, some sort of vegetable/animal oil that goes off. Definitely don't use it on leather (unless it's for someone you don't like!). Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members TonyV Posted September 11, 2025 Members Report Posted September 11, 2025 There is a French website for P. Paulin, which is selling shoe polishing compounds and various cleaners and oils, including 'Huile pied de boeuf cuir ' Which I believe translates roughly to Cow foot oil (my mother would be ashamed of my lack of Francais). Try what you have on some non-critical project or 3. I bet it works fine. Catalogue produit P. Paulin Cirage | Revendeur - Distributeur en ligne Quote
Moderator bruce johnson Posted September 12, 2025 Moderator Report Posted September 12, 2025 I'm going to be the odd man out here and say most likely it is not compounded NF oil. The oils most are compounded with will not solidify as easily as what is recognized as pure NF oil today. I can't speak for other countries but here is the thumbnail sketch of NF oil as I understand it in the US. Traditionally yes - the recognized standard pure NF oil was made by boiling leg bones of cattle. During one of the world wars ( I am thinking it was WW2) the military need for neetsfoot oil out stripped the supplies. The military standards were relaxed to allow any animal based oils that fit similar characteristics of NF oil. I don't have exact details but pressed hog lard was one of them and available. Since there were few consumer standards but a military standard, depending on manufacturer other animal oils besides cattle make up some percentage of pure NF oils since then. I would suspect that some name suppliers have a standard and source and some of the lower end suppliers use price-point sources with less standards. I have used several and some did consistently smell different than others, all solidified at some temperature but melted easily with a little heat. Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
