8 hours ago, Tommy217xxx said:
Are these skipped stitches or are they loose?  I’m not sure how to fix it.
Mostly your top tension looks to be too tight. Try turning back anticlockwise about 1/2 turn. It also looks a bit intermittent which could mean that the needle size should be a smaller size for that weight leather. What size thread and what size needle are you using here? Also are you using a leather point needle?
YouTube Channel
Instagram
  • Replies 38
  • Created
  • Last Reply
Top Posters In This Topic
I’m using 92 thread and needles and I’m not sure what needles I got when I bought the machine.
The leather your sewing has to be thick enough to hide the knot,try 2 or3 layers.
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
For a V92 thread you need a #20 in thin leather or a #22 in thick leather. Here is a good needle size vs thread size chart ( condiments of @CowboyBob ).https://www.tolindsewmach.com/thread-chart.html
One layer unless it is fairly thick can be difficult to bury the knot in. To small a thread for the needle size will look slack. Don't forget to hold the top and bobbin thread ends for the first few stitches and there are two ways to start. i) most common method is to hold the thread ends, stitch 3 or 4 forward, reverse back 3 or 4 stitches to lock them and go forward to continue your seam. ii) less commonly done but gives a nicer, less bulky stitch at the start of your seam. Start your stitch line in the distance of 3 or 4 stitches and while holding both thread ends reverse back 3 or 4 stitches and then go forward to do your seam.
kgg
Thank you everyone for your advice. I’m very new to machine sewing but eager to learn.
This one took me a while to figure out and some practice to get right. It is much, much better than basically running over your lock stitches 3 times with big thread.
- Voltaire
- Aristotle
I use that same method, I keep some scrap around and make a piece the same thickness I am going to sew then sew a line of stitches on it.  Does two things, makes sure everything is running right and it gives me a way to measure 3 stitches.  I use my wing dividers set them in the holes and make a mark 3 stitches in on the project and start there and sew back to the start point then forward over the 3 stitches and on down the project.
Todd
Do u guys take the brake out of your servos? Mine has a brushed motor and I saw an article about different motors. The article mentioned taking the brake out.
is there a reason why I wouldn’t want to do that?
I wouldn't disable the brake. I want the motor to stop when I take my foot off it. I certainly wouldn't want the machine to freewheel another stitch or two.
- Voltaire
- Aristotle
That’s a good point. What about different hopper feet? Would a zipper foot make zippers easier to stitch?
sorry for all the questions.
