Members rmr Posted January 21, 2012 Members Report Posted January 21, 2012 I have a set of paper patterns Im planning on using to make my first saddle. Assumming this goes OK and I decide to make anothewr one- I want to have the patterns on something more durrable than paper. I would love to hear what others are using for a material to create more permanent patterns from Thansk for any advice RMR Quote
Members THein Posted January 21, 2012 Members Report Posted January 21, 2012 RMR, I've got one cardboard pattern I've used so much it's curling under on the edges from tracing. I've got a peice of Lexan to tape a new pattern on then cut it out on a bandsaw. I figure on cutting a little large and finish on a sander. Terry Quote
Members Dwight Posted January 21, 2012 Members Report Posted January 21, 2012 All of my smaller patterns follow John Bianchi's advice: manila folders. I have never had an issue with any of them, . . . not one. For larger patterns, . . . Tandy sells a product, . . . bag liner, . . . it's a kinda sorta cardboardy material, . . . but so far has held up really well in every test pattern I have used it for. It comes in a roll, . . . something like 40 inches wide, . . . and I love the stuff. Fact is, . . . when I get the new shop next spring, . . . one of my "tasks" is to take all my smaller patterns and create new ones with bag liner for the ones I use the most. May God bless, Dwight Quote
Members justken Posted January 22, 2012 Members Report Posted January 22, 2012 Hello!..I've started using a clear runner material that I picked up at Home Depot.Get the smoothest you can find,not the carpet type.Works really good so far ,and you can also see through it to work around blemishes. Quote
Members tonyc1 Posted January 22, 2012 Members Report Posted January 22, 2012 I like Lino offcuts for most patterns. Easy to cut and stiff enough to hold their shape! Tony. Quote
Contributing Member TwinOaks Posted January 22, 2012 Contributing Member Report Posted January 22, 2012 I wait until the end of "back to school" season and pick up the plastic file folders at wallyworld for about a nickel each. I use these for most of my smaller patterns. For large patterns (both of them) I like linoleum ....same reasons as Tony. Quote
Members lazyy Posted January 22, 2012 Members Report Posted January 22, 2012 I go to flooring stores and buy there vinyl remnants. Usally get 4x8 or there abouts for $20. Extreamly durable waterproof and semi ridgid. Quote
Members Big O Posted January 22, 2012 Members Report Posted January 22, 2012 Manila folders. It doesn't make sense for me to try to re-use a pattern, because I make every one of my holsters to order, customized for ride height and angle. And my volume is ridiculously low, maybe 2-3 a month. Quote
Members Treed Posted January 22, 2012 Members Report Posted January 22, 2012 I go over to the local feed store and pick up the pallet covers. They are cardboard and the size of the pallet to protect the bags of feed from getting ripped open. The best thing over the great size is free Bobby R Quote
Members GrampaJoel Posted January 22, 2012 Members Report Posted January 22, 2012 I usually start with poster board to work out a pattern I like, and then save a permanent pattern onto a sheet of vinyl like plastic . The plastic is the same thickness as poster board and has very similar bending properties. I buy the plastic sheeting in a 5' X 20 ' roll from a local plastics store. When I store the pattern I just punch a small hole in the plastic and hang in on a nail. Joel Quote
Members steelhawk Posted January 22, 2012 Members Report Posted January 22, 2012 I use manila folders, but I like the idea of using something clear that allows me to see bad spots on the leather. Quote
Members jmace Posted January 23, 2012 Members Report Posted January 23, 2012 Plexiglass-- If it's a pattern I know will be used often. It is clear, rigid, it can be drilled and hung on wall, and it helps me keep my knife cut at a 90 degree angle. Quote
Members benlilly1 Posted January 23, 2012 Members Report Posted January 23, 2012 I get my pattern material from a local chiropractor. When they receive new x-ray films there is a nice white sturdy but thin cardboard between each sheet. They just throw it away and it works great for me so I'm never out of pattern material. Quote
Members lottarope Posted June 19, 2012 Members Report Posted June 19, 2012 Plastex- it a bathtub surround material available at Home Depot for about $25 a 4x8 sheet. I like it better than flooring material because it has no paper backing to warp over time. you can also draw on it with a pencil and erase easily. This was one of the coolest things I learned at Sheridan this year. Thank you Mr. Smith. When I'm developing a pattern I use beer box and duct tape. I find Blue Ribbon inspires best but I'm sure others have a brand that works just as well. Quote
