also jett sett is used by physical therapists to help people rehab......great stuff
Emergency Room Nurse by profession.......Leatherworker at heart!!
Hoping to reverse the order in that one of these days!!
You can also try low temp plastic pellets. They can be melted with hot water and molded to any shape. They are available at craft stores and in Canada at Princess Auto. You might find them at Harbour Freight stateside. My problem was with my swivel knives cramping my hand, and I just wrapped a piece of 10 oz vegtan around it and stitched it up tight. Gump
WinterBear, Thats some interesting stuff. It's amazing to way it molds and reusable to boot! I think I may try that. Thanks for the idea.
Bro Tim
It is good stuff according to the jewelers I know. I'll be ordering myself a pound next month--I want to try it on the shaft of some skinny stamps I have that are hard for me to hold. And best of all, it's not permanent, so I can peel it off if I want to sell the tool.
I used to be an Eagle, a good ol' Eagle too...
Hi All
Anybody consider using bottle wine corks, they're cheap, available at the local supermarket. Just drill a hole of the proper size in the centre and push it on. A little glue may help. Cork is soft and will absorb vibration. Try it.
Leo.
I use silicone tubing. it is soft enough to stretch tightly over the shaft and tough enough to last forever. It is also heat resistant to about 750 degrees F. so if you tool really fast you don't have to worry about heat friction meltdown of your handle.
Well I hadnt thought of drilling out a portion of dowel either. It could alway be set with a drop of silicone or epoxy.
Bro Tim
Another possible solution, but probably not as good as those menioned above - there is a plastic solution commonly sold at builder's supply places (unfortunately, I can't remember the name) which is used to dip things like plier handles in to insulate them from electrical shock. the tool(s) could be dipped several times to build up to the desired thickness. It does dry fairly soft and very flexible. You might see it already installed on small tools at Home Depot, Lowes and the like. Most that I've seen is orange, but also see blue occasionally.
Hmmm... I like that idea too as it may absorb vibration from being struck as well. Good idea!
Bro Tim
A friend of mine who is a tattoo artist, gave me a few of the tattoo gun grips (knurled metal) and they have a set screw drilled into them. I can screw them on a lot of my stamping tools to provide a larger grip
Never argue with a stupid person. They'll just drag you down to their level and beat you with experience!!
