It is possible I have some sort of sewing machine curse...
Every sewing machine (of any type) I've ever owned to date has been such an unending source of headaches, that I hand sew - everything.
Then I learned to tool. And saw the lack of attention to detail (and frankly lack of care...) that was going into the tack repairs I was sending out locally... Which left me unwilling to let someone else assemble the chaps, belts, bridles, belt, and other miscellaneous tack items I am building. Hand sewing zippers into chaps is just not on my to do list!
So, I picked up a singer 31-15, cheap, supposedly just serviced and with a sample piece the tech had supposedly sewn...but no power in the shop where it was located. Yes, I learned my lesson... A year of fussing with trying to get it to stop missing stitches (and not be wanton to take off if it actually will pick up all the stitches) as I continue to hand sew.... I had finally had enough and went back to CL
I found a Japanese built industrial leather cylinder arm machine with a 1/2 hp, 220v, three phase motor for a song. Motor date is 1978, very low hours, very smooth action, super clean. It supposedly had been purchased new and wharehoused until last year, when it was purchased and used for one specific project. The only complaint I had was marking from the roller feed foot even on 5-6 oz leather, but I knew that can be taken care of a few different ways and it has other feet. It sewed as slow as non machine sewing me needed, through over 1/2" of veg tan with almost no hesitation on the most thick portions (tho the machine did think I COULD go a little bit faster on the heavier section and it would have been more happy...but a little help with the pulley and it was fine)
Brought it home. Wiring is not a problem, so I pulled a 220 leg, threw in an outlet, replaced the plug end to match the available outlet configuration, plugged it in. Motor came on, but hung (no rotational sound) and then burned a fuse in the switch box (on the machine). Spent days trying to FIND the 2.5x220 slow burn fuses, did, also found a loose screw on a negative connection within the motor as I was waiting to get the fuses (figured it must have gotten jostled in the move?). Ran thru everything logical w my voltmeter, everything looks good all the way through, fired it up... Again with the sound of the motor trying to turn without actually going....
So I am back to disengaging to clutch and turning the wheel by hand...which is at least easier on the hands than saddle stitching the chaps I've had on order for WAY too long!
Is there anything else I might be missing with the motor that worked -perfectly- (and it was so quiet!) less than a week ago? I am so frustrated and just want to get to work in the finite amount of time I can dedicate to this... I'd much rather be up half the night working on my PROJECTS and not my machines :(
Thank you in advance for your time-
"Everyone is going to die. Not many will choose to live"
I would rather risk sounding like an idiot and get this machine running...
It is a pretty standard 220 plug. I wired my exhaust fans in my paint booth, my welder, my dryer, and my range- all of which are 220 and work fine. For the sewing machine, I was a little lazy and pulled a pig tail off my dryer outlet, and installed another 220 outlet in my utility room. The machine then plugs directly into the wall.
The key is still that "3 Phase" you mentioned. You can not run a 3 Phase motor on standard Single Phase 220 voltage that 99.9% of households have. 3 Phase is a commercial voltage and is only avaiable special order
You can buy a convertor to make it work but last time I checked they were $400 - $500.
Tom
3 phase motor should have a 4 prong plug 2, 120 volt 1, 208-220 and 1, neutral. You will need to buy a single phase motor.I would get a servo motor. You need to talk to some of the dealers on this site. sounds like your problems are the machines but the people you are getting them from.
  • 3 weeks later...
For $117.00 shipped, you can get a VFD (Variable Frequency Drive) that will convert your 220 VAC 1 ph input to 220 VAC 3 ph output to the motor. It will also give you speed control of the motor, I just put one of these on my Singer 153 W... but have been using them for years, installing them in factories and mills requiring motor speed control and 1ph to 3 ph conversion.
Here's the link: http://www.automatio...0_VAC)/GS1-20P5
If you decide to get one and need some guidance in hooking it up, contact me. I hope this helps.
Gerry
pcox,
The 4 wires have 220 (nominal) between any two of 3 wires, and the 4th wire is ground; no 120 VAC in a 220 VAC, 3 phase system.
Edited by GerryR
I believe you are correct about the voltage readings, IF you read between the two terminals. When you read from ground to the terminals it is a different story.
I have a 40 horse phase converter in our shop. Actually the three phase voltage is 260 Volts with no load in our set-up. I have a 220 Volt single phase sander tied to the two three phase terminals in the fused disconnect that read 120 v each, to ground. The sander is obviously grounded. This connection gives me a 220 v single phase. I can also connect to one of these 120v. terminals plus a ground to run anything requiring 120v. single phase.
The best "fix" for this problem is.....buy a Servo Motor that is 120 volt single phase. Such as one Bob Kovar sells at Toledo Industrial. All of your sewing problems are solved with one simple set-up.
ferg
Edited by 50 years leather
All this discussion below is with respect to AC induction motors.
In a 3 phase electrical circuit, each of the phases is 120 degrees offset from the others. If 220 (normally 208) VAC is the phase to phase to phase voltage, and the circuit is "Y" connected, the centre point of the "Y" (which may or may not be grounded) is 120 VAC from the centre point to any phase terminal. Take the phase to phase voltage and divide by the square root of 3 (which is 1.732) to determine phase to neutral voltage.
Delta connected 3 phase equipment has no neutral; "Y" connected has a neutral centre terminal, though it might not be visible or connected externally.
Wikipedia probably has diagrams showing circuits and electrical wave forms if you want to delve further into 3 phase circuits.
Normal North American 220 VAC household or residential circuits are single phase. The centre tap in the transformer is grounded neutral, so you have 110 to 0 to 110 VAC, or 220 VAC across the outside terminals.
For single and three phase circuits, you should try to balance the loads across the system.
And by the way, if power is lost on 1 phase of a 3 phase circuit, motors may continue to run, low on output power, and overheating. This is called single phasing. Not a good circumstance to be in. 3 phase motors will not start when single phased. But if you spin the shaft, it may continue to run, whichever direction you had spun it. 3 phase motors do not have a starting winding. Single phase motors require a starting winding.
Tom
I made a 220v.3-phase converter out of an old 3-phase motor to run our mill.We had to mount a 110v starting motor on a board & belt it up to the old 3-phase & we turn the 110 on to spin the 3-phase then turn the 220 on & shut the 110 motor off the 220 motor keeps running & will run our mill.
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Yup! That is the principle of a rotary converter. Good job.
Tom
