thesergeant: Those are beautiful tables! Love the veneered table to make use of the leftover pieces - you have some serious shop skills and a great eye for design and color! Now I'm all motivated to give my own Pfaff 130 a nice, permanent home like that rather than being hidden away in a cabinet. Nice photography, too.
cjsamples: I've uploaded the V-Carve Pro file for my Consew 225 table top here: http://uwe.net/CAD/Consew225_v2.crv
You'll have to tweak it to fit your hinge design and corner pads. You'll also have to separate out the top and bottom cutting paths for two shopbot runs.
Uwe (pronounced "OOH-vuh" )
Links: Videos
  • Replies 178
  • Created
  • Last Reply
Top Posters In This Topic
Apparently you have access to serious CNC equipment. I am drooling!
Just an update on my flatbed table attachment for my Adler 205. I sanded the whole thing down to make smooth, rounded edges and painted it white. It installs in under a minute and is remarkably solid when attached to the cylinder arm by two countersunk screws, earning it a perfect score on my UCI scale (Uwe's confidence indicator) :)
attachicon.gifIMG_2815.jpgattachicon.gifIMG_2814.jpgattachicon.gifIMG_3279.jpgattachicon.gifIMG_3278.jpgattachicon.gifIMG_3280.jpgattachicon.gifIMG_3277.jpgattachicon.gifIMG_3281.jpgattachicon.gifIMG_3276.jpg
Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
Thanks for the file but my Aspire 3.0 wouldn't open it. I will look around and see if I can find something to convert it so I can read it. When I saw it was a .crv file I was.........Yippee!! then " Code 102 cannot open file".....grrrrr.
cjsamples: Bummer about the file incompatibility. You could try downloading a trial version of V-Carve Pro to at least open the file and look at it and perhaps export to different format, but I'm not sure how limited the trial version is. I could send you the ShopBot code text file, but it's not really editable. I created the file in V-Carve Pro, so I don't really have another CAD version. Perhaps I can export to some standard AutoCad style DXF file, but I doubt it would not have the pathing info, which is important.
DrmCa: Yes, I do have access to very cool and wickedly expensive tools, but only if I pay my $150/month membership fee at TechShop (which I can afford only once every couple of months, unless people actually start buying stuff I make there, haha).
Links: Videos
I did download the trial version and it is pretty locked down as far as things you can do. I found a dimensional drawing from Juki for most of it but my machine has round attach points in the back so I will need to modify the file a little anyway.
I can set the run paths if you can export out a dxf file, I have a router here at the house.
Thanks, Chris.
  • 2 weeks later...
Talk about overkill, you guys are dreaming up something that is totally unnecessary.
If you wish to make a top with laminate as a finished surface, obtain a piece or 4 x 8 foot sheet of particle board 1 1/8" thick. You can build an under carriage/leg set from 2 x 4's you can buy at Lowe's or HD if you like but the "H" set of legs available that are made for this purpose, I know your wife thinks they are ugly, has everything where it is supposed to be with no interference when you mount a motor, cut a belting hole, etc. You think that 11/8" particle board isn't heavy enough? I have three of them and I see absolutely no problem with any of them.
IMHO, Buy the "H" leg set and cover it with something that makes it look Industrial if you will.
BTW: If I put a table under one of my machines with that black pipe for legs my wife would make it disappear. LOL
ferg
Even better than p board, go to masonry products supplier and buy 1-1/8" form ply, way more stable.
Better yet, can order adjustable leg set and butcher block from Grizzly for around 300$ and all you need to do is wait for the delivery truck with your screw gun in hand...,
When in need, I watch Craigslist for a homely example of a table that has the cutout ready for my target machine....you can often find a sound, straight but *ugly* top, complete with a K-leg stand (and even a used machine!) for close to the cost of your material list. I have bought damaged full sheets of Formica HPL for $8 to $25 from the local builder's supply, which can cover as many as 4 standard sized tables, depending.
A "laminate trimmer" router bit, some bondo if needed, flooring sandpaper, and a bit of contact cement puts you in business. I don't expect to see it on the cover of any magazines, however.
post-46726-0-38520900-1448811114_thumb.j
post-46726-0-98407900-1448811115_thumb.j
-DC
Machines: Juki LU-563, Consew 206-RB5, Singer 20U33, Pfaff 481, Mitsubishi CU-865-22, Consew 29B, Rebadged Juki LU-562,  Mitsubishi LS2-180,  Seiko SK-6, Juki LG-158-1
Sark, I'm guessing that the second photo is the "before"? Either that, or you've gone overboard with the "used look". :rofl:
My three used tables are a bit the worse for wear. I toyed with the idea of refurbishing them, but decided it was more trouble than it was worth.
Your idea of picking up a cheap one is actually a good one, and as you point out could be less than the materials required to build one from scratch.
