Evo160K Posted December 29, 2018 Report Posted December 29, 2018 Really enjoy following your work, Jimi. You and some of the others are an inspiration. Makes me question my decision not to restore any more machines. Quote
Members jimi Posted December 30, 2018 Author Members Report Posted December 30, 2018 1 hour ago, Evo160K said: Really enjoy following your work, Jimi. You and some of the others are an inspiration. Makes me question my decision not to restore any more machines. Hey Al, how ya doing. Thanks, but that was nothing compared with yer overhauling of those 45ks Quote
Members Scoutmom103 Posted December 30, 2018 Members Report Posted December 30, 2018 Very nice. Thank you for all the pictures. Quote
Members dikman Posted December 30, 2018 Members Report Posted December 30, 2018 Nice one. Looks like you got a good one there jimi, mostly surface rust and dirt! That accessory plate looks like a neat idea, lots of holes for attaching all sorts of things. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members jimi Posted December 30, 2018 Author Members Report Posted December 30, 2018 20 hours ago, shoepatcher said: The best machine now is the Adler 669 of which I have one That looks like a good modern 69/335 looking machine there Glenn. I am sure that costs an arm and a leg and maybe another leg.. but if it is well made then it will last for ages, that we know. Seems like in the photos of it, it has two tension units?? is that correct??, Jimi. 20 hours ago, ensitmike said: This is so awesome. I want to do this to a Singer or Adler patcher, hopefully soon Hi Mike, thanks, your patcher will be a different ball game to this. there are a few posts on the patcher machines on this forum. here is one but it is not as extensive as this post. All the best and good luck, Jimi. Quote
Members jimi Posted December 30, 2018 Author Members Report Posted December 30, 2018 12 hours ago, Scoutmom103 said: Very nice. Thank you for all the pictures. No problem scoutman and thanks. 10 hours ago, dikman said: Nice one. Looks like you got a good one there jimi, mostly surface rust and dirt! That accessory plate looks like a neat idea, lots of holes for attaching all sorts of things. Hi Dikman, yes not a lot to do to this one, and the plate as usual came with no screws, but i tried the singer thumbscrews and seemed to work in a couple of them so it must be ??? oh cant remember the thread ??? 11/64 ??? Quote
Members shoepatcher Posted December 30, 2018 Members Report Posted December 30, 2018 Great job as usual Jimi. You want to get the correct needle clamp screw as the one you have is sticking way out and that can be a problem if you are sewing something tight. You ever put the correct wing screw and locking clamp on the base plate you made on the on the older 335 you restored? . If Pfaff parts are to expensive for the Pfaff, go to Consew wingnut, clamp and screw from a 227 on the Pfaff. glenn You can get generic feet for the latest 335 you are doing cheap on eBay or College Sewing. glenn Quote
Members shoepatcher Posted December 30, 2018 Members Report Posted December 30, 2018 (edited) And yes, I have gotten needles with a sharp edge or burr in the eye. It does happen. Also, new generic bobbin case for 335 are fairly cheap to buy. glenn Edited December 30, 2018 by shoepatcher Quote
Members jimi Posted December 30, 2018 Author Members Report Posted December 30, 2018 2 hours ago, shoepatcher said: You ever put the correct wing screw and locking clamp on the base plate you made on the on the older 335 you restored? No i never put anything on there yet Glenn, i did not feel the need as the belt holds it down well enough. I could easily make one up from some steel plate but never got there, also i have seen them on Aliexpress i think??, it was cheap also. i did get feet and a couple of bobbin cases with bobbins there also but one has already popped the latch so they are not the best but okey to get you going until something better comes along. the feet are real tight also, not a good fit. I don´t know if college would have good fitting ones either?? they look like the same ones on Aliexpress?? I always try to find cheap original used parts if i can as they should work first time and no problems. As long as they are not to worn and that is where sometimes you take the gamble. Thanks for the info glenn. Regards, jimi. Quote
Members shoepatcher Posted December 30, 2018 Members Report Posted December 30, 2018 One thing you may not know Jimi is the 335-17/B is a binder machine yes but it is a symmetric feed binder. To make a it that kind of binder, you must use the cover plate the moves. If not, the old plate with all the holes makes it a no binder machine or one you can install other items on that plate. Symmetric feed binders are more rare and work better. glenn Quote
