Members Rick54 Posted March 29, 2017 Members Report Posted March 29, 2017 I'm considering a machine after doing hand sewing. The projects I'd be doing are wallets, purses, belts, and knife sheaths. The machines up for consideration would be either the Cowboy 4500 or Boss. Unfortunately, I'm not reading many "fantastic machine" posts regarding these machines. What I have been reading are about problem issues with each of these machines, and how they seem to be very temperamental. I know nothing about sewing machines, and the wife has already informed me I will NOT be attempting to use her sewing machine. So I'm depending on you folks for the straight skinny on these two leather machines. Since I doubt I'll be doing high volume production, I'd like you're thoughts on how steep and tricky the learning curve is for these machines? Perhaps one should save themselves a big headache and just stick to hand sewing, your thoughts? I'm sure many of you are thinking, if you're not doing high volume, why are you looking into a machine. Well, I've worked and saved all my life, and now that I'm retired, I'd like to enjoy MY savings a little before the nursing home enjoys it ALL! Quote
Contributing Member JLSleather Posted March 29, 2017 Contributing Member Report Posted March 29, 2017 (edited) 25 minutes ago, Rick54 said: oing are wallets, purses, belts, and knife sheaths Often, the leather used in wallets and the leather used in sheaths is not the same thickness (or perhaps not even same type). HERE lies your question... what WEIGHT and TYPE of leather would you like to sew? AND, the material and thread size you want to use will [somewhat] define which machine you'll want. My opinion: Forums, including this one, are perhaps not the best source of information / reviews about equipment. And that includes me -- I'm NO sewing expert. At all. Often what you will see is someone asks a legitimate, sincere question - and instead of a reasonable answer they get opinions and conjecture (though it's often presented as factual information). My recommendation: Look for a machine in your area. This is BY FAR the best approach. Take some leather with you to see the machine work, and see it work with teh leather YOU intend to use. If that's not doable, and you can't talk with someone you know (or at least can see), then were it me I'd CALL BOB. Based on your location, and my own conversations with Bob, I'm confident he can fix you up. Just let him know WHAT you want to sew (tooling leather, garment leather, upholstery, etc) and teh approximate weights you'll want to work with. I will say that if you want to make wallets (on the thinner end) and sheathes (the heavier end) I would say that MOST people 'round here would recommend thread size from about 138 to 277. And one final note of common sense.... if another member goes by the name of WIZ pops in and disagrees with anything I've said --- go with what HE said I have been reading are about problem issues with each of these machines, and how they seem to be very temperamental It's possible that some are looking for ONE machine which will perform well in every situation. Tough to do with anything, though. I mean, at one point I owned both a dump truck and a sports car. While both quite good, neither will do the job of the other. Edited March 29, 2017 by JLSleather Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
bikermutt07 Posted March 29, 2017 Report Posted March 29, 2017 Ha! Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
Northmount Posted March 29, 2017 Report Posted March 29, 2017 If you are thinking about a Boss, you need to realize that you can only use one hand to guide your sewing. The other has to be on the lever to make the stitch. So the more finicky the project, the harder it is going to be. One machine to sew from say 3/16" to 5/8" inches thick material without having to do a bunch of re-adjusting between projects just isn't going to happen, especially for a new user. Tom Quote
Members Gregspitz Posted March 29, 2017 Members Report Posted March 29, 2017 the more company support you have for the machine you buy the shorter and easier learning curve. Buy the Seller! I have 2 Techsew machines and could not be happier with the machines and the support. I do wish someone would have been around to teach me but the process now that I look back on it was necessary to know how to do things. The good companies will help you pick out the correct machine for you. Let us know what you do! Quote Greg Spitz MD,FACS Custom Watch Straps 922Leather Gregspitz@922Leather.com
Members MadHatter Posted March 29, 2017 Members Report Posted March 29, 2017 the Cowboy, or any in that class, will do a good job for any projects you mentioned but will require changing adjustments for lighter any heavier threads. I use a CB4500 along with a JUKI LU563 for lighter 69 to 138 threads. Each should have the newer type motor controler for much smaller learning curve Having both is the way to go. Your wife's machine sewing skills may help you cut down your learning curve :-| Quote
Members brmax Posted March 29, 2017 Members Report Posted March 29, 2017 I would consider a bit more towards the machine with a pulley wheel. Good luck Floyd Quote
Members TacticallySharp Posted March 29, 2017 Members Report Posted March 29, 2017 I used the Cobra 3. Yes I have to adjust it based on what I'm doing which is the same as you listed plus holsters. Basically two settings cover everything I do. Steve at Cobra may even have a unit which he took on an exchange for a new one. Quote George Tactically Sharp, Inc. Hialeah, Florida tacticallysharp.com "time only is forever"
Members eglideride Posted March 30, 2017 Members Report Posted March 30, 2017 Rick54- I like what you said- basically you can afford a machine, Cool. I bought one because I knew I would never sew a rifle sling, belt or guitar strap by hand. No interest in it what so ever. I am not into "production" at all really. I have one because I wanted one. The machine does make it possible to do more things that I do enjoy. Also, I like the "mechanicalness" of the sewing machine...find it fascinating. I will hand sew from time to time..when it makes sense (read, because I have to) Enjoy the adventure! Do purchase from one of the advertising supporters of this forum- Gregspitz is correct- buy the seller! Great way to put it!!...I went with the CB 3200 and Cowboy Bob FWIW...great experience. JLS and Wiz are huge resources (although JLS left Iowa and moved NORTH for some crazy reason, so he is suspect) do a lot of reading on this forum...watch you tube videos...then jump in! But hey- I am just a hobbyist... Best Quote
Members Rick54 Posted March 30, 2017 Author Members Report Posted March 30, 2017 Thanks everyone for the input. eglideride, I like the way you think! Quote
