I recently (one month ago) got a Cobra Class 4 machine and I haven't been able to get it adjusted correctly yet.  Is there a troubleshooting guide out there that shows pictures that say if your machine is doing this then try this?
I did 3 passes the first two left to right and the 3rd right to left.  I changed the needle between the first and second pass.  Thread size 277 needle size 25 (passes 2 and 3 with S point)on a single layer of 12oz saddle skirting.  The back side looks pretty good but the front looks awful.
First of all, 12 ounces is really light for #277 thread. It is hard to hide the knots that are fairly large, as you can see. But, the knots should not be changing altitude in a continuous stitch line. Something is intermittently letting go or tightening up and causing the knots to move up and down. Let's consider the usual suspects. Investigate these one at a time until you identify your culprit.
  1. Improperly wound bobbin, or bobbin inserted feeding the wrong way. Try reversing the bobbin orientation.
  2. Thread fragment under the bobbin tension spring business end, causing the bobbin tension to drop as the thread feeds past the scrap.
  3. Out of round bobbin ends
  4. Moving up ^^^ top thread is over-bonded and comes off spool like a coil spring, changing its tension as it feeds or binds along the path, then lets loose.
  5. Top thread not staying centered in the top tension disks, thus changing the tension. This can be caused by twisty thread.
  6. Needle too big for thread/thickness combination. Try a #24 needle.
  7. Thread too thick for thickness being sewn, Try #207 thread instead, with a #24 needle
  8. Top thread flipping over guides or rollers on the way to the needle.
  9. Rawhide or weak sections in the leather can affect the stitches.
It is obvious that the problem is too much tension on top and not enough on the bottom. You might solve the problem by tightening the bobbin tension screw a bit, then compensating with the top tensioner. This is a big boned machine that doesn't mind being rode hard.
Posted IMHO, by Wiz
Okay, I tried a few things.
1. Bobbin was good.  Cleaned to bobbin case and checked for foreign matter.
2. Adjusted holder moved cones up higher and made sure it was coming straight off the top.
3.  Used different thread and needle sizes.
4.  Loosened the presser foot chain.  I noticed it was pulling a little when machine was running.
Passes 1-4 on 14-16 oz saddle skirting.
Pass 1 is size 24 needle with 277 nylon thread for top with 346 nylon thread in bobbin.  Pretty pleased with top.
Pass 2 24, 277, 277.  Pretty pleased stitches are a lot more uniform.
Pass 3 size 24 needle 207 polyester top and 277 bobbin.  Fairly consistent but bubbles pulling up from bottom.
Pass 4 size 23 needle 207 poly top and bottom.  Consistent but bubbles showing up on top
Pass 5 and 6 on 10 oz saddle skirting.
Pass 5 size 23 needle 207 poly top and 277 nylon bottom.  Consistent bubbles on top.
Pass 6 size 24 needle 277 nylon top and bottom.  With bubbles on top.
The upper tension is as loose as I can make it.  Still skips some stitches on reverse.  I''m sure all is just operator error.  Any suggestions are appreciated.
Don't want to beat a dead horse, but if you did everything you saId and are still getting the bobbin pulled up like on pass 6, then there has to be a bind somewhere in the thread track from spool to needle.  A silly question, but are you sure you threaded the machine correctly?  What you are experiencing is quite common with the thread track from spool to needle hanging up on a screw, or an unintentional extra wrap around the secondary tension on the way to the take up arm, or a little bit of bind going through the last "screw" loop or the last hole before the needle.  I have had similar temporary problems, but they all traced back to pilot error and a bind somewhere in the thread track.
I know it's frustrating.  I'd give Steve a call and see what he might suggest.
Good Luck
Paul
Paul long-----108 Briarwood Ln. W-----Kerrville, TX--78028------830 367 5536-- pfl@cebridge.net
You are reducing both top tensions? It is common to run a next size thread smaller in the bobbin than the top or the same size but I don't think I've heard of running a thicker on the bottom before. Consistency is at least a good sign.You may need to tighten the bobbin spring on the lighter threads a bit. Brian
YouTube Channel
Instagram
I think the first two stitch lines are working better. The idea to use a bigger thread in the bobbin than top has my interest in why.
Im curious is the bobbin tension screw still adjustable. Not to make a change at this time in your test, just the question.  A reason I ask is you mention the top tensions being at their minimum setting.
I know these 441 types are heavy duty,  I have been curious if top tension springs are an option some have changed.
Good day there
Floyd
Everything seems to be coming off smooth without hang ups.  I checked and I am threading correctly based on a couple different sources.  I am sure it is pilot error.  I tried to call Steve on Friday but no one was in the shop when I called and it is usually after hours when I get off my regular job.  I have been sending him photos as well.    Early on I ran it for a while with only one wrap around the primary instead of the recommended two.  It worked okay but is not as consistent.
I am reducing both tensions.  Running the larger thread on the bottom leaves the back raised a little, it doesn't look as good as it should.
I will check the bobbin screw again and see if there is any adjustment left.
Wiz, Paul, Wild Harry and Floyd thanks for your responses and ideas on what to check.  I think I''m getting closer to getting things adjusted.  Hopefully there is still a little adjustment in the bobbin and it will all look good.  I'll check a few more things and test it again.
Thanks again to all!!
Here are more results from this evening.  I adjusted the bottom tension a couple of times but when I tried to tighten the top a half turn bigger bubbles showed up again.  The test leather started to drop off a little in weight.  With the smaller thread the tension is pulling the knot out the top still a little.  It is much better than when I started.
Yes,it's looking better BUT ,I always tell people when your checking tension to make sure your leather is thick enough for the thread,so you should try the larger thread on 2 layers or the thickness of the project you plan to sew.And practice alittle on that thickness before you try sewing on a piece that has tooling & is cut to size,it a lot easier than pulling out stitches or possibly having to start over.
You can see that's why the 277 & 207 combo looks better than the 277 & 277 the thinner thread on the bobbin helps to hide the thread therefore making your stitch look better as you get into thicker the 277 & 277 will look better.I know a lot of people always run a size smaller in the bobbin when they are sewing on  thinner leather.277 is best when your around  3/8" & thicker the knot hides better.
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
I did this late last night before I saw Bob's comment.  Anyway this is 2 x 8 oz (16 oz) leather with 277 on top and bottom.
