 The type of construction of this holster - what is it called?  It looks simpler to make than the typical double layer holster construction.
What would be the disadvantages of this type of construction?
Edited by SouthernCross
Add picture
Might want to post the pic directly here.
I won't pay photo bucket a penny to view photo's they post.
Expand
Biggest disadvantage is over time the single layer wings will get floppy ane sloppy, . . . not hold the gun up like it should.
AND, . . . there really is no ADVANTAGE to it other than having saved a few square inches of leather, . . . that would probably not be used anyway, . . . just because of the way it is cut.
I would not make one like that for myself, . . . and a REALLY would not make one for a customer.
May God bless,
Dwight
www.dwightsgunleather.com
I can see where it would work with something like an LCP or Kel-tec, but not for something larger/heavier. If the back piece was thick enough, it wouldn't get that floppy, but then if you were going to go that thick, why not just do the two full size layers?
I did make an OWB for my LCP, just because I could, but I'll never use it. If I'm going to carry OWB, I'll carry something more substantial.
So much leather...so little time.
 Not to be a critical snob but thread is way small for the holes which look like they were drilled out or punched single layer like as said before would not be coming off of my bench unless it's IWB small of back, period... floppy holsters lead to possible disaster. That one is unsafe in my opinion get it wet and its a done deal...
  • 3 months later...
I believe this is called a pancake style holster
If you can live, thank god
If you can read, thank a teacher
If you can read this in English, thank a veteran
May God Bless,
Carson of C Hangin Diamond Leather and Catte Company
Expand
No, no it's not.  A pancake is going to be 2 layers for the entire holster, not just the holster pocket. It adds considerable stiffness to the holster, which this one will lack.  It's someone trying to "improve" on a pancake and answering a question no one really asks.  This is a pancake, flat back pancake to be exact.  The difference is in how much leather is used, and how it's used.  The holster above puts the grain side to the gun, which could be done by making a lined holster but it takes more time and effort.  And the above is also pointless because the outside leather is flesh in anyway, so what's the point?  Meaning it's only "lined" on one side,  not both.  It just looks like it's lined.
Edited by chiefjason
