This is my first production run on these wedding ring boxes so for future reference I am a taking a heap of pictures as I go.
Due to a few rush jobs I have now only one week to get a minimum of 44 of these done. Many are pre sold and I don't think they
will be happy if they don't arrive for their wedding. :(. Details may get a little sketchy as I go.Just ask if you're interested.
This picture shows the cups I designed being printed on a second hand $400 au printer I bought.
Actually they come apart to look more like this picture. The large one at the back left is a sander to clean up any roughness inside and outside the cups.1f.JPG1g.JPG
Placing the sandpaper part into the cup and spining to remove roughness.
Same thing for the cup outside. After this step the cups should all be ready for gluing up.
Next step is cutting the leather parts and splitting them to the correct thickness.
  • Replies 55
  • Created
  • Last Reply
Top Posters In This Topic
Following are a few more of the steps I've done today.
Here I am splitting the leather to about .6mm. these pieces will be used where the cups come together in the middle. I did it this way as I did not want any joins at that part.
Here I have elected to use spray glue to save time. They could be done after the next stage of cutting but I found it a bit fiddly to hold and glue.
At this stage when they have tacked off well they are ready to have their second cut.
This picture shows how I have used a clicker press to do the cutting.
Yes! Keep the pics coming
Those are beautiful!  I think I need to invest in a 3D printer for some of the ideas I have... :D
Edited by verus22
Will do:).Time to see some more of yours I reckon.:thumbsup:
I can only say I wish I had this technology around 20 or more years back. The ease that so many different projects can be brought to real life is truly amazing.
Following are a few more pictures for today. Picture below shows gluing the inside and outer side of the cups.3a.JPG3b.JPG
Here I am pushing the ring cup completely through the ring jig to tighten the outer edge.4g.JPG
Note the inner leather is still loose and now goes down onto the next jig4h.JPG
Here I use a holding tool and spin the inner jig out. This creates pressure and heat and helps the contact glue to stick well. (and it does)4j.JPG
Presto :thumbsup: more to come
This is awesome.
+1 to that
Didn't quite follow that at first but I got it now. For some reason I thought the cup itself was part of the jig haha. Silly me. Is it just a glue down construction?
6 hours ago, bikermutt07 said:
This is awesome.
Thanks but I wont say that until i finish them. Couple of hick ups today.
Yes they are all glued down construction and as I found today very well glued down construction. You have to rip the leather to get it off. I did one to many tops which meant I had one base short. I started with too many but then more orders caught me out.
All attached in about 5 minutes. Now to prepare the leather for tops and bottoms.7a.JPG
The next step is skiving. I decided .5mm at edge tapering in about 13mm7m.JPG
I've done one of the other colour to show you the skive better. More to come
At this stage I decided to test a couple and make sure it works alright. Better than making 88 wrong and find out.7e.JPG
Leather fits in Ok
Guiding ring placed
Note that the soft leather has crept up over the ring in the middle. This is a problem.7l.JPG
I quickly redrew the guiding rind to be .5mm larger in the hole size. I set it printing next as it will take about 45minutes to complete. 7o.JPG
The new ring worked good and I got the tops and bottoms done in around 90 minutes I think except where I got my counting wrong.:unsure:7r.JPG
As you see the contact works awfully well on this PLA stuff. More tomorrow
Edited by RockyAussie
The text went out of order
Thanks for the pics! They remind me of macaroons. :yes:
Thanks for posting, this is great to see.
Your welcome, I had to look up Macaroons and they do look similar but I think they would taste much better. Certain aisles I am not allowed in on the rare occasion I go shopping with the missus.:unsure:
22 hours ago, Matt S said:
Not sure if this is genius or witchcraft. Either way the results are beautiful.
If only I could just wiggle my nose and there they be I would be so happy. As for genius my wife is still laughing and I do gotta admit I should have done a couple of more samples before starting this run. I agreed to do a rush one for today for a wedding this weekend. NOT GENIUS. I got it done alright as promised but found I had to come up with another tool to expedite the velvet application to the foam process. That is the pictures I will load next.
Thank you Bob. I think I will have to tidy this post up a bit and redo it. I might think about doing a video on one if a few people think so as well.
The following 9 pictures are limited to how I do the velvet and foam parts.F1_resize.JPG
This above shows a knife that I had made for doing the cutting of the foam. This could be done with just a hole punch and cutting through with a knife later as I did on my prototypes.
Note here in the close up I used two foams that I glued together and then covered with this white fabric. This was necessary to get the right depth and the fabric is because the green shade of the foam showed through on some lighter coloured velvets.
This picture shows the velvets pre cut now and the cardboard rings to hold the foam in shape in the bucket behind.
This shows a few of the stages of the foam being attached to the fabric. Just a thin glue line in the middle as yet.
Here are some now glued and pressed into shape. The three on the left are contact glued and drying off ready to get to the next stage
This one shows the new ring I did that helps the pressing into shape.
As you see when it presses down it nicely contains and shapes the velvet.
That's this part finished ready to be inserted later as seen in the following box I did today.DSC00699_resize.JPG
Yes it had to be monogrammed as well. More on Friday. Brian
wow, they looks so so good. thanks for sharing !
I'm always amazed by the level of craftsmanship and detail that goes into making something like this. It is just fascinating!
I get as much of a kick out of the tools and jigs and creations than the end products! even when I am making things myself. Like living in an episode of "How it's Made".. I love process engineering.
Very nicely done. Your skill with fabrication always amazes me! -Adam
Would love to see a video of the whole process Brian. I'm sure plenty of others would as well
I second that. Looks like a mesmerizing process
Third vote on that!!
Keep the pix coming! this is great!
While a lot of the 3D printer world are printing out Star Wars ships, and vases, you are using the 3D printer as a proper tool.
As a mere amateur in the 3D printing world (I print out basic forms, guns, and bullets, amongst other stuff), you are right in there getting on with it.
Very nicely done, having the tech sure makes that look pretty quick.
