Members MarkInKy Posted January 29, 2018 Members Report Posted January 29, 2018 (edited) Hello all, I'm new to leatherworking still and have seen this diamond pattern hatched thingy on phone cases and book covers. It looks nice and kinda classy but I don't know what it's called! I'd like to get some tips on tooling it so I don't make any stupid mistakes. Lord knows I make plenty of mistakes! Anyway, does this diamond, square, block design have a name because I don't know what it's referred to:-) Any carving/tooling tips would be appreciated! I take it this book cover had resist applied and then some antiquing to make the "crosshatch" diamond pattern (and other tooling) pop? Maybe olive oil, then resist then antiqued? Thanks in advance:-) Mark in Northern KY Edited January 30, 2018 by Northmount added tags Quote
bikermutt07 Posted January 29, 2018 Report Posted January 29, 2018 I don't know what it's called. But it is made with a swivel knife and a seeder. Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
Contributing Member fredk Posted January 29, 2018 Contributing Member Report Posted January 29, 2018 I would call it 'Lattice Work'. Bikermutt has said it I was just reading a 'How do I......' on this just the other day. Some cut the lines first then stamp with a seeder, whilst some mark the lines, stamp with the seeder, then cut the lines between the stampings. Yes, looks like a resist first then antique applied Quote Al speling misteaks aer all mi own werk..
Members TSes Posted January 29, 2018 Members Report Posted January 29, 2018 I don't think it has a name, other than a diamond pattern. The easiest way to do it is by using a round awl. Draw the square shape first, then connect the corners to make a big X using the awl. Lay the awl down pretty flat so it doesn't scratch the leather when you drag it. Then lay a 1" ruler next to the line, and make the rest of the lines all the way to the corners. You might want to practice on some paper first, and adjust the spacing so it looks correct your project. You can use a swivel knife if you want, but an awl does a good job. Then use the seeder at all the line crossings. Use a small seeder so it eliminates the small x inside it. Quote
Members MarkInKy Posted January 29, 2018 Author Members Report Posted January 29, 2018 Okay, Maybe we should name it... Diamond Lattice! Sounds good to me LOL. So I guess one would start laying down the 2 longest line first? Then determine spacing distance from the longest lines and draw one line at a time moving outward from there. Based on the fact the longest lines go perfectly into the corners it looks like the maker of this one must have began with those long lines:-) Thanks! Mark Quote
Members Mattsbagger Posted January 29, 2018 Members Report Posted January 29, 2018 A lot of people call it a quilting pattern too. From what I've heard. Even spaced straight lines cut with a swivel knife and your seeder of choice. Tt one guy he uses a protractor at 30 degrees. Quote
alpha2 Posted January 30, 2018 Report Posted January 30, 2018 Slightly off topic, but not really...Anyone remember the old bit about the effect of punctuation on a sentence...i.e, "what is this thing, called love?" As opposed to "what is this thing called, love?" Quote So much leather...so little time.
Contributing Member fredk Posted January 30, 2018 Contributing Member Report Posted January 30, 2018 yup, remember that and the book 'Eats Shoots and Leaves' all about such Quote Al speling misteaks aer all mi own werk..
alpha2 Posted January 30, 2018 Report Posted January 30, 2018 Ha! I forgot about that one! Good times. You're killin' me! Quote So much leather...so little time.
