Members Mizzy Posted May 27, 2018 Members Report Posted May 27, 2018 I’ve been trying to fix up this beautiful old machine myself, including the table, but I’m stuck on a feed dog problem. When I purchased it recently it had a broken timing belt and a binding setup on the cylinder arm. The binding was easy enough to remove with a hacksaw (it was welded on), and the timing belt wasn’t too difficult. I’ve ensured the arrows are lined up on the clutch cog and timing plate. I’ve ordered new presser feet, fed dog and feed dog plate. But in the meantime, I’m trying to figure out why it won’t advance material. To me, it seems that the feed dog does the opposite motions as intended. Can someone please have a look at it in action on utube and suggest how I could fix it please? Quote
RockyAussie Posted May 27, 2018 Report Posted May 27, 2018 Looks like its running in reverse This earlier posting might be of help. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members dikman Posted May 27, 2018 Members Report Posted May 27, 2018 Mizzy, probably would have been better if you handwheeled it, it's a bit to fast for me to figure out which way it's going (Brian's obviously got better eyes than me). Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Trevor Baret Posted May 27, 2018 Members Report Posted May 27, 2018 Mizzy, I agree with dikman, it would be better if we could see a slower movement in the video - perhaps by using the handwheel. Having said that, it looks to me like it is going the right way. Can you please take another video with a slower movement? I would be interested to see it again. Trevor Quote "Just love preserving that old black cast iron" Our Current Industrial Singer Machines - 103K; 31M32; 31K48; 31K47; 132K6; 307G2; 17-8; 45K25; 29K58; and more coming... Our Domestic Singer machines - 201K (classic style) with knee controlled motor; 201K (classic style) with hand crank; 201K (aluminium body) with foot controlled motor.
Members gottaknow Posted May 27, 2018 Members Report Posted May 27, 2018 I would recheck your belt timing to start with. Tip the machine back, place your left thumb on the take up lever until you can feel it’s at the very top of the stroke. Then check your timing marks. It’s also possible that the lower belt cog doesn’t have the correct screw in the groove of the bottom shaft, making it appear to be in time, but it’s not. No telling what’s been done incorrectly on a used machine. Regards, Eric Quote
Members Mizzy Posted May 27, 2018 Author Members Report Posted May 27, 2018 Thank you all so much! I really appreciate your advice, I’m struggling here. Quote
Members gottaknow Posted May 28, 2018 Members Report Posted May 28, 2018 Your top and bottom shafts are out of time. Regards, Eric Quote
Members Mizzy Posted May 28, 2018 Author Members Report Posted May 28, 2018 Thank you Gottaknow, that gives me something to work on. Now I know what I need to research and learn about. Very much appreciated! Quote
Members Mizzy Posted May 29, 2018 Author Members Report Posted May 29, 2018 Today I took the timing belt off and started again. Needle bar at highest point and arrow on timing plate aligned with groove on clutch cog. All good. But nothing has changed. If I lived near a repair service I’d pay someone to fix it, but the nearest place is 3 hours away. I’ve read back through all the posts. The one you suggested RockyAussie (thank you) I’ve read several times. Can anyone please suggest a utube clip that focuses on fixing my feed dog problem? Quote
RockyAussie Posted May 29, 2018 Report Posted May 29, 2018 Could you say what town in Oz you are ? There may be someone close that you could talk to. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
