RockyAussie Posted July 14, 2018 Report Posted July 14, 2018 This shows a few of the steps I took along the way as I made this bag. There are 4 bags to be made out of Australian saltwater crocodile skin and to be ready over the next week coming. The background to this is that these four Chinese customers I have done works for previously want to revist Australia and get me to make them each a bag to take back home with them. As this has been done in such a rush some of the bag hardware I wanted to get from Ohio Travel and flashy zips did not get used. AS hard as I tried I could not get my pattern measurements to work satisfactorily as shown below so I decided o resort to some old steps from my shoe making days.The first couple of pictures show the first bag as complete. This following picture shows my first disastrous patterning effort using cad software. Here following I resorted to making up the shape I wanted by gluing and sanding up some craft-wood and then like the old shoe lasts I used masking tape to do multiple overlapping layers around the shape. With the patterns broken down into 15 degree increments I transferred these spacings onto my mould and the masking paper.These marks are for aligning the pieces as they come together. Next the masking tape I removed and l flattened onto my cutting table. This was then attached to an A3 sheet of printing board. I then took a picture directly overhead and placed it into my cad program to trace around and bring to match the correct size. It could be done without this step but I like to have all of my patterns stored together. This next pic shows that the bag now sits flat and I am on the right track. I will post some more pictures later. Brian Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
garypl Posted July 14, 2018 Report Posted July 14, 2018 Brian, that finished bag looks great and I am in awe of your talents, both in pattern making and crafting ability! Looking forward to seeing more about this project and thanks for posting! Gary Quote Cowboy 4500, Consew 206RB-4
Members Sheilajeanne Posted July 14, 2018 Members Report Posted July 14, 2018 So, what did you make the mock-up bag out of? Looks like leather? (But obviously a cheap sort.) Quote
Members Dun Posted July 14, 2018 Members Report Posted July 14, 2018 Beautifully done and explained. Makes me want to try your steps, I should just get some zipper practice in first. Quote
alpha2 Posted July 14, 2018 Report Posted July 14, 2018 Zipper practice. You and me both. Jeff Quote So much leather...so little time.
RockyAussie Posted July 15, 2018 Author Report Posted July 15, 2018 22 hours ago, garypl said: Brian, that finished bag looks great and I am in awe of your talents, both in pattern making and crafting ability! Looking forward to seeing more about this project and thanks for posting! Gary Thanks for confidence vote Gary but to be honest I'd be a lot happier if I could get the pattern right the FIRST time. Camera's playing up a lot but I will keep posting as best I can. 20 hours ago, Sheilajeanne said: So, what did you make the mock-up bag out of? Looks like leather? (But obviously a cheap sort.) The first mock up is a thick a quite firm chrome tan that is not all that cheap but I use a lot of it on a wide range of products like belt backing and alarm pouches etc. The second mock up pattern tester is an oil tan veg or retan I get here called "Jungle" from a southern supplier or "Whisky Chopper" if from East Coast Leather near Brisbane. I picked these leathers due to them being around 2mm+ thick (5+oz) as the croc is very thick to start and getting it sanded down to below this thickness can lead to holes. 11 hours ago, Dun said: Beautifully done and explained. Makes me want to try your steps, I should just get some zipper practice in first. I will load a few tips on the zip in a bit more detail later but I will put a little bit on it here tonight as well for you and @alpha2 To more fully check the patterns and my leather linings and their layout I decided I best make a more complete bag. Some of the croc skins are smaller than others and require some more segments than the larger skins so I also broke up the leather bag into the smaller segments patterns as well. This picture shows the front shaped pocket made up along with the piece for the strap that attaches later. At this stage they have the lining attached as shown in the following picture and have a 1mm foam between them. They have also been edge coated and stitched as well. Lining side below This one shows the 2 parts that make up the back. The lining piece shows the zipper pocket and the outer back leather shows the 1mm foam attached. I will show some more on the technique for this little zipper installation when I do the next croc bag. This is the other side view of the above picture which shows the second pocket on the lining as well. Next I have spray glued the edges to combine these 2 parts. This shows the parts now conecte4d and ready to have the lining edges trimmed down and the line up V cuts put in. This pic shows the top section of the second pocket that will have to be made up in 2 pieces on the bags made using the smaller croc skins. A stitch is done around 6mm or 1/4" in from the edge as shown. This is then glued and tapped down and recut to size. The inner curve part will be edge coated at this stage. Here is that piece connected to its lower lining piece as well as the opposite side of that section that has a phone and pen pocket attached. This section gets ful;ly attached together and trimmed to size again with the V cuts put in as well. This is the gusset bottom section with its liner spray glued and ready to be attached. Note that the outer part has been made from 2 pieces as well. More to come Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members KingsCountyLeather Posted July 15, 2018 Members Report Posted July 15, 2018 That’s a beautiful looking bag. Your explanation of the process is soo helpful to those of us who are new to leatherworking. Thanks. Quote
RockyAussie Posted July 15, 2018 Author Report Posted July 15, 2018 Now the dreaded Zipper ...... After cutting the leather to shape and giving the inner edge an edge coat I use a template to mark a line in 7mm from that same edge. Note that the zip and the leather has had line up marks to get the positioning as accurate as possible. This is contact glued up on the zip and leather. This shows the zip now attached into place Next the leather lining of the same size is attached into place. It has the inner edge edge coated as well. This piece has the zip sewn into place now and to cover the ends I decided to make up some little cover pieces. This will add strength to a part that will have to endure a lot of pressure later. This tab is now glued back over the zip and leather edge and readied up to attach to the bottom gusset section. Here shown are the back and its D and strap attachments as well as the front and middle pockets combined and ready to have the gusset attached to them both. Here the gusset has been connected and ready to have a double lot of stitching on each side More to come soon. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
RockyAussie Posted July 15, 2018 Author Report Posted July 15, 2018 4 minutes ago, KingsCountyLeather said: That’s a beautiful looking bag. Your explanation of the process is soo helpful to those of us who are new to leatherworking. Thanks. Thanks but honestly I have a terrible memory so I just book mark my post and when I have to make another I come back and see how I did it. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
RockyAussie Posted July 15, 2018 Author Report Posted July 15, 2018 Just to finish off this pattern tester this pic shows the front and middle pockets attached to the gusset. Here I did a test with my phone and a pen for fitting. Note that the binder over the edge is a must as the zip will snag a bit if the binder is not attached These next pics show the bag all stitched and the test is a good pass this time. The croc making ones are next to come. . Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
