It's been a while since I've posted to this forum but I figured since I was back that I might as well contribute also so here are some patterns that I drew up/ modified over time. Hope you guys enjoy them! They are all on 8 1/2 x 11 sheets!
WALLET 8 HALF BY 11 SHEET 1.pdf
WALLET 8 HALF BY 11 SHEET 2.pdf
WALLET 11 BY 17 inner parts.pdf
WALLET 11 BY 17.pdf
Edited by jpounders95
Thanks for sharing!
Very nice - thank you for sharing!
Gary
Cowboy 4500, Consew 206RB-4
Thanks. Before I try to make one in paper just a quick question: Dimensions are in inches I presume?
Definitely!  By inspection, metres or cm or mm just won't yield the correct size at all.  USA is still stuck on feet, inches, gallons, etc.  Then in Canada, it depends on when you went to school, or if you had any engineering related jobs.  Some of us can quickly change between British and SI units.  As for paper sizes, we (USA and Canada) are still using British units for the most part, thus you see 8.5 x 11 (letter), 8.5 x 14 (legal), and 11 x 17 (tabloid) as common sizes.
Tom
Northmount, do you have a finished wallet you could show off? That would help me understand how it all fits together!
For the UK the wallet size should be enlarged as a £50 note is 156 mm long and 85 mm wide which leaves very little room at the top, I think other countries notes are also quite large
Mi omputer is ot ood at speeling , it's not me
Well, Northmount is a fellow Canuck, so I don't think the dimensions will need altering... :lol: I think Canadian and U.S. bills are pretty much the same size. Canadian may be just a tad bigger, but not enough to cause a problem.
If the OP @jpounders95 doesn't get back with something in a couple days, I'll give it a go.  I'm what you might call "out of office" for a few days now.
Tom
