On 8/15/2018 at 10:33 AM, JLSleather said:
I haven't yet done it, but I will :innocent:
For the 'clones', I like the idea of a simple piece of wood.  If my drill press hadn't pooped I'd be done ;)  Few things to get organized around here, and then I'll put one up.
I suppose the 'trendy' thing to do is to post all over social poo trying to bilk leather workers into buying yet another item, or plans for an item. But maybe I'll just post a pic and a tip, and you can do what you like.  Note you will need:
  • something to drill with (hand drill might be easiest)
  • small twist drills, 1/8" and 11/64"
  • 1" spade bit (you could do with a 15/16" if thats what you happen to have)
  • ruler and pencil
  • block of wood, size dependent on number of bobbins retained
  • couple of #8 screws x 1" (or 1 1/4")
SO if a fella had a chunk o wood layin' out back the barn, could drill holes through the block spaced a bit like this.  Then chase them same holes with a spade bit (yeah, I know -- somebody wanna git fancy and cut it out with an end mill on a cnc mill.. fine, whatever) 1.1" deep (or 1.250 deep, with a "thumb hole" on the sides of the holes).
Which gonna look a bit like this (go ahead, somebody with all that 3d rendering stuff make a purdy pic ;) )
#8 screw through the two end holes into the machine table to hang it, put the bobbins in and they don't unwind (no tape, no knot, no dust collection...)
5 leather patterns
  • Replies 30
  • Created
  • Last Reply
Top Posters In This Topic
23 hours ago, RockyAussie said:
Pla and a heated bed run at 65 degrees C. The plate is cleaned well with Isopropyl alcohol before every new print.
I gotta try that! Last time I printed something flat and sizeable, it warped like crazy (it was a base for a monitor stand).
Maybe that is just the cheaper filament I bought (produces off-white product, kind of milk color, where previously I used white filament which produced white products).
Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
Filament quality and even different colours can give a lot of variable results so I tend to do mostly work with this silver colour and run it on the hot side. Keeping the room warm can help a lot with that also. I'd like a large Perspex box over the top but that's just another on the gotta do list.:yes:
YouTube Channel
Instagram
Hey Jeff ...you know that's off topic now in this forum?:offtopic: You gonna get us kicked back into the sewing machine section again as there is no wood work section that I've seen yet.:P. I been thinking about your drawing and the only thing that bothers me is the lack of seeing the colour clearly of me bobbins and with my bad shi memory I would not know where the hell I put that colour unless I painted beside the top or something like that. You being into holsters and guns and stuff I came up with this idea I have called Jeff's Bobbin Revolver :gun:  The pic on the left shows both pieces assembled and able to revolve and the pic on the right ...blah blah.
This pdf file below should open in a 3d way if you click on the picture when it opens. Unfortunately there is some little triangle thing you can see that I have to work out to remove maybe. I will give it a trial print tomorrow and let you know how it goes. I would have done it today but the printers been busy doing the new click together zip line up guide and more dam ring boxes. I'll post the zip stuff tomorrow as well in the sewing machine section first. They'll move it for me probably :dunno:
Jeffs Bobbin Revolver1.pdf
:rockon: Brian
YouTube Channel
Instagram
Their is some really clever people on this forum, Wow, what you come up with is brilliant.
Thanks, I love it.
Do you guys upload your creations to thingiverse at all? That's a great place, as they have advanced interactive preview with 3d, and pretty good UI. I just started using it in my other line of business https://www.thingiverse.com/VintageElectronicsInc/designs and found it so easy to use.
I aint fixina make wunna those, but that was priceless -- nice work up get the attitude flowing to hit the gym this morning! ;)  Despite the pixelation, that was certainly hi-res enough for this conversation!
That looks quite a bit like a thingie I had years back for POKER CHIPS,  though I suppose back then it was injection molded (?).  You have a point also about the view -- maybe transparent (or at least translucent) is good.  The "gun 'n' holster boys might just buy that if you make it horizontal and make it "drop out" like a wheel gun cylinder ... :whistle:
Maybe that aint cost effective, though.  But I'm purdy sure you folks got driftwood up there on the north beach.. maybe could pick up a chunk while up there rasslin' them crocs for the next project?@!
Gotta stretch the bones .... 'preciate the talk!
5 leather patterns
Brian, I really like that design, being a wheel gun shooter! If you create the .stl file I'll just HAVE to make one!!
I'm beginning to think your talents are wasted on leatherwork.:lol:
Thanks for that ......I think?? :P. Here is the results of the print out below. Note I mentioned there was a triangle thing hanging out which I was worried about, well I ignored it and it worked out alright. Those that are good at cleaning up this stuff please feel free to do so. I don't generally get these when I draw up and can'r remember the steps to get rid of it. It was faster for me to scape it off with a sharp knife. Clean up time on both pieces was about 1 minute if that.
This first picture is as the stl files will give you without alterations and with bobbins installed ready to shoot.:gun:
It works and spins well and the bobbins are easy enough to get out. I had a failure on my first print which for some reason the stepper motor on rare occasions jumps or misses a step and every thing thereafter keeps printing above on the wrong line. This next pic was that print and it failed about 10mm up Z. As the fill was set at 30% I changed the next 1 to 20% and slowed the print speed a little.
Here I dropped the first print beside the new one once it was passed the same fail point and relaxed again:P.
This pic shows how bad that triangle spike printed out. Not so bad.
When things stuff up I sometimes think there's a reason and I think the failed print made me think of a top cover and I kind of like it and as well it shows if you print the axle piece longer you could place another on top if you wanted. This makes it easier to handle as well. If you are using the Curra program you can unlock the padlock in the scale section and just increase the Z height to make it as high as you want it. I had one off a different project and used it instead and that is why the top hole is not showing in this example.
Showing the double up idea.
Keep in mind that if you do the same scale trick in Curra to the Z height you could shorten the revolver part to make a better lid as well.
As I said this can make the handling and revolving quite nice.
Lastly now here are the stl files.
Jeffs Bobbin Revolver1.stl
Jeffs Bobbin Revolver2.stl
Please post your results and versions here as well.
Woops nearly forgot here a link to another progect you may find useful.
Brian
YouTube Channel
Instagram
Brian, this technology is amazing.  How do you go about learning how to make stuff like this?  Seems to me you have to be a computer programmer to actually create the file?
Thanks again for taking the time to document what you are doing and the great pics!
Gary
Cowboy 4500, Consew 206RB-4
