A ferrule is the little metal neck, usually brass, that is clamped onto the handle to more securly hold the blade of something in.
  • Replies 50
  • Created
  • Last Reply
Top Posters In This Topic
A ferrule is the metal band which goes around a wooden handle just where an awl or chisel blade fits into the wood. Its to prevent the wood splitting
I have two awls - one from Bowstock, I think, which has a narrow blade, about 2mm, and I got a blade only from John James and mounted it in my own haft; this is the more usual wider size at about 3,5mm
They both needed to be shaped & sharpened, which took ages, especially the JJ. I used a medium and a fine oilstone, then a strop, spreading the work over 3 afternoons. Trying to do the work in one go would be tiring and probably not produce as good results
I find I like the narrow awl. I tried Tandy's Craftool Pro Stitching Awl 83020 in their shop a while ago, and have just bought one when they had it on offer at half price
It would be interesting to try a Japanese awl, especially the Craft Sha
I like to think I'm fairly good at sharpening, but recently I tried the Scary Sharpening System - find it on Google and YouTube, and I'm impressed. I sharpened a head knife and an awl blade very well, easily, and quickly. I'll report on that soon in the Sharpening section
I just wonder if the Billin has tried a selection of veg tan or just one piece of very old dryed up leather
Mi omputer is ot ood at speeling , it's not me
I have read and re-read that book many times.  I still do it differently.  I mark my holes with a stitch wheel.  Then I poke all my holes with the leather piece flat on the surface using a  piece of leather and a cutting board to stop my awl from going through to the table.  I have become pretty good at keeping it aligned properly, and it works for me. Then, when I go to the stitching horse, all I need to do is stitch, although sometimes I do keep the awl in my hand in case theres a difficult hole.
I know it's not traditional and I don't care.  It was how I was able to get consistent, good looking stitches on my work.
Now, I have tried a lot of awls by a lot of makers, and I finally found one that is exceptional.  It's not fancy, but it does the trick.  Sharp, but not TOO sharp.  One maker makes them so sharp they cut the leather and that makes for ugly stitching.  Sure, it goes through a mile of leather with ease, but the holes are ugly.  So, the one I have been using and will likely add another one or two is made by LederLouis in Switzerland.  He ships to the states and they are well worth the money.  He makes prepared blades that will fit existing hafts and he makes finished awls with very plain handles.
https://shop.leder-louis.ch/product/Diamond-awl-ready-to-use-45-mm-S/1595
Here's some stitching I was able to do using the methods described above and with this awl.
Hope this helps.  Just a different approach.
Learnleather.com
Mike, very interesting comments and that looks like gorgeous work to me. I am beginning to believe that some form of technique that involves pre punching all of my stitching holes for a stitch line is going to be my preference, at least for what I consider thicker stuff.
Chris, I don't have a "selection" of veg tan. But the stuff I have is fresh from Springfield Leather within the last couple of months. It isn't old and dried out. And hopefully I won't let it get that way.
May I add my bit?
I got these stitching-holes pliers not to long ago and I find them dandy for pre-punching holes. Sometimes in very thick leather they don't cut all the way thru so an awl is handy to open up the hole, or use of a Glovers sewing needle. I have them with 4 teeth and  2 teeth; for the curves an corners. One is stuck on the spi with these but they generally work out fine
Fred, That is an interesting tool. Where did you get it?
I did get some stitching chisels from Weaver. They got here pretty quickly and I got to use them for the stitch lines down the length of my quiver. I found them to be a big improvement for me. I haven't totally given up on the awl but I believe I have managed to prove it is me and not my awl. I asked my son, who knows diddly squat about leather work to push my awl through two layers of 6/7 oz. veg tan. He had little difficulty and didn't even know what he was doing. Didn't push perfectly straight in or anything. My conclusion is that I am the problem not the awl. Guess I will have to work on my awl muscles. Which ones are they by the way.
A word of caution @BillinTR, if you do multiple plies, you have to be beyond careful to either ensure your holes are perfectly perpendicular through all layers of your leather (maybe make a jig tho keep everything aligned?) or that you punch holes on all layers of the leather in exactly the same place on all layers (again, a jig?). This is the entire reason I learned the Stohlman method. It wasn't for tradition or looks or any other reason aside from being able to get my awl through all the layers and get the pointy part to come out the groove I made on the far side. I have ruined some really cool projects by punching through at a slightly off angle and also by being off slightly on my pre-punched holes on multiple pieces of leather. Its doable, it is just tough to get right, especially early on.
Think of making a sheath for a thick bladed bushcraft knife where you need a double welt and you have both front and back pieces of leather on a taco sheath....4 layers of 8-9 oz. No punch in its right mind is going to go through that without a ridiculous fight, and then you have to ensure your angle doesn't change mid punch or else you just made holes somewhere that you didn't want them.
Again, it can be done, but the difficulty gets upped. The Stohlman method takes a bit of learning but I can get my holes where I want them far more regularly than not. It is more forgiving but it costs you in learning curve.
I punch my holes sometimes but usually only on one side to get the holes right and then use the awl to get through the other layers.
In any case, please post pics of whatever you do and keep asking questions and sharing. Inspiration is a two way street :)
1. I got the stitching-hole pliers from a Chinese seller on ebay. They cost under £9.50 a tool. (about $12?)I bought a 4 tooth and a 2 tooth but the 2 tooth one wasn't hardened and the teeth bent so I bought two more 4 tooth ones and ground off two teeth on one. I live in a ground floor flat (apartment) so I need to keep noise to a minimum. Its ok to hammer a bit during the day when neighbours are out at work, but after 7pm its not good - with these I can work anytime
example; https://www.ebay.co.uk/itm/New-4mm-Leather-Craft-Spacing-Stitching-Chisel-Hole-Punch-Piercing-Nippers-/301787381110?var=&hash=item0
Check out different sellers. I got mine for under £10 and I've seen these for as much as £80 - they all come from the same factory
Also; be aware Tandy does or did something similar, but those are for lacing, they make 3mm (1/8 inch) holes 3mm apart. These stitching pliers gives about 6.25 stitches per inch
2. Try backing up the leather with a block of cork in your hand. You can get a good sized block of cork in a hardware store, for wrapping sand paper around. It can be cut down to a neater size
battlemunky, I posted in the Critique My Work section. Maybe I should have posted here but most forums don't like double postings.
Thanks for the info guys! That is a cool pliers.
Expand
it works for me.  I'm not knocking the purists and I use exactly the Stohlman method for the rest of the stitching, including holding the awl to open difficult holes.  I just find I get good consistency this way.  Now this would be impossible sewing a cantle binding on a saddle and you'd HAVE to do it the other way, but I don't make saddles.
Learnleather.com
  On 10/5/2018 at 11:34 PM, BillinTR said:
I appreciate all of the comments and suggestions. A lot of interesting information to digest.
First of all for me it is a hobby and I have no anticipation of making any money at it. As a matter of fact as a hobby it can only cost me money. Secondly for those that hinted at me possibly finding the act of holding the two needles and the awl and performing the actions of Stohlman's technique a bit awkward, that is not it at all. My manual dexterity is reasonably decent for an olde pharte. It is purely about the effort of getting my awl through the hole. The awls I have are Osbornes that I got from SLC. There is absolutely no burr to be felt anywhere. I have polished and polished right down to using an ultra fine ceramic stone I use for polishing sears on my pistols. I will continue to work with them.
As I said it is a hobby so it costs me money. And I am on a fixed income. So paying upwards of $75 to $80 for a Barry King awl isn't likely any time soon. I don't need a finely finished cocobolo handle to make an awl work. And I expect that I will here the you get what you pay for preaching. Well if you can't buy "quality" then you have to be willing to work to make it so. In Armitage's video he is sharpening an Osborne awl with a fixed point. He seems to do pretty well with it but I can't say that the awl appears to just "glide" through the leather as some seem to think it should.
I am not giving up because I have a number of things I want to do in my new leatherworking pursuits. I hope to do a fair amount of hand stitching, one way or another. I will get back to my polishing this week end although I am unsure how much better I can get these blades.
Thanks again for all the comments.
Expand
Not discounting your fixed budget issue, a Barry King awl blade is $25 plus shipping.  I think they sent mine first class mail for a buck or two.   I use it in my cheap Osborne awl handle.  Works just as fine as a nice cocobolo handle, just not as purdy!  I think my first Osborne awl blade cost me $12 and several hours over the period of many months chasing my tail thinking I sucked at saddlestitching.  If I knew then what I know now, I would’ve gladly paid the difference.
My offer stands, if the $25 properly shaped, properly sharpened BK awl blade doesn’t make a significant difference, I’ll gladly buy it from you & have a spare.
"Make every product better than its ever been done before. Make the parts you cannot see as well as the parts you can see. Use only the best materials, even for the most everyday items. Give the same attention to the smallest detail as you do to the largest. Design every item you make to last forever."
-Shaker Philosophy of Furniture Making
  On 10/5/2018 at 11:36 PM, zuludog said:
I've just had a look at Crimson Hides website; just Search Google
Made up awls are a bit expensive at $95 Singapore = $68 USA = £52  presumably as the hafts are carefully shaped to fit your hand
But the blades alone are more reasonable at $20 Singapore = $15 USA = £11, so you could fit a blade to your own handle
these prices are before shipping and any import duty
Expand
 been hearing about Crimson Hides.. didnt realise that they are a local (to me) company!...
Edited by canonitr
"Fear not death itself, but how it comes"
  • 2 months later...
Thinking seriously about getting a quality awl but wondering what length of blade you all use for general work, holsters, belts and then wallets?
For flat goods i can work with my shorter blades bit for formed goods where i want the stitch line close to formed part i use a longer blade do the haft doesn't mark the work. Hope that makes sense....
"Oh my God....I beseech thee grant me the grace to remain in Thy Presence; and to this end do Thou prosper me with Thy assistance, receive all my works, and possess all my affections" Brother Lawrence c.1614-1691
plinkercases.ca
Thanks  plinkercases for the reply.
An article I was reading last night suggested an awl blade length of 57mm (2 1/4”) could be used for most work. I follow the Al Stohlman method for hand sewing so would like to be in the ball park for my first blade length to try and then possible purchase of different lengths as my experience develops.
Awl blade size will also sometime limit the length as the thinner blades are not usually made a long for obvious reasons. 2.25 inches is "long" and likely a thicker blade for heavier thread and work.
Best think is just get what you think you will be comfortable with and get stitching then experiment from there.
plinkercases.ca
Expand
Thanks for taking the time.  Looking at the BK awl lengths that are available, they start at 1 1/2". So, I think I'll start with that blade and go from there.
  • 11 months later...
Hey gang!
I'm usually content to admire all your awesome work and soak in your experience.  I'm working on doing it just like Stohlman Illustrates.  Before I knew any better,  I ordered a bunch of veg Tanned Horsehide and commenced producing buscadero style holsters so the Air Cav guys I was stationed with would look cool as heck while flying around Iraq....    I branched out into Askins style holsters.  I made holsters that mostly fit Beretta's, but put out a few for the Contractor dudes' Glocks....   I didn't have much  in the way of leather tools... so I would lay out the stitching lines, then run a groove with a tool from Tandy.  I used a cheap pencil compass with a sheetrock screw duct taped where the pencil goes, the screw went in the previous hole punched and the point of the compass marked the location of the next hole.  Once all the holes were marked,  I drilled them with a Dremel tool in a drill press  set up....   any time I was attaching two layers of leather, I used rubber cement and clamps to put the pieces together, then drilled through  both layers...  I used mostly 3/64ths and 1/16ths  bits.... Then I found your website and started ordering tools and stuff by  mail order from sponsors ads and a touch of google fu, to help my production...   the stuff looked pretty good, and held up pretty well , too...  no one ever brought one back for repairs...    yet ( I always gave a life time warrantee!)
Just thought I'd toss my method out there for grins , and maybe an out of the box solution....
LOL...
And now back to our regularly scheduled thread....
  • 3 months later...
resurrecting an oldie.....
all great comments. in summary: i often do the same as immiketoo. prepunch the holes over a cutting board or similar and then stitch. not always. and. i have tried as the OP stated, to hold all of the tools in my hands as i fiddled with the stitching operation. no can do. i set down the needles.
now, as regards awls, has anyone ever tried making their own? i have done it from old fashioned cut nails - or square nails as some might know them. they are very hard but grind down nicely to the desired shape. and they hold a nice point and stay sharp.
just adding my 2 cents.
A difference in materials; here those square nails are soft iron. Look at it too hard and it'll fold up.
Since this Thread started I have bought an Osborne #42 awl blade & haft. It was quite easy & quick to sharpen the blade; less than an hour on a fine stone and a strop, and the result is very sharp
But mounting the blade in a haft was fiddly and I couldn't get it to go in straight. I ended up drilling the haft and setting the blade in the haft with epoxy glue
If I ever buy another awl it will be an Osborne #42 or #43 blade and one of their hafts with some sort of chuck or collet.
I have used old drill bit to make awls, a little bit of work, but they seem to hole there edge nicely.
Even go deep into fingers without very much effort at all, more careful now.
Bert.
