Members katit Posted December 7, 2018 Members Report Posted December 7, 2018 Seems like there is some kind of virus, after you get one machine you need another So, machine in question came up for sale locally (finally). It's the same as 226R (thanks to this forum). For the price I think it's great even though smaller bobbin which is not a big deal for me as I see it now. But it has reverse which IS a good feature to have. It will have clutch and I am immediately thinking about slowing down and going servo. I started to check ebay and they have motors with positioner at about $150. I think this needle positioner is a bomb for what I do. I always deal with this when sewing. Either raise needle to take work off or keep it lowered to make turns. If it works as I think it does - I'm not even going to be concerned about speed per se. If I can jerk pedal and cause one full stitch that is all I really need. Or something close to that. And then there is a button to control either it works with needle up or needle down for 2 modes. Does it work just like I described? Do all of them work for up or down (with button switch)? Any specific issues/problems with equipping this machine with positioner? P.S. Machine needs some TLC but it works and I got some experience with machines now Quote
Members dikman Posted December 8, 2018 Members Report Posted December 8, 2018 If you're going to slow the machine right down then to a large extent that negates the need for a positioner as you can control the needle position fairly easily. You should be able to set any needle positioner for either stopping up or down, usually the controls will be "buried" in the menu system of the servo, so not just a matter of pushing one button. Some servos may allow you to set the pedal so that if you heel down on the pedal the needle will rise if the default is stopping needle down. Also, be aware that some needle positioners may not work if a pulley reducing system is also used. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members katit Posted December 8, 2018 Author Members Report Posted December 8, 2018 With my Pfaff 1245 I have servo and smaller 45mm pulley. It is slow but I have to manually crank up or down every single time it seems. And I can go faster in general in what I do (car upholstery) so it feels like this is very good frature. But I do need a way to easily control if it’s going to be needle up or down. Is there a name for this specific feature? Quote
Moderator Wizcrafts Posted December 8, 2018 Moderator Report Posted December 8, 2018 I have to agree with Katit here. I too have servo equipped machines without reducers and it is sometimes hit and miss with using my foot alone to stop dead up or down. That means I have to use the hand wheel to find the perfect rotational place . A needle positioner would speed things up by letting one sew fast, do a motion to affect the needle's position at the stop, then either pull out or resume sewing. The machines that have 3:1 reducers are hard to turn by hand unless the brakes are removed from the servo motors. Clutch motors are easier to hand crank for precise needle placement. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members katit Posted December 8, 2018 Author Members Report Posted December 8, 2018 (edited) Looks like "positioner" debate should be left for later time. Not sure what I got myself into. I brought machine home. Bought it for $200 from retired upholstered. We met on a parking lot (was a far drive). I asked to show that it sews and we did couple of stitches by turning wheel. Everything moves smoothly. Now I brought it home and realized couple things: 1. I should have left table with a seller. It's rusty on a bottom, top is bent, clutch motor. AND my table from PFAFF 1245 perfectly fits this machine (I wish I knew). But U-shaped legs look very sturdy (OLD). Maybe it's worth restoring? Basic grind/respray? 2. Machine is filthy. NO rust which is great, not dried up, but just filthy everywhere, needs a good cleaning. Good part of paint remains, stickers, etc all there. 3. Everything seem to move smoothly, there is no play in needle bar or anywhere. Seller claims new rotary hook was installed. It does look new. However, seller also says "cleaned, serviced" and it doesn't look that way. I tried to sew on it - does not work. Skips stitches. Now to the questions. 1. Does anybody have good links to manuals, videos? What type needle? I found good video from Uwe on timing the hook. 2. See picture with timing belt gear. There is epoxy on it? What was fixed? 3. Front cover bolt broken (cover was taped in). What thread size there? 4. When machine sews reverse lever knocks on a body. Issue? 5. I tried adjusting stitch length but reverse always seem to be 0 or so. Almost no move in reverse. 6. Something missing on a back? I see hole and I see threaded hole. 7. How does it look to you overall? Did I get myself $200 door stop? It seems that I need to start from basics. Get some #19 needles, metal bobbins. Then clean everything top to bottom. Lube/Grease and do all adjustments from A to Z. Right now I noticed hook touches needle. Edited December 8, 2018 by katit Quote
Members dikman Posted December 8, 2018 Members Report Posted December 8, 2018 Seiko's are nice machines and judging by those photos $200 is a very good price. It shouldn't be too hard to find a manual for it. Looks like it probably just needs a good cleaning, oiling and adjusting. As for the epoxy, my guess is either the safety clutch had a problem or someone decided to stop it working by gluing it up solid! Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members katit Posted December 9, 2018 Author Members Report Posted December 9, 2018 @dikman I found manual, but there is not much beyond basic threading/oiling Here is table. First of all, should I bother with it? Steel looks very good comparing to newer table, thicker. How much new tables going for? I will definitely need new top as current one warped. And second, what is this other pedal with chain? I assume it's a foot lift, but where do I hook it up on machine??? If that's what it is - I already love it for the simple fact that I hate knee lift I got with my other machine (my knee is not really where it needs to be and no adjustments help) Basically, should I salvage anything here? I can see myself spending couple hours on disassembly, grinding and respraying. Not sure about top, probably going to buy ready one. Quote
Members dikman Posted December 9, 2018 Members Report Posted December 9, 2018 The steel frame looks pretty reasonable, whether you re-paint it depends on how pretty you want it to look. Ditch the table top if it's warped, either make a new one (lots of posts about doing that), buy one or keep looking for a used one going cheap that you can adapt. The chain/pedal is used instead of a knee lift, but it looks like the bars and pivots to connect it are missing from the rear of the machine. I have an STH-8BLD, a slightly different model but I suspect some of the adjustments for timing could be the same (and the missing lift pieces). You should be able to find that manual (mine is 2.7mb, so too big to upload). I believe the machine may be similar to a Consew 206, the manual for those is readily available, and also the manuals for the Singer 111 series (111W153, for instance) may also be useful to understand setting the needle. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members brmax Posted December 9, 2018 Members Report Posted December 9, 2018 Looks like a great find! Congrats The stand is looking pretty heavy duty I agree. A keeper imo Good day Floyd Quote
Members Matt S Posted December 9, 2018 Members Report Posted December 9, 2018 I'd be happy with that machine at double the price you paid. It's still a fraction of what a machine of this quality would cost new, so I always figure on spending some time and money in cleaning up any machine I buy second hand. Specifically I suggest oiling it heavily and leaving over night. Then fit a brand new top quality needle (correct class and size of course) and bobbin before retiming. Find the parts book online and write down all the ones that could do with replacement. Buy the ones you definitely need and wait to buy the "would be nice" ones until the machine has made some money. (The end cover isn't essential, but the bobbin cover nearly is.) Clean whatever schmoo you can without removing parts. Polish away any burrs or nicks on the shuttle hook that you can. As you've said there's not much this machine can do that your Pfaff cannot (except reverse). However you might find it useful to have your two machines setup to do different sorts of work -- the Seiko for v69/tkt40 thread and the Pfaff for v138/tkt20 for instance. That would mean less time adjusting the machine between different operations. Plus you'll have a backup in case of a sudden failure of your other machine. Quote
