Members Vikefan Posted January 7, 2019 Members Report Posted January 7, 2019 Is there a machine that could sew holsters, knife sheaths and small thinner leather items like wallets, or would someone need two separate machines for that duty? I'm thinking welts as thick as 5/8" and thin as wallets with liners. Thanks, Vikefan Quote
bikermutt07 Posted January 7, 2019 Report Posted January 7, 2019 That is going to fall into the 2 machine category. The Cowboy 3200 tops out a 1/2", so you would need a 3500 to do 5/8". Most folks get by using the 3200 on holsters though. I did learn from a friend that the height of the machine drops a 1/4" when you install the holster needle plate. There are comparable machines from Cobra and techsew available like the ones mentioned above. Also, the industry standard is thread size 277 or thicker for holsters. Sewing machines are designed to run in a range. They have a sweet spot. Can the 3200 make a wallet? Short answer, yes. Long answer, not easily. You will probably find it hard to get a needle small enough to make a decent wallet. Also, the tension on the presser foot is high. This will cause marks and problems on thinner materials. I believe a lighter spring is available but you would have to change it back and forth. Then you have thread and bobbin tension adjustments to fiddle with. People have done all this to see if it will work. And it has. But, no one that I know of wants to do it as a part of their daily routine. Most folks, (myself included) want to set it and forget it. These machines are costly and to to me, intimidating. I don't want to be fiddling with them. I want to use them. The best I can tell a machine mentioned above paired with a consew 206rb is a great combination. Or even a cowboy 227r or cb341 if you need the cylinder capability on the small machine. I recently acquired a 3200 and a 206rb-1. But, my studio has been involved in a long ongoing transitional phase to make room for them, and new work areas. So, I haven't really gotten to learn how to use them yet. All that I have passed along is from researching these machines here and elsewhere over the last few years. There are plenty of experts here and I'm sure they will correct me if I am wrong on any of this. And don't leave out other manufacturers, I only referenced cowboy and consew because they are the brands I studied up on. Cobra, techsew, artisan, Adler, and juki are supposedly all great machines if cared for. Cobra and cowboy get a lot of high reviews here for their machines and more importantly, their service. Good luck. Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
kgg Posted January 7, 2019 Report Posted January 7, 2019 I agree with bikermutt07. Holster type thickness/thread/toughness is going to require a completely different machine then what would be required to do a wallet. No one machine is going to be able to give or be able to give constant results over a large range of materials / thickness / toughness, you will be forever fiddling with changing threads, needles, tensions, feet, binders, etc. I think you need to consider multiple machines, if the budget allows, and set them up to do the task that they do best. That way once they are tuned in every time you work them it should/will give constant results. Less hassle, more enjoyment, more productive. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members brmax Posted January 7, 2019 Members Report Posted January 7, 2019 Yes, If you selected your leather choice thickness/weight carefully. Just as you and I would do in the upholstery size or class machines. Our need or want to fabricate super thin nylon materials one in a while, its always our tough denial decision. So finding a sweet spot leather thickness with thread you can center the knot of heavier thread. I have mentioned before using thread colors to contrast a product. This as well can be looked at for blending if one wants thread concealed. All that aside the feed mechanisim can be bigger on the large machines as are the gaps and or holes for big needle abilities. Have a good day Floyd Quote
Moderator Wizcrafts Posted January 7, 2019 Moderator Report Posted January 7, 2019 If you truly need to sew 5/8 inch thickness, go for the full size, high lift CB4500, or equivalent. I have one and have sewn over 3/4 inch with it, using #346 thread. Get a common upholstery class compound feed walking foot machine for your wallets and belts. There are many makes and models that fit the bill, including the venerable old Singer 111 series, various Consew, Seiko, Chandler, Juki, Pfaff, Adler, etc. The upholstery machines can sew from ~3 ounces up to about 3/8 inch, using thread sizes bonded 69 through 138.. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Constabulary Posted January 7, 2019 Members Report Posted January 7, 2019 3 hours ago, Wizcrafts said: Singer 111 venerable she is Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members dikman Posted January 7, 2019 Members Report Posted January 7, 2019 I wish I had a $1 for everyone who asks which machine they should get to make belts, wallets, bags etc - oh, and holsters too! I could probably have bought a CB3200 with the money. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Vikefan Posted January 8, 2019 Author Members Report Posted January 8, 2019 Thank you everyone... Wow... I guess I will hold off and have to investigate further. Since I don't have a machine I hand-stitch my holsters and Knife sheaths I make. Thanks again for all the good information. Vikefan Quote
Members dikman Posted January 8, 2019 Members Report Posted January 8, 2019 I handstitch my holsters as none of my machines are capable of doing them. Handstitching is actually the best way to sew holsters, imo, but it does take a while (no real problem when it's only a hobby). Doing a gunbelt, however - edges and decorative stitching - is an exercise in tediousness! If you can get a good used upholstery-class walking foot it might be a good way to get started without breaking the bank. In the meantime keep reading the sticky's in this section, there's a lot of info in there to assimilate. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members SilverForgeStudio Posted January 10, 2019 Members Report Posted January 10, 2019 @Vikefan Thanks for this thread- It has seriously shed some light on a decision I was contemplating as well. Thank you! Quote
