Members afdfirefighter Posted January 14, 2019 Members Report Posted January 14, 2019 What is the easiest way to do this and do it consistent each time? Should I have a dye made or is there a punch I can use to accomplish this? Thank you in advance. Quote
Members DJole Posted January 14, 2019 Members Report Posted January 14, 2019 If you are making a lot of them, then getting a cutting die made is the way to go. If you are making a few of them, then make a durable template for this (out of heavy cardstock, or plastic). Then you lay it on the leather and trace around it to get that same shape over and over. Quote \D. Jole \ --> <http://djole.altervista.org/djole/Publications/Leather/Lindex.htm>
Members afdfirefighter Posted January 14, 2019 Author Members Report Posted January 14, 2019 On 1/14/2019 at 9:24 PM, DJole said: If you are making a lot of them, then getting a cutting die made is the way to go. If you are making a few of them, then make a durable template for this (out of heavy cardstock, or plastic). Then you lay it on the leather and trace around it to get that same shape over and over. Expand Thank you. Is there a site that has pre-made (standard-ish) dyes? I would imagine there is something out there similar to what I am doing or that I can make work. Quote
Members Hasbeencowboy Posted January 14, 2019 Members Report Posted January 14, 2019 Try Heather at Texas Custom Dies. They will treat you right Quote
alpha2 Posted January 15, 2019 Report Posted January 15, 2019 The thing about making your own template, is that it conforms to exactly to what you want to do. Short of going the custom die route, you can make as many bad, failed ones as you want, keeping only the one that is perfect. At least, that's what I did! Cheap, effective, and cheap. Jeff Quote So much leather...so little time.
Members JazzBass Posted January 15, 2019 Members Report Posted January 15, 2019 I take a couple of extra minutes to make "2-step templates" for something like this. First, is to do it with paper cut to the full width. Fold it in half. Draw the radius, then cut it while folded. Both sides will be perfectly symmetrical. This is a BIG help. Then, trace that onto some poster board and cut it out. You now have a template that will last multiple uses. Quote Christopher J. Gordanhttps://www.youtube.com/user/ChrisGordan
Contributing Member JLSleather Posted January 15, 2019 Contributing Member Report Posted January 15, 2019 On 1/15/2019 at 2:27 AM, JazzBass said: Then, trace that onto some poster board Expand I'm a bit hurry-er than that .. a bit of spray adhesive on the paper and the posterboard, stick it, and go. Eliminates errors from tracing too IF you decide you are making enough to justify a die, just make yer paper pattern, get it the way you want it, and send it to Sandy. They'll make a die right from your paper pattern. Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Members JazzBass Posted January 15, 2019 Members Report Posted January 15, 2019 On 1/15/2019 at 2:31 AM, JLSleather said: I'm a bit hurry-er than that .. a bit of spray adhesive on the paper and the posterboard, stick it, and go. Eliminates errors from tracing too Expand That's why you're a pro and I'm still having "forehead slap" moments. ROFL! ...but I'll take it as a compliment for the paper/symmetry concept (at least I got something right!) Quote Christopher J. Gordanhttps://www.youtube.com/user/ChrisGordan
Members mdawson Posted January 15, 2019 Members Report Posted January 15, 2019 Hi Weaver Leather did a video on this using a strap cutter and an English Point punch. The Leather Element: How to Taper Leather Straps Mark Quote
Members Dwight Posted January 15, 2019 Members Report Posted January 15, 2019 Because you have two holes, . . . this is a natural for a kydex template. Of course, . . . make a "perfect" pattern in paper, . . . transfer it to a piece of kydex (get it at Tandy leather shop), . . . punch two holes, . . . lay template on leather, . . . mark and punch holes, . . . lay template back on leather, . . . drop couple of small bolts into the holes to hold template from moving, . . . grab the razor knife an start cutting. They will be as perfectly symmetrical as you are able to cut them, . . . May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Contributing Member JLSleather Posted January 15, 2019 Contributing Member Report Posted January 15, 2019 (edited) On 1/15/2019 at 1:10 PM, Dwight said: drop couple of small bolts into the holes to hold template Expand Yup, that would work (folks usedta call them "pilot" holes, maybe now it's something more ... sensitive?). IF you decide to have a die made, I would have them add the punches for the holes too. One "hit" and it's done. Sandy's smart, she's prolly gonna recommend that you use tapped holes in the die, and then insert threaded punch tubes. It's more money of course, locating the holes in the die, but MUCH easier to sharpen or replace if they're made to come out. Edited January 15, 2019 by JLSleather Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Members chrisash Posted January 15, 2019 Members Report Posted January 15, 2019 I am now using my 3D Printer to make 2mm thick PLastic templates for all my items, takes about 30-60 min for most sizes, gives a firm and consistent tracing edge, stands up to knocks etx and about 20 min of 3d software to draw, also makes tangents with curves as smooth as possible and as much detail as you require Quote Mi omputer is ot ood at speeling , it's not me
Members Harry Marinakis Posted January 24, 2019 Members Report Posted January 24, 2019 1/8" aluminum bar stock Make a template Quote
