Members Travis73 Posted January 17, 2019 Members Report Posted January 17, 2019 I built a 4ft x 6ft workbench to put in the center of my shop. I chose this size because that was the biggest bench that i could fit in the room as i already had a U shaped bench along 3 walls. I also chose that size because I had found a 48"x72" cutting mat at Tek Line. After finishing the bench I sat down to order the cutting mat and read some reviews on it that were less than favorable, apparently it is just rubber sheeting. They have some cartoonish looking product pictures on their website and now I guess I know why. I am not paying $211 for soft plastic sheeting. I have seen pics that some of you have posted with really big poly cutting boards and mats on top of your tables. Where would i find such a thing? Google is not helping, Other than the Tekline, i cant seem to find anything in that size. I want to keep it under $300 and really don't want to spend that much but i dont want whatever i buy to fall apart or have big gouges that will ruin my leather, or make my cuts go off course. Would appreciate any input. Thanks Quote
bermudahwin Posted January 17, 2019 Report Posted January 17, 2019 I looked at this UK site, and when I have made my bench will contact them. I like the interlocking mats, as you can move them around as they wear. https://signgeer.com/equipment-workshop/sign-furniture/cutting-mats Harry Quote No longer following it.
kgg Posted January 17, 2019 Report Posted January 17, 2019 Did you check this place. https://www.gwjcompany.com/index.php?main_page=product_info&products_id=64 kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Contributing Member LatigoAmigo Posted January 17, 2019 Contributing Member Report Posted January 17, 2019 (edited) 44 minutes ago, Travis73 said: I have seen pics that some of you have posted with really big poly cutting boards and mats on top of your tables. Where would i find such a thing? This is the largest cutting mat that I have been able to find. Not as big as you are seeking, only 3" x 5", but it has been a good mat. I found it available on Amazon: https://www.amazon.com/Sullivans-087168-SUL38233-Table-White/dp/B006JJG6D6/ref=sr_1_1?ie=UTF8&qid=1547741618&sr=8-1&keywords=sullivans+36''x59''+gridded+cutting+mat+for+home+hobby+table Edited January 17, 2019 by LatigoAmigo Quote
Members Matt S Posted January 17, 2019 Members Report Posted January 17, 2019 I need to resurface my bench but I'm holding off until I've decided whether I have to leave our as 8x2 or can squeeze a 8x4 into the workshop. None of the intensive surfaces I've tried so far (chipboard, hardboard, green mats) have worked well enough so I'm going to bite the bullet on something decent, even if it is expensive. HDPE is usually what's recommended but most suppliers here in the UK only but it as 1x2 metered sheets (about 3'3"x6'6"). Full 8x2 or 8x4 sheets aren't cheap in the sorts of thickness needed but they're out there. I found the suppliers through Google and eBay. Harry those mats look handy and a good price but I'm worried about how tough they are, especially when I go heavy handed with a round knife. I'd also like a surface on which I can punch with impunity. What did you used to use in industry? Cos I'm fed up of keep spending money and ruining leather on inadequate surfaces. Full bench sized HDPE 10+mm thick is what I'm leaning towards. Yes it's an expense but if I spread that over the expected decades of use it works out pretty cheap. Quote
bermudahwin Posted January 17, 2019 Report Posted January 17, 2019 In industry... in the olden days, if we could see through the fug from oil lamps... we had HDPE mats that we 6 ft x 2 ft x 1 inch, on the bench, and on a side bench (we were the design room so got 'special treatment') had a butcher's block that needed oiling and prepping etc, that was 3 ft x 2 ft and had a piece of 1 inch HDPE off cut for punching, or a block of lead for punching. Using my head knife I am ok on self healing mats now, but my round knife use on wood only. Remember, in the factory we were mainly using clicking knives or head (half round) not round knives, so my 'go to' is a differing one than many. I use my scalpel for bookbinding, nearly exclusively. Best H Quote No longer following it.
Members Sonydaze Posted January 17, 2019 Members Report Posted January 17, 2019 I built a 4' x 8' table and covered it with a sheet of 1/4" HDPE. It cost about $85 around 8 years ago (and is still doing fine after lots of heavy use.) I got it From Sabic Plastics, which has warehouses all over the world. https://www.sabic.com/en/about/locations You will likely have to buy a full sheet, they don't like to sell part sheets, but you can likely get them to cut your sheet to the size you want. Quote http://www.bound2please.com Sewing machines: 3 - Sunstar 590BL, Artisan Toro 3200, Juki LK-1900HS, Juki DDL-8500-7, Juki DDL-5550N, Pfaff 138-6/21, Pfaff 546-H3, Pfaff 335-H3, Adler 221-76, Singer 144WVS33, Singer 29K-51, Siruba 747B
Members Matt S Posted January 17, 2019 Members Report Posted January 17, 2019 1 hour ago, hwinbermuda said: In industry... in the olden days, if we could see through the fug from oil lamps... we had HDPE mats that we 6 ft x 2 ft x 1 inch, on the bench, and on a side bench (we were the design room so got 'special treatment') had a butcher's block that needed oiling and prepping etc, that was 3 ft x 2 ft and had a piece of 1 inch HDPE off cut for punching, or a block of lead for punching. Using my head knife I am ok on self healing mats now, but my round knife use on wood only. Remember, in the factory we were mainly using clicking knives or head (half round) not round knives, so my 'go to' is a differing one than many. Paraffin or whale oil in the lamps Harry? Thanks for the detailed response. I tend to be a bit hard on equipment so I think I'd better just pony up for a big chunk of HDPE. Most of my green mats have at least one hole from when I thought I could get away with punching "just a couple" holes. I could probably make do with a 6ft assembly/punching/general bench if I had a separate lightweight 8x4 layout/cutting table but I really can't fit both into my little shed. Quote
stelmackr Posted January 17, 2019 Report Posted January 17, 2019 (edited) I went to my local "old/new hardware" shop where there nut, bolts, fittings, barrels, etc. See pictures of the shop: https://www.google.com/maps/uv?hl=en&pb=!1s0x549878d6916d69bf:0x95dacdfe91069a4f!2m22!2m2!1i80!2i80!3m1!2i20!16m16!1b1!2m2!1m1!1e1!2m2!1m1!1e3!2m2!1m1!1e5!2m2!1m1!1e4!2m2!1m1!1e6!3m1!7e115!4shttps://lh5.googleusercontent.com/p/AF1QipPlJO7mZ93YGG1h7jqEOpEiuHdkwnWOXaDyzpsU%3Dw213-h160-k-no!5sart+carpenter+kennewick+-+Google+Search&imagekey=!1e10!2sAF1QipPlJO7mZ93YGG1h7jqEOpEiuHdkwnWOXaDyzpsU&sa=X&ved=2ahUKEwjH7MTftPXfAhXKwVQKHd6PDhkQoiowCnoECAYQBg ...and purchased a roll of rubber conveyor belt. I used 3-foot wide, because my table was 3-foot wide. The belt is smooth rubber, about 3/8 inch thick and has bias ply construction like tires. Edited January 17, 2019 by stelmackr Quote Bob Stelmack Desert Leathercraft LLC Former Editor of the, RawHide Gazette, for the Puget Sound Leather Artisans Co-Op, 25 years of doing it was enough...
bermudahwin Posted January 17, 2019 Report Posted January 17, 2019 (edited) Paraffin or whale oil in the lamps Harry? What to go with my walrus tusk knife handles? Yup, HDPE is a good buy, and I must get some too. Edited January 17, 2019 by hwinbermuda Quote No longer following it.
