Some time ago I started having problems with access to https://www.tandyleather.com/ (https://www.tandyleather.ca/, https://www.tandyleather.eu/ - same)
Error 403 Forbidden
The problem is constant and repeated over several days.
I wanted to ask, is it only when trying to enter the site from Ukraine or someone has the same situation?
  • Replies 48
  • Created
  • Last Reply
Top Posters In This Topic
2 minutes ago, hwinbermuda said:
I went straight in from UK, into.eu site.
H
Thanks!
It seems that this is a deliberate blockage.
How to explain Tandy that Ukraine is not Russia? :)
Both work from France..Just accessed them ..
Try using a proxy based outside the Ukraine..That will let you know if they are blocking Ukraine IPs..
Try using a Russian proxy..might be they are just blocking the Ukraine ..
Why they'd block either is a mystery..
Edited by mikesc
"Don't you know that women are the only works of Art" .. ( Don Henley and "some French painter in a field" )
Thank you, Mike.
I tried to log in through a proxy (Germany and the USA) - everything works.
What Ukraine is guilty? :(
Like Chris said..blame it on Brexit..
OT / Co-incidentally enough Andrey..when you posted about being "blocked" above, your post count was 403 :)
Now you are 404.. :)
Pay close attention to any noises coming from your computer lest you go 410 :)..when did you last clear out the dust bunnies..
How does one say "dust bunnies" in Ukrainian ?..In French they are called "moutons" ( sheep ).. :)
Edited by mikesc
speeling
If only we could convince Russia that Ukraine isn't Russia.
25 minutes ago, ABHandmade said:
Thanks!
So much leather...so little time.
Now your are 404..
Pay close attention to any noises coming from your computer lest you go 410..when did you last clear out the dust bunnies..
Yes, I haven't vacuumed my laptop for quite a while. Need to do. Thanks for the warning :)
And as for dust bunnies, I can’t even remember a special word in Ukrainian for that. Well, except that the word dust is "poroh".
Sir, the USA is doing quite a lot in this direction, for which the Ukrainians are very grateful.
Specialty:Various..and "topic drift"
Thus..Murky Buckets..H :)
Takes my mind off watching Wales leading Ireland 10-0..( now 13-10 :(( )
To return to Topic..Tandy HQ is in the USA and is shut weekends..I did phone Canada about an hour ago ( who are open today ) to see if they knew of any policy that says that Tandy as an organisation are blocking the Ukraine..Very polite guy there at the shop ..does not know..Says only HQ would know..
I can phone and ask them* ( Tandy HQ in Fort Worth TX ) when they are open next week ..
*No problem..Unlimited worldwide ( with the exception of a handful of countries ) calls and data plans on my phones..fixed lines and cells..
Point them to this thread..and to Andrey's work
https://leatherworker.net/forum/topic/85137-mountain-lion-for-my-wife/?tab=comments#comment-577226
( I'm sure they'd like him to be using some of their leather to work on )
