Maaaann you shore jumped into it on the printer stuff. LOVE it.
32 minutes ago, jimi said:
Next thing i need to do is a small edge paint tray and wheel to see if that works, although i  am not a big fan of painting edges
I have been considering making up something but I would like to use some little motors like on the printer to keep the roller turning continious. Some paints dry onto the rollers very quickly and you will quickly get dry lumpy problems if it does not keep the paint moving.
Seems like on the mirror works pretty good for you brian? do you heat it up??
Yep. On pla+ I usually run mine at 65 degrees.Aluminium heather plate under the mirror and cork under that to keep the heat more even and stable. I think the mirror is holding up better than the original. Mind you I use a separate cooling fan for when the job is done and make sure that it all but pops off of the plate when I remove the job.
Are you using Cura? If so what version? You did real well printing that foot as you did. I think I would have added more sidewall thickness and printed it the other way up with light supports though. Looks more original like the way you did it. I think you are going to be coming up with some amazing stuff and I hope to see it.:thumbsup:
Is that leather stuck on the bottom of the centre foot? 335?
Hey ...here's something I found last night ...I WANT
YouTube Channel
Instagram
  • Replies 55
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
No cura, Prusaslicer which seems to use simplify3d also, I tried cura but it started to print things in the air and stuff so i changed to simplify then had a look at the prusa one which is similar and worked great for me, both of them.
Thanks for the heads up on the paint tray Brian?? motors eh?
Yes leather on both feet of the 335, see you got a hawk eye..Lol.
well that´s a Biggee?? for bags?? does that sew on cording or something?? that looks like the equivalent to a walking foot patcher?? Well as you do a lot of bags and have big volume jobs i am sure that would work well for you, all you need to do now is make the missus supper and break it gently to her..:rofl:
3 hours ago, Constabulary said:
I wonder where all the nice sewing devices Singer once sold went to - you never find them. Are they all worn out and junked? Or still in use? Or is there a black hole for Singer parts? You even barely find presser feet for 45K´s
Maybe they are having a party with all the socks that get lost in the laundry?
I kind of wonder why there isn't somebody out there making these parts.  The market is probably not big enough to go into castings, etc - but with the advent of small CNC machines, and such, it seems like these parts could be made on a piece by piece basis and still make some amount of profit.   If I had the gear, I'd give it a try!
- Bill
Have I ever mentioned that I hate people who can print out this cool stuff  :thinking:
You guys are awesome, I don´t think I had the patient for that!  :lol: Looking forward to seeing more of this stuff. Printing old Singer sewing devices could become a business idea - probably.
I agree constabulary. Every time I start trying to learn how to use a design programme I get distracted onto something else.:blink:
It is a sort of walk up the arm and cylinder arm combination. Best I can tell the arm can swivel 360 which means that you could sew all the way around a bag without the gussets getting in the way. Very lacking in information that can be found on it. I did find another similar machine which has a dog foot feed as well but again Very lacking in information.
Come on Folker.........Give it a go. The best stuff will always come from the people like you.
YouTube Channel
Instagram
Ok, maybe thats a cable for a light?? nothing to do with cording Lol, looks interesting, that needle plate puck parts looks to be held still while rotated hence the thick arm which would have a few pinions along the way i suppose??
Did you see the link above Brian?? nice big pictures to get measurements from and it is used on the Adler 205 so almost the same as the one you have??
http://sew24.blogspot.com/2012/09/sew-luxury-leather-bag-handles-with.html?m=1
Yeah..comon Folker...go for it :lol:
Edited by jimi
Hi jimi, Yes I have seen that one before and it is the style of thing I was thinking about doing except on the big 441 machine and the pressure of this type of work I will need to build in a lot of support structure where possible to take that kind of load. I may end up trying it on an old 69 Adler first I think once I get a servo motor hooked up to it. I do have a few bags that need these handles to do so........:dunno:
YouTube Channel
Instagram
  • 4 weeks later...
On 3/20/2019 at 12:48 PM, RockyAussie said:
I have been doing a few projects recently that need a very small cylinder machine to enable me to get into the tight corners and such. This is still a bit of a work in progress but so far the results have been good. A few more tweaks and they should be excellent. I have a 335 Pfaff , 69 Adler, Tk 335 Elizabeth and a 331 Pfaff that I have finished of some new cylinder caps for. After doing some measurements and tests the width of the caps have now been reduced from 46.6mm down to 41.4mm. ( a bit under 1/4"). The depth has reduced a couple of mm and the length a couple as well. NOTE: except for the Pfaff 331 which has a little more room for reductions, all of the caps fitted and they are all the smaller bobbin variety.
The first picture shows 3 of the 4 caps just finished as against the ones being replaced.
This is the TK335  Elizabeth cylinder showing some comparisons.
If any of you have printers and one of these style machines let me know and I will get you a stl file if you want it.
If you have one of these machines and are one of my followers and do not have a printer... PM me if you would like one.
I know the colour is awful and I could have done them in a metalic silver colour but at least they are easy to find now.
Brian
I just bought a Pfaff 335 H2L and it's missing the sylinder cap. I'd love to be able to print one out. I don't have a printer of my own yet but I know a place where I can make it.
