Members Gymnast Posted April 27, 2019 Members Report Posted April 27, 2019 At the attached picture, you see two presser feet for Singer vintage sewing machines with normal feed dogs. I made a modification to the right foot by cutting a notch into the foot. Have you previously noticed a similar presser foot? Do you anticipate problems by using such presser foot? I tried to sew tarpaulin near the limit for such a machine with a tex 135 thread. With the modified foot, I was able to reduce the thread tension to 61 % compared to the left foot in picture. Furthermore the required pressure on the pressure foot could be reduced to 52 %. In this way it became easier for the machine to handle the same job. Quote Sewing Machines in Detail, YouTube channel
Evo160K Posted April 27, 2019 Report Posted April 27, 2019 Good modification. What thought process lead you to do that? Quote
Members Constabulary Posted April 27, 2019 Members Report Posted April 27, 2019 (edited) What is the modification - the short cut in the right foot? What is the advantage? 135 thread is quite tick for a Singer domestic machine. You calculate tension in percentage - are you a scientist? Maybe its just me but I don´t get what you want to say - but maybe its just me. Edited April 27, 2019 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
RockyAussie Posted April 27, 2019 Report Posted April 27, 2019 Interesting . They are 2 different feet in that the one on the left is a hinged foot and has a fair bit longer body length than the one on the left. Like a stiletto shoe heel a lot more pressure is going down for the same weight applied which explains the reduced foot pressure needed. I can only assume that the slot cut may allow the thread tension to come in earlier to effect how the thread tension behaves. It may also be needed for the needle travel if the foot is for a different length than this machine. 2 hours ago, Gymnast said: Do you anticipate problems by using such presser foot? AS long as it is smoothed off well no and if it requires less foot pressure to do the job it should extend the machine life as well. Thanks for sharing. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members Gymnast Posted April 27, 2019 Author Members Report Posted April 27, 2019 Thanks for your comments. I will try to answer your question in a later reply. But I need to give more details. I made some comparative test with three presser feet. It was a normal presser foot, a modified foot with a notch to the back, and a wheel type foot. The modified foot had been cut about 3 mm to the back to make room for the thread when maximum thread tension is applied in the sewing cycle. In this way the thread friction below the food is reduced. Furthermore the required traction for the feed dog is reduced due to the direction of the thread tension hitting the fabric. The wheel foot has the same kind of advantages. The test was performed using a Singer 201k machine with a 140/22 needle and an Amann Serafill 20 polyester thread (Tex 135). Tension measurements were performed using an uncalibrated dynamometer. The tension was measured by pulling the thread before reaching the thread take up. The tension from the bobbin case was set to 0.5 N. The fabric was two layers of 600 g/m2 tarpaulin of good quality. In each case the sewn stitch was examined, and the upper thread tension was adjusted to get a balanced stitch. The traction of the feed dog was increased by increasing the pressure on the presser feet, so a maximum stitch length could be noticed. It was 4.4 mm for the two first presser feet and 4.8 mm with the wheel type foot. Then the pressure to the presser foot was reduced until 0.1 mm lesser stitch length could be measured. This pressure on the presser foot is named as the required pressure on the presser foot. The results are given in the pictures. For some unknown reason the stitch length became 0.4 mm longer with the wheel foot compared to the other feet. The pictures are taken in the stitch forming part of the sewing cycle, where the thread tension is applied to the upper thread (near max position of the thread take up). Results: With the modified presser foot and wheel presser foot, you are able reduce the thread tension to 61 % of thread tension with a normal foot. The required down force on the modified presser foot could be reduced to 52 % of the normal foot. The required down force on the wheel foot could be reduced to 28 % of the normal foot. Quote Sewing Machines in Detail, YouTube channel
Members dikman Posted April 27, 2019 Members Report Posted April 27, 2019 (edited) Brian, I am more than happy to acknowledge your superior experience in these things, but I must admit I'm with Constabulary on this. The feet look the same type as those on my little 201K (domestic) and I'm blowed if I can see any advantage in filing out a notch like that. Plus, as you say they are two different type of feet, so to prove that cutting the notch makes a difference the comparison should be between two of the same feet, i.e. before and after. Of course, I could be completely wrong...... I see you posted just as I did, Gymnast. Interesting tests, but as I said you should do the comparison between two of the same type of foot in order to get an accurate result. Edited April 27, 2019 by dikman Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Gymnast Posted April 27, 2019 Author Members Report Posted April 27, 2019 1 hour ago, RockyAussie said: Interesting . They are 2 different feet in that the one on the left is a hinged foot and has a fair bit longer body length than the one on the left. Like a stiletto shoe heel a lot more pressure is going down for the same weight applied which explains the reduced foot pressure needed. I can only assume that the slot cut may allow the thread tension to come in earlier to effect how the thread tension behaves. It may also be needed for the needle travel if the foot is for a different length than this machine. AS long as it is smoothed off well no and if it requires less foot pressure to do the job it should extend the machine life as well. Thanks for sharing. You are right - I have not used the same foot in the detailed Measurements. However i did earlier make some comparisons of the two feet, and actually did not find and significant differences. At the moment I do not have more feet of this kind, but I have ordered more feet. When I get them in about 3 weeks I shall make a better comparison. But I would like to see others try this modification. The reason I did this modification was, that I discovered, that I needed less thread tension when using the wheel foot and started to investigate why. Quote Sewing Machines in Detail, YouTube channel
RockyAussie Posted April 27, 2019 Report Posted April 27, 2019 12 minutes ago, dikman said: Brian, I am more than happy to acknowledge your superior experience in these things, but I must admit I'm with Constabulary on this. The feet look the same type as those on my little 201K (domestic) and I'm blowed if I can see any advantage in filing out a notch like that. Plus, as you say they are two different type of feet, so to prove that cutting the notch makes a difference the comparison should be between two of the same feet, i.e. before and after. Of course, I could be completely wrong...... As you know I am guilty of using hammers and scales and fish scales etc but its funny how little things like this can make such differences in the operation of a sewing machine I reckon. The slot looks to allow the thread to be pulled through the needle on a more straight angle and that would therefore make the thread slide through the needle with less friction. The roller giving a longer stitch I think would be because there would be less resistance on the fabric when going through. The other 2 feet keep pressure down all through the job and create friction over their wider non rolling base than the other large roller foot. Now I sound like a geeeek again . I'll get kicked outer this here section yet. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members Gymnast Posted April 27, 2019 Author Members Report Posted April 27, 2019 3 hours ago, dikman said: Brian, I am more than happy to acknowledge your superior experience in these things, but I must admit I'm with Constabulary on this. The feet look the same type as those on my little 201K (domestic) and I'm blowed if I can see any advantage in filing out a notch like that. Plus, as you say they are two different type of feet, so to prove that cutting the notch makes a difference the comparison should be between two of the same feet, i.e. before and after. Of course, I could be completely wrong...... I see you posted just as I did, Gymnast. Interesting tests, but as I said you should do the comparison between two of the same type of foot in order to get an accurate result. Thanks for your comment dikman. We need to be critical in order to try understan´, what is going on here. I agree, that the different type of feet can make a change to the feed dog traction. Therefore the figures regading required down force on the presser foot may not be compareable. But how do you explain the difference in thread tension for a ballanced stitch?. When you compare the tread tension for the Wheel foot with the notch food, then they are equal. The only reason for me regarding the drop in thread tension from 7.2 N to 4.4 N is, that you add significant friction to the tread below the normal presser foot. Furthermore the thread tension direction is along the fabric and not more right up from the stitch hole in the tarpaulin, and it should add to thread friction as well. With the added tension and direction of the tension in the thread pulling in the fabric, you need more traction from feed dog to pull the last half part of the feed dog motion with high tension in the thread. And the only way you can get more traction is to increase the Down force on the presser foot. I actually did some Measurements with dynamometer on how much traction in the fabric you get depending of Down force on presser foot. A slump figure for this normal presser foot on this machine is, that you get about 1/3 more traction compared to down force. So if you increase down force with 12 N, you should get about 4 N more possible traction. So these traction values are compareable to the thread tension. Quote Sewing Machines in Detail, YouTube channel
Members trash treasure Posted April 29, 2019 Members Report Posted April 29, 2019 This is actually pretty interesting - If the modification results in that much less tension needed, then there might be a real benefit with pucker reduction for seaming some fabrics - I may have to do some experiments on my own ........... Quote The model number giveth, and the subclass taketh away ......... Sometimes
Members Gymnast Posted April 29, 2019 Author Members Report Posted April 29, 2019 1 hour ago, trash treasure said: This is actually pretty interesting - If the modification results in that much less tension needed, then there might be a real benefit with pucker reduction for seaming some fabrics - I may have to do some experiments on my own ........... Thanks trash. If you try it out, I should love to know your results. I have got a supprice myselves. It is hard to believe that such a simple thing is not in use already. Quote Sewing Machines in Detail, YouTube channel
Members Gymnast Posted April 29, 2019 Author Members Report Posted April 29, 2019 Thanks Wiz - yes please. Could I do this in some other way? Quote Sewing Machines in Detail, YouTube channel
Moderator Wizcrafts Posted April 29, 2019 Moderator Report Posted April 29, 2019 34 minutes ago, Gymnast said: Thanks Wiz - yes please. Could I do this in some other way? You only have a short time to edit a post as a standard user. Moderators can act at any time. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Gymnast Posted June 2, 2019 Author Members Report Posted June 2, 2019 (edited) The first test got some rightfull critique due to the different foots used in test. Now I got 3 equal foots shown from start in picture below. All the these "vintage" foots are delivered from same supplier in same order and post. They are all hinged feet, so they can tilt a Little to the front and behind like the very first normal foot shown in picure in first post of this thread. The left one is as received. It has a rather sharp edge below and to the back, and it is bad design/manufacturing and not normal for this kind of foot. So the foot in the middle has been grinded at that point, so it is considered normal. The foot to the right do also have a notch as described in previously in this thread. The notch make space for thread, so it is easier for the machine to pull the thread for the lock in the stich. Again two layers of vinyl is used for the test and a Serafil 20 thread. So the foot in the middle of the photo and the foot to the right are compared using two kinds sizes of needles: I think the previous test might have been done with a 130/21 needle. This can explain the difference in thread tension to the previous test from 4.4 N to 3.8 N. With this marginal pressure on the foot, you can see a little tilt in the foot, when the needle is pulled up. This can of cause not happen with the foot with no hinge in the first post. Still the foot with the notch seems to require less thread tension and less pressure on presser foot. Edited June 2, 2019 by Gymnast Quote Sewing Machines in Detail, YouTube channel
Members DavidMillsSaddlery Posted June 3, 2019 Members Report Posted June 3, 2019 On 4/27/2019 at 4:25 AM, Gymnast said: he may very well be a scientist with that equipment... but these needles look like they’re in backwards, and the thread isn’t run properly either... Quote
Members Gymnast Posted June 4, 2019 Author Members Report Posted June 4, 2019 On 6/3/2019 at 6:27 AM, turbotexas said: he may very well be a scientist with that equipment... but these needles look like they’re in backwards, and the thread isn’t run properly either... Oh, thats a special announcement about my credibility. I did not expect that in this forum, but it is after all the internet of today. I am suppriced to learn, that someone used to sewing can think, that sewing like that can be done with an inverted needle. Sometimes the good thing about internet is, that some matters can be easily verified by people who want to do that. There is over 50 videoes on youtube that show details on how Singer 201 make stitches, the direction of the grove of the needle, and how the thread will pass the machine. Make your own judgement on who is creditble. This is one of the videos: I am sorry, if some of you will feel uncomfortable with me showing some test results. I actually just write down what I see, measure and what I think about it. Use it and think what you like and make your comments. I do know, that many here have a lot more expirience with sewing than I have. Quote Sewing Machines in Detail, YouTube channel
Members dikman Posted June 4, 2019 Members Report Posted June 4, 2019 You're quite right of course, gymnast, if the needle was in backwards there's no way you would get any stitches! As for the thread path, the only thing I can see that's not quite right is the angle of the thread coming down from the needle clamp, it looks like the wire guide is missing? In reality, however, it won't make much difference as at least one of my machines is missing the guide but it works fine. Your testing methodology is impressive, it's just not something that many of us worry about, we tend to "wing it" and just learn about tension by experience. I don't think we've seen anyone delve into tensions in such a detailed manner before. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
kgg Posted June 5, 2019 Report Posted June 5, 2019 On 6/3/2019 at 4:27 AM, turbotexas said: he may very well be a scientist with that equipment... but these needles look like they’re in backwards, and the thread isn’t run properly either... I think the problem with the above statement is that turbotexas is not familiar with older domestic Singers which have the needles installed with the long grove on the right hand side versus commercial machines having the needle installed with the long groove installed on the left. The thread always follows the long groove so the threading of the needle on the older domestic Singers is done from right to left which the video shows correctly. I find this topic interesting on how a different / modified foot can affect the thread tension. This may not be a problem on commercial sewing machines but we all should be aware of this when we change out the presser foot on any machine particularly if a problem crops up after the change out. I think your methodology is spot on: problem, base line data, modification, test, document result, result comparison and let the chips fall wherever. The data won't lie. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
JJN Posted June 5, 2019 Report Posted June 5, 2019 I think people that are not familiar with the 201k might assume by the appearance that this is a horizontal axis hook that is located on the right side of the needle. That is why it looks like the needle is in backwards to some of us. This machine is a vertical axis hook and it is located on the left side of the needle. From the photo it looks like the needle may be slightly off with the scarf aiming a little to the rear, but it might just be the way the photo looks. Quote Ferdco Juki Pro-2000, Juki DNU-1541S, LS-1341, LU-563, DLN-9010A-SH, MO-6714S, Consew 206RB, 206RB-1, Chandler/Bernina 217 6mm w/Cam Reader, Brother LT2-B842-5
Moderator Wizcrafts Posted June 5, 2019 Moderator Report Posted June 5, 2019 If I recall correctly, the Singer 15-91 also threads from right to left (groove on right). However, it is a horizontal hook machine using Class 15 bobbins. Singer slant needle machines thread from front to back with a vertical hook in front of the needle. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Gymnast Posted June 5, 2019 Author Members Report Posted June 5, 2019 8 hours ago, dikman said: As for the thread path, the only thing I can see that's not quite right is the angle of the thread coming down from the needle clamp, it looks like the wire guide is missing? You are right. I think it is how the machine is. The grove is to the right, at it causes the thread to be hold in a more difficult pass around the needle shaft. It have made me thinking about a possible modification by moving the thread guide on the needle shaft closer to the needle centerline. 8 hours ago, dikman said: Your testing methodology is impressive, it's just not something that many of us worry about, we tend to "wing it" and just learn about tension by experience. I don't think we've seen anyone delve into tensions in such a detailed manner before. Yes. And perhaps I should have the Work done instead of all this :). But i think it is a Little funny too. Forcing this machine to its limits do also require more trials. Quote Sewing Machines in Detail, YouTube channel
Members Gymnast Posted June 5, 2019 Author Members Report Posted June 5, 2019 (edited) 7 hours ago, JJN said: From the photo it looks like the needle may be slightly off with the scarf aiming a little to the rear I think you are right regarding the photos with the presser foot notch and wheel foot. The tension in the thread is going to somewhat bend the needle to the back. This will not happen on the normal foot, and it can actually be a reason why a normal foot is, as it is. You may not like that to happen, and it may affect the working time of the needle. When I carefully look at the sewing cycle on this machine, the thread take up will take off tension before the needle hits the fabric. Therefore it should not affect the stitch length. Edited June 5, 2019 by Gymnast Quote Sewing Machines in Detail, YouTube channel
Members climent Posted August 1, 2019 Members Report Posted August 1, 2019 On 4/27/2019 at 5:25 AM, Gymnast said: For some unknown reason the stitch length became 0.4 mm longer with the wheel foot compared to the other feet. I'd say the reason is the reduced friction the dog foot has against the wheel when compared with standard pressers. That friction reduces the travel of the fabric by a tiny bit per stitch. But is just a hypothesis. Have not tested it. Quote
Members Gymnast Posted December 8, 2019 Author Members Report Posted December 8, 2019 I made a video about this comparison of these two vintage presser feet one normal foot and one food with a notch. I included a little more explanation and drawings than given above. I suppose the result is significant for those of you using a sewing machine without a walking foot. I did not make a comparison to a foot not hinged. People in this thread rightfully rejected the first results when the feet was not exsactly the same. I suppose and hinged foot may easier climb a "hill". But do you see a reason when to chose a hinged food and when to chose a non-hinged food? Quote Sewing Machines in Detail, YouTube channel
Members dikman Posted December 8, 2019 Members Report Posted December 8, 2019 Gymnast, there's no doubt about it, you are a nerd extraordinaire! Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
