Members tstan47 Posted June 12, 2019 Members Report Posted June 12, 2019 Hey guys, i am having a problem with marks on leather projects when they are either being worked on or when finished. Other than the obvious ‘try to be more careful” is there something I can do to get rid of the marks ? Here is a holster I am working on that show what I am talking about. Quote
Members chrisash Posted June 12, 2019 Members Report Posted June 12, 2019 They can be finger nail scratches, I have heard of some folk using fine cotton gloves to stop it happening Quote Mi omputer is ot ood at speeling , it's not me
Contributing Member fredk Posted June 12, 2019 Contributing Member Report Posted June 12, 2019 I concur, probably finger nail scratches. Ways to remove? burnish with a flat piece of glass which has a rounded edge. These are sold as burnishers; example - https://www.amazon.co.uk/Leathercraft-Glass-Slicker-Burnishing-Leather/dp/B004JAOB2K You can get these cheaper than this or you can make your own. For small nicks and marks you can generally reduce them with a spoon end modelling tool or even a teaspoon, but for large areas like this you need the glass plate Ways for it not to happen? cut finger nails close, be careful or give up leather work. Quote Al speling misteaks aer all mi own werk..
Members tstan47 Posted June 12, 2019 Author Members Report Posted June 12, 2019 (edited) What is the best way to remove the marks, wet leather first then use spoon or the glass burnisher? And for the record, I am still learning, this is the second holster I have ever made. Edited June 12, 2019 by tstan47 Quote
Members noobleather Posted June 13, 2019 Members Report Posted June 13, 2019 Nice stamping and stitching on the holster.I make sure I trim my finger nails when stamping else I get little indents on the wet leather. May use a glove or change the way I hold my stamp. Thanks Fredk hadn't thought about using a slicker or modelling spoon on those pesky little scratches Quote
Members YinTx Posted June 13, 2019 Members Report Posted June 13, 2019 That leather looks awful dry. Have you put any neatsfoot oil on it? Dubbin? anything? sometimes I find that can help prevent scratches too, seems more fragile when it's dry. Buffing lightly with a soft cloth after oiling can lay some of the scratches down. Bending it when dry can cause stress cracks too. After casing, plating with the glass evens things out before stamping. Well placed stamps, look forward to seeing the final version! YinTx Quote YinTx https://www.instagram.com/lanasia_2017/ https://www.youtube.com/playlist?list=PLK6HvLWuZTzjt3MbR0Yhcj_WIQIvchezo
Members tstan47 Posted June 13, 2019 Author Members Report Posted June 13, 2019 Can someone explain what is “Dubbin” how is it used etc and neatsfoot oil would that interfere with dying the leather? Quote
Members YinTx Posted June 13, 2019 Members Report Posted June 13, 2019 28 minutes ago, tstan47 said: Can someone explain what is “Dubbin” how is it used etc and neatsfoot oil would that interfere with dying the leather? Dubbin is a mixture of waxes and oils used to nourish the leather. Many make it themselves, or you can buy it like Aussie or Sedgwick's leather care, many many other brands. Just apply and rub in, sometimes use a little heat like from a hair dryer on low setting to help it along. Usually used after dye, etc. It tends to make the colors more vibrant, and the leather have more lustre. Neatsfoot oil can be applied before or after dye. It will not stop the dye from penetrating the leather, but can give a slightly different effect depending on when applied. Usually necessary after dye to prevent cracked leather - dye can make leather stiff, and it needs oils to improve it's serviceable life. Also usually applied before antique. Let it rest for several hours after applying to allow it to migrate throughout the leather. Hope this helps, YinTx Quote YinTx https://www.instagram.com/lanasia_2017/ https://www.youtube.com/playlist?list=PLK6HvLWuZTzjt3MbR0Yhcj_WIQIvchezo
Members Carnivore Posted June 13, 2019 Members Report Posted June 13, 2019 Go to your local quilting supply shop and get a pair of cotton quilters gloves. The ones I have came with non-slip finger tips and are perfect for holding tools and stitching. Quote
Members Handstitched Posted June 18, 2019 Members Report Posted June 18, 2019 On 6/14/2019 at 7:03 AM, Carnivore said: Go to your local quilting supply shop and get a pair of cotton quilters gloves. The ones I have came with non-slip finger tips and are perfect for holding tools and stitching. .......or you could just trim your nails @tstan47 I always use neatsfoot oil on my belts and some other products before I dye them, but with brown or lighter coloured belt & products , I use a thin oil similar to ' Armorall' for car upholstery, as it dries mostly clear and doesn't darken the leather like neatsfoot does. HS Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
Members HoneycuttMachine Posted August 5, 2019 Members Report Posted August 5, 2019 On 6/12/2019 at 11:29 PM, YinTx said: That leather looks awful dry. Have you put any neatsfoot oil on it? Dubbin? anything? sometimes I find that can help prevent scratches too, seems more fragile when it's dry. Buffing lightly with a soft cloth after oiling can lay some of the scratches down. Bending it when dry can cause stress cracks too. After casing, plating with the glass evens things out before stamping. Well placed stamps, look forward to seeing the final version! YinTx I wash mine with a little dawn dishwashing liquid on a wet sponge then wipe off with a cotton rag. this puts just enough moisture in the rag to get the saddle soap a little frothy, rub hell out of both sides, let dry a minute and then case leather, I spray mine with the kitchen sink sprayer ever so briefly just to wet, I then lay skin side down on a towel. , drying the hide side with another dry towel. this after maybe touching up a few dry spots with the sponge (now rinsed of dawn) will let me work the leather for quite a while in an air conditioned shop before re-wetting. I have found that leather properly treated and not needing a drink is less likely to pickup errant nail or tool marks before you want them to. I happened upon this by pure accident, I had put a long diagonal scratch somewhat deeper than the ones you show, I had a glass of Iced tea with me, I looke down, shrug and grab a big ice cube out of the cup, suck the tea off of it and then rubbed the scratch right up and out of the leather by burnishing lightly with the ice cube. Quote
Members Halitech Posted August 8, 2019 Members Report Posted August 8, 2019 Also be careful with rings and other jewelry, it can mark the leather as well Quote Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
