I think there are better deals out there I have a 30x18cm  cnc with a laser head I started with and mover up to a 50x65 cm laser engraver you have to assemble them yourself but definetly the possibilities are endless. I am currently using a 3500 mw laser and it is plenty for leather work. There is a learning curve but once you get the hang its am amazing tool.
  • Replies 43
  • Created
  • Last Reply
Top Posters In This Topic
19 hours ago, Somiskid said:
I'm about to pull the trigger on one of these exact lasers. How has it been going?
I've retired mine. Not because there is anything wrong with it, but I got a bigger faster and more powerful machine. I didn't go crazy, I just went with the 2 legged free arm machine with a 5.5W laser with an almost 7"x8" burn area. I have a logo I burn regularly and my burn time decreased from 35 minutes to 4:15. Haven't tried it yet with cutting.
Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
Do you have a link for the new one? Is the old one for sale lol????
Similar to this one
https://www.ebay.ca/itm/110V-3500MW-DIY-Laser-Engraver-Cutter-Cutting-Machine-Printer-210-170mm/192437293179?hash=item2cce28107b:g:apIAAOSwLs9aaE4f
But the seller I got it from was a lot cheaper and had a 5.5W laser
ummm not really lol I'd like to keep it just in case ;)
I got a 80 watt laser it cuts 10 oz.  leather easy. I sold my clicker ( it was manual and weighted 100 lbs,small work area so had move it when I wanted to use it), sold my steel rule die bender ( also heavy) and my Tandy foiler, the laser is much easier and better to use! It takes a little while to set things up but  when you do get them set up it is much easier and accurate!
  • 2 weeks later...
Would love to know more on this - we REALLY want to be able to just put initials/logos/monograms/etc. The sheer volume of letters, setups and info is staggering.
You will want to keep in mind that to engrave, the laser burns off the top layer of leather, and the results are not always very durable. I had stars in my eyes when I bought my 100 watt laser cutter, but have had to dial back my ambition due to the vulnerability of the engraving. It looks good, but does no wear well. And the look is always dark due to the burning process, but then that can look pretty good.
  • 3 months later...
Would love to see some examples of laser engraved leather that's been in use (like a wallet) for a while. We often treasure patina - but would those lines in your image above hold up, or would they wind up looking like a WWII sailor's tattoo? (Yeah, it used to be a beauty sitting on an anchor - now it's just a dark blob lol)
They are fragile and would certainly be compromised through daily use.
