Members Silverd Posted May 4, 2020 Members Report Posted May 4, 2020 (edited) I find that my clients are very creative and sometimes have more interesting ideas than do I...so I go with it! When the young woman saw my standard 11" I-Pad Pro case in traditional Mahogany with Black trim she immediately asked if I could make her one in Pink with a Hair-on Cowhide Main flap. "Of course I can" I said! As the details of the project unfolded I suggested Blue trim, the rest was hers. It took a lot of hours to actualize the end results but it was fun and since I'm only 3 years into this leather thing I considered it a learning experience. Aren't they all? BTW: The pockets hold a special compact charger and charging cables and the zipper tube holds the writing stick. Silverd Edited May 4, 2020 by Silverd image and grammer correction Quote
Members maxdaddy Posted May 5, 2020 Members Report Posted May 5, 2020 Wow, that' a really great design. Quote
Members YinTx Posted May 5, 2020 Members Report Posted May 5, 2020 Really awesome! Where'd you get that pink tho? YinTx Quote YinTx https://www.instagram.com/lanasia_2017/ https://www.youtube.com/playlist?list=PLK6HvLWuZTzjt3MbR0Yhcj_WIQIvchezo
Members dikman Posted May 5, 2020 Members Report Posted May 5, 2020 That's different! Nice job. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Silverd Posted May 5, 2020 Author Members Report Posted May 5, 2020 12 hours ago, YinTx said: Really awesome! Where'd you get that pink tho? YinTx Ebay and Amazon both sell leather paint in rattle cans. Mfg is Brillo. Small cans run about $10.00ea. I use white to help cover then pink over the top as a final coat. Silverd 12 hours ago, maxdaddy said: Wow, that' a really great design. Thank you Quote
Members hashtagartz Posted May 5, 2020 Members Report Posted May 5, 2020 I love the design and the colors! Perfection! Quote
Members Silverd Posted May 5, 2020 Author Members Report Posted May 5, 2020 1 hour ago, hashtagartz said: I love the design and the colors! Perfection! Thank you! Much appreciated Silverd Quote
Members YinTx Posted May 6, 2020 Members Report Posted May 6, 2020 12 hours ago, Silverd said: Ebay and Amazon both sell leather paint in rattle cans. Mfg is Brillo. Small cans run about $10.00ea. I use white to help cover then pink over the top as a final coat. I would have never guessed paint! How does it hold up? YinTx Quote YinTx https://www.instagram.com/lanasia_2017/ https://www.youtube.com/playlist?list=PLK6HvLWuZTzjt3MbR0Yhcj_WIQIvchezo
Members Silverd Posted May 6, 2020 Author Members Report Posted May 6, 2020 2 hours ago, YinTx said: I would have never guessed paint! How does it hold up? YinTx I'll let you know. The fragility factor of the product has been a concern from the start. I've not had too much previous experience with cow hair skin and even less with painting leather but I gave her a one year warranty should it all go south. The quality of the paint appeared to be excellent...and for the cost it should be. I spray lots on leather including stains, clear coats, adhesive, water, goofproof and now paint. So far so good. Silverd Quote
Members Grey Drakkon Posted May 6, 2020 Members Report Posted May 6, 2020 Pink is absolutely not my thing but you did a great job! I'm sure the customer is thrilled! Quote "Everyone with telekinesis, raise my hand!" -Repairman Jack
Members Silverd Posted May 7, 2020 Author Members Report Posted May 7, 2020 On 5/5/2020 at 7:23 PM, YinTx said: I would have never guessed paint! How does it hold up? YinTx Quote
Members YinTx Posted May 8, 2020 Members Report Posted May 8, 2020 That is awesome. I know some folks that are gonna love pink! Do you put any oil on the leather before the paint, or will it soak in after the paint? YinTx Quote YinTx https://www.instagram.com/lanasia_2017/ https://www.youtube.com/playlist?list=PLK6HvLWuZTzjt3MbR0Yhcj_WIQIvchezo
Members Silverd Posted May 8, 2020 Author Members Report Posted May 8, 2020 19 hours ago, YinTx said: That is awesome. I know some folks that are gonna love pink! Do you put any oil on the leather before the paint, or will it soak in after the paint? YinTx In this case I applied white color Brillo paint as a color "Primer" as it seemed to cover better. The paint appears to be of good quality and applies easily; it also blends well so there was no evidence of over spray. The first coat really soaks into the leather so I dont think that pealing will be an issue. Did not apply oil. The leather I was using is a Tandy's Superior Oak Veg Tan in the 5-6oz range and was plenty supple with out additional conditioning. The Pockets are made from Herman Oak and I wanted these with some temper to resist collapsing during user handling...so no oil on them either. I applied three coats of pain in total if I recall and did some patching of three extra needle holes by gluing into each hole a sliver of leather, then trimming it and sanding it smooth and respraying that effected area. Similar to repairing a car fender! Can hardly tell the accident occurred. I give the VOCs of the previously applied paint layer a chance to evaporate before applying the next layer. But did not let it dry completely. I think it is referred to as being open. This is done so that the 2nd layers chemically bond to the previous coat. if the previous coat was to dry completely then it would be a good idea to sand the surface first which provides a profile for the new paint to grab onto. I think multiple thin coats are better than one thick coat. Its pretty basic stuff and was quite easy. Surprisingly nice results. I had issues with a lot of the design and execution elements of this project but the paint was not one of them. I don't know if the paint will allow oil to pass as it was much thicker than the clear acrylics that I also use over stained leather. More experimenting is required. Good Luck! Silverd Quote
Members YinTx Posted May 9, 2020 Members Report Posted May 9, 2020 @Silverd, thank you so much for the details. Will save me a lot of experimenting and heart ache when I do it! YinTx Quote YinTx https://www.instagram.com/lanasia_2017/ https://www.youtube.com/playlist?list=PLK6HvLWuZTzjt3MbR0Yhcj_WIQIvchezo
Members Silverd Posted May 10, 2020 Author Members Report Posted May 10, 2020 On 5/8/2020 at 8:41 PM, YinTx said: @Silverd, thank you so much for the details. Will save me a lot of experimenting and heart ache when I do it! YinTx Good luck. Have fun! Silverd Quote
