Members Alexis1234 Posted May 10, 2020 Members Report Posted May 10, 2020 I am not happy with my cut borders- is there a way to soften/round them? They need fixing( they look jagged, uneven, unacceptable). I'm not sure if there is a tool? What am I doing wrong? Is this the way the are supposed to look? I am struggling with tooling. Thank you for any help. Quote
Members TSes Posted May 10, 2020 Members Report Posted May 10, 2020 Try running a large, shallow, smooth beveler down each cut line where the border stamp will go. Don't go too deep. Then carefully run a modeling spoon down the cut line to knock off the sharp corner that's left. Then do the border stamp. Quote
Contributing Member fredk Posted May 10, 2020 Contributing Member Report Posted May 10, 2020 (edited) you can get a plastic beveler tool which fits into the swivel knife instead of a blade. That might help PS. I made my own versions Edited May 10, 2020 by fredk Quote
Members Alexis1234 Posted May 10, 2020 Author Members Report Posted May 10, 2020 Thank you both. Frekd how did you make your own if I might ask? Quote
terrymac Posted May 10, 2020 Report Posted May 10, 2020 (edited) Easiest way I know is to use a back beveler. It rounds off the "back" side of your cut. Barry King sells them Terry Edited May 10, 2020 by terrymac Quote
Contributing Member fredk Posted May 10, 2020 Contributing Member Report Posted May 10, 2020 28 minutes ago, Alexis1234 said: . . .. Frekd how did you make your own if I might ask? Dead simple; I bought two bars of certain plastics. 1 is delrin and 1 is nylon. The delrin is the diameter to go into the knife. The nylon is smaller in diameter. It slips into a hole drilled in the delrin part. I used a modelling knife to pare away one end of the nylon bar to get the bevel shape I wanted. It can all be done on one bar but I had to be awkward. The cost of the two bars was about $3 and there's plenty to do other profiles I first saw this thing on here but found a. they were/are very costly and b (were) very hard to get. So I made one. If I find it amongst the mess on my desk I'll photo it and put it up. Quote
Members buzzardbait Posted May 11, 2020 Members Report Posted May 11, 2020 I cut my lines, then I bevel with a push beveler. after that I round over the edges with a back bevel blade in a swivel knife. My push beveler and my back bevel blade for the swivel knife are both from Barry King. Quote
Members Alexis1234 Posted May 11, 2020 Author Members Report Posted May 11, 2020 Thank you! I'll have to put in an order with him Quote
Members Retswerb Posted May 12, 2020 Members Report Posted May 12, 2020 @fredk I’d love to see a pic of that. I’ve been swivel-beveling for a while now per @immiketoo but my hand gets awfully sore running the regular beveler tool along. Quote
Members Scootch Posted May 14, 2020 Members Report Posted May 14, 2020 Your geometric lay out looks great. I find it much easier to carve something than lay out geometric patterns. It's much easier to hide the mistakes with carving. Barry King also sells a push beader like I used here. You could use this tool between your wishbone border stamps. I cut two parallel swivel knife cuts then push the beader down the cuts. Nice job, Scootch Quote
Members Alexis1234 Posted May 14, 2020 Author Members Report Posted May 14, 2020 Thank you all for the help. I looked at the Barry King site. I've been slowly buying tools since December and can see I need to add a few. An update on this project(saddlebags): I tried correcting the cut lines this morning and some of them were soo wavy there was no way I could acceptably blend them in/ soften. The closer I looked, the worse they were,lol. I need to learn to cut straight! So, it's back to square one. Quote
Members Scootch Posted May 15, 2020 Members Report Posted May 15, 2020 One thing that can help with straightness is to buy a really wide blade for your swivel knife. A wider blade is easier to keep straight for those long borders. It also helps me to cut toward me so that I can see the sharpened edge that is not in the leather. Making sure the exposed sharp point is on top of your scribe line will ensure your not fish tailing the cutting portion in the leather. Scootch Quote
Members Vikefan Posted May 15, 2020 Members Report Posted May 15, 2020 Alexis1234 Have you tried the the double Line push creasers that Osborne used to make. brucejohnsonleather.com might have some used ones for sale? I use a double lined one for the belts I make. Hope that helps. Vikefan Quote
Members Arturomex Posted May 15, 2020 Members Report Posted May 15, 2020 And there's always this from Tandy: https://tandyleather.ca/collections/tools/products/craftool-hand-border-tool Wouldn't load a photo but the link will show you a border tool much like an adjustable stitching groover except this holds a swivel knife blade. Cuts nice, straight lines. Handles curves quite well. Regards, Arturo Quote
Contributing Member fredk Posted May 18, 2020 Contributing Member Report Posted May 18, 2020 On 5/12/2020 at 8:57 AM, Retswerb said: @fredk I’d love to see a pic of that. I’ve been swivel-beveling for a while now per @immiketoo but my hand gets awfully sore running the regular beveler tool along. I got my materials mixed up. The nylon goes into the knife and into a hole in the delrin. The delrin is carved to the profile. tbh I've only used these a couple of times as I don't do hardly any tooling or swivel knife work 1. this has one straight cliff edge and a slope to bevel 2. this has a centre bar, about 1 mm high by 1.5 mm wide and a slope on each side to bevel both sides of a line B. The two together so you can see how I made them. Others could make them far better using a lathe and power tools but I don't have those things so I need to do it by hand With these materials I can make any profile which suits me Quote
Members Retswerb Posted May 18, 2020 Members Report Posted May 18, 2020 Thanks @fredk! I’ll definitely have to try that, would be a huge improvement over gripping the regular beveler and running it along. Quote
Members Arturomex Posted May 18, 2020 Members Report Posted May 18, 2020 11 minutes ago, Retswerb said: Thanks @fredk! I’ll definitely have to try that, would be a huge improvement over gripping the regular beveler and running it along. Thanks indeed, Fred. Regards, Arturo Quote
Moderator immiketoo Posted July 5, 2020 Moderator Report Posted July 5, 2020 Seems like this is pretty will covered, but I’ll add this. Part of your problem is that you’re cutting too deeply. These line borders don’t have a lot of support once you cut both sides, and the grain can start to “peel” up on the cut edges. for the most part, I don’t cut these borders anymore, rather I use a wing divider to score a deep line and leave it at that. those push bevelers and beader blades are really difficult to control and it’s easy to mess up a piece of leather in a hurry. The wing dividers afford a lot more control, and if you do need to cut them in, there’s a sweet channel to guide your swivel knife. Quote
Moderator immiketoo Posted July 5, 2020 Moderator Report Posted July 5, 2020 In these images, the border lines were cut after the dividers, then smoothed with a modeling spoon to round them off. Quote
