Moderator Wizcrafts Posted August 5, 2020 Moderator Report Posted August 5, 2020 6 hours ago, Ysalex said: Thanks cowboyBob. I followed these instructions and yours for timing to a T, and now it fails to pick up any stitches in reverse or forward. The thread very reliably twists away from the hook. Apparently, your thread is overly twisty. When I have twisty thread it usually twist clockwise. So, I counter it by threading through to holes in the top post in a counterclockwise direction. If your machine doesn't have a post with two or more holes, wrap the top thread CCW around something along the path. This should counteract the twist and give you enough loop for the hook to pick off. If this is the case, replace the thread ASAP. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Ysalex Posted August 10, 2020 Author Members Report Posted August 10, 2020 (edited) Update: thank you everyone for the advice. I was (actually, my wife was) able to find a professional sewing machine repair guy in our city. After trying to work around it the stick screw it became necessary to remove it. after working the day with a carbide drill bit, a lot of patience and various extractors, it came free! so now I need to replace the screw with the same length and thread size. Not to keep blasting the forum with questions but does anyone know where I can find that info? after I get it replaced hopefully it’s just a matter of timing and adjustment. I also ordered brand new needles just to be sure, and new bonded nylon thread. Edited August 10, 2020 by Ysalex Quote
JJN Posted August 10, 2020 Report Posted August 10, 2020 Yay! That has to feel good getting that thing out of there. If you have a micrometer or good caliper, measure the diameter across the threads to the nearest thousands of an inch. Then measure along the length 10 threads, peak to peak also to the nearest thousands of an inch. Post those measurements and we can figure it out. The screw could be metric or is could be fractional inch. Most likely is not a screw you can get locally. If you have a parts manual, look it up and google the part number. You did a good job extracting that screw without causing any damage. Wipe all the metal shaving out of the machine! Quote Ferdco Juki Pro-2000, Juki DNU-1541S, LS-1341, LU-563, DLN-9010A-SH, MO-6714S, Consew 206RB, 206RB-1, Chandler/Bernina 217 6mm w/Cam Reader, Brother LT2-B842-5
Members chrisash Posted August 10, 2020 Members Report Posted August 10, 2020 Company details on this link, give them a ring and photo of where it was in the machine to avoid confusion https://artisansew.com/leatherstitchingmachine.html Quote Mi omputer is ot ood at speeling , it's not me
Members dikman Posted August 10, 2020 Members Report Posted August 10, 2020 Or you could contact Cowboy Bob and ask him. I recently had reason to check the size of the screws holding the bobbin winder plate on and was very surprised to find they're not metric. They're not Whitworth or BA, my best guess is 3/16" UNF. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
CowboyBob Posted August 10, 2020 Report Posted August 10, 2020 It is a 15/64" x 40tpi Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members dikman Posted August 10, 2020 Members Report Posted August 10, 2020 I'm really surprised at this, I know all about the older machines having oddball screw/thread sizes but I just assumed that when the Chinese copied the machines they would have used standard, probably metric, threads. Who'd have guessed...... Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Ysalex Posted August 11, 2020 Author Members Report Posted August 11, 2020 Thanks guys, and thank you cowboy bob, that seemed to be it. i couldn’t find that screw near me so I ordered one from Chester at artisan in north California, it’s near to me and they are pretty quick to ship so it should be here soon. in the meantime I am happy to say that the machine is now timed properly and bulletproof (as far as I can tell) in reverse and forward. I found a sewing machine mechanic in my area and he helped me tonight get it working. the only challenge past the missing set screw was that even with the set screw removed, and the other two screws loosed/removed, that shaft did not want to turn at all. It took awhile and a lot of gentle nudging/pressure, and some heat, to work it loose. After that it was easy sailing. im pretty sure that whoever owned this machine before did that adjustment themselves and did a poor job of it. I also think they used too strong a strength of lock-tight and some got into the shaft. last thing I’ll need to work out tomorrow is that the presser feet are not feeding the material through correctly. I get some forward motion and then I get a near equal amount of back motion, so the stitch length is very short even with the handle dialed all the way up or all the way down. but I’m not going to sew with it until I get that set screw to lock the shaft in place. 20 hours ago, dikman said: Or you could contact Cowboy Bob and ask him. I recently had reason to check the size of the screws holding the bobbin winder plate on and was very surprised to find they're not metric. They're not Whitworth or BA, my best guess is 3/16" UNF. Yeah that surprised me too. Quote
Members dikman Posted August 12, 2020 Members Report Posted August 12, 2020 Sometimes I am so dumb (something to do with getting old, maybe?), anyway I had cause to adjust the feet on my 4500 so got out the "manual" that came with it. Wasn't any help BUT the parts list is very comprehensive, listing all the screws used, and they're all what I would call American thread sizes, fine pitch. No metric, which still surprises me. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
CowboyBob Posted August 12, 2020 Report Posted August 12, 2020 6 hours ago, dikman said: Sometimes I am so dumb (something to do with getting old, maybe?), anyway I had cause to adjust the feet on my 4500 so got out the "manual" that came with it. Wasn't any help BUT the parts list is very comprehensive, listing all the screws used, and they're all what I would call American thread sizes, fine pitch. No metric, which still surprises me. And you wonder why did a Japanese company design it that way?Which is nice since they are more in common with alot of the Singer screws. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
