Any of you own a fencepost thumper? One of those 8" diameter tubes with a plate welded over the end and handles on the side, drives a post like butter?
Now scale it down. Say 1cm diameter, 5cm long, no handles (OK, you could embed it in a malleable thermoplastic to fit in a clenched hand precisely, with a thumb over the top).
And now you've got rid of the problem of unpredictable thrust when you use it on a punch. Simply plug the end of a tube, then thread it and add a knurled cap with a rubber shock pad?
Dunno what to call it, but you can't patent it 'cos I said it here first!
  • Replies 24
  • Created
  • Last Reply
Top Posters In This Topic
How would you use it? Pick it up and drop it down each time? I'm trying to think of how it'd work for beveling. I could see it for a one hit stamp perhaps but I've gotten good with just repetition on those.
Springload it like a  center punch. (R) <---my turn :-P
Fix the leather, one hand on the stamp, main hand thumping it with the thumb on top. The realisation is it gives far finer control than a mallet putting sideways vectors into the head of the stamp - and you can aways do that. More importantly, you can get a faster hit rate. The biggest issue's the variable size of chisel shaft, I think 7mm should do it, making for an M10 tube.
My wrist hurts just thinking of using it, if I’m picturing it right. Without the weight of the mallet your arm and wrist would have to do all the work. Am I missing something?
  • CFM
What I do when I think of these things. Go for it, build it and give it a try!
  • 1 year later...
Hmmm. Slide hammer....
I use a press instead. No hammering.
Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
For punching holes sure I get that as well as one time impressions on cased leather.
I like the idea Sanch has, make a slide hammer out of it.  Slip over tool, line up and hammer.  Two or three different weight hammers.
